查看: 2475|回复: 3
Cadence Launch Script Revised.
发表于 2015-12-26 10:15:15 | 显示全部楼层 |阅读模式
Here's the revised script that I took from min4max and modified it to allow users to initialize workspaces preloaded with pdk and cdk.
You can download the pdk and cdk from
http://www.eda.ncsu.edu/wiki/FreePDK
http://www.eda.ncsu.edu/wiki/NCSU_CDK.
Remember to change the variables:
# Set the PDK_DIR variable to the root directory of the FreePDK distribution
setenv PDK_DIR /eda/pdk
# Set CDSHOME to the root directory of the Cadence ICOA installatio
setenv CDSHOME /eda/IC616
from pdk ncsu_basekit/cdssetup/setup.csh to the corresponding locations.
Also do not forget to set,
PDK_DIR=/eda/pdk,
CADHOME=/eda,
and
LM_LICENSE_FILE=$CADHOME/license/license.dat
to the correct locations.
Finally,
change/remove the extention from the script from the .doc extention.
Usage:
cadence ws|wsc|start|help
ws - initialize workspace with CDK+FreePDK technology on the current directory.
wsc - clear workspace with CDK+FreePDK technology on the current directory.
start - start cadence from the current directory.
help - print help information.
cadence.doc (9.98 KB , 下载次数: 19 )
发表于 2015-12-26 20:54:49 | 显示全部楼层
Thank you.
发表于 2015-12-27 09:18:55 | 显示全部楼层
good job ~~~
发表于 2016-1-10 20:54:05 | 显示全部楼层
非常感谢提供!
GMT+8, 2025-12-17 00:34 , Processed in 0.022136 second(s), 6 queries , Gzip On, Redis On.
