查看: 1665|回复: 0
[招聘] Marvell美满电子成都、南京、上海多职位招聘
发表于 2015-12-23 10:45:00 | 显示全部楼层 |阅读模式
如感兴趣,欢迎投递简历至china-hr-staffing@marvell.com,邮件标题格式为应聘职位名称-姓名-中国顶级开发网
成都
SoC Platform部门: IC Design Engineer (SOC)
上海
SoC Platform部门: IC Design Engineer (SOC)/ Software Engineer
CSI部门: Datacom System Engineering - Software Engineer
Wireless Technology部门: GPS software engineer
Video部门:Software Engineer
南京
Wireless Technology: GPS software engineer
Central Engineering: Analog IC Layout (Nanjing)-CE
成都
SoC Platform: IC Design Engineer (SOC)
Responsibilities:
-Work on IP and chip design;
-Understanding architecture and protocols;
-RTL design and verification;
-Documentation;
-Work closely with FPGA team for pre-silicon prototyping;
-Work closely with software team for driver developments;
-Travelling to US is not mandatory, but sometimes required.
Qualifications:
-MS or PHD in EE;
-Good understanding of digital IC design;
-Good team work spirit and strong problem solving skills;
-Knowledge of Synthesis, STA and DFT is a plus;
-Knowledge of SystemVerilog and UVM is a plus;
上海
Responsibilities:
-Documentation;
Qualifications:
-MS or PHD in EE;
SoC Platform: Software Engineer
Description:
In this position, you will be working with the system architects, technical leaders and other developers to contribute to embedded Linux BSP.
You will be responsible for the detailed development specifications, system performance profiling and you also will work with the validation team to ensure the system is thoroughly tested.
Qualifications:
-Master in Electronic Engineering or Computer Science major
-Strong in c/c++/assembly programming skills
-Deep understanding about SOC system
-Good at Linux kernel and driver development
-Hardware debugging experience is a plus
-Experience with PCIE, USB, memory controller or NAND
-FLash is a plus
-Fluent communication in English
CSI: Datacom System Engineering - Software Engineer
Description:
This is an entry level, software engineering oriented system engineer position. The engineer will be part of the vertical system engineering team composed with hardware engineering, software engineering, firmware engineering, FPGA design engineering, signal integrity engineering, and others. The IC products to work with include Ethernet PHY/NIC/Switch/SoC, high speed SerDes based PHYs, DTV front end components, PLC PHYs, and so on. System engineering team is responsible for many post silicon engineering efforts like product validation, platform development, collateral development, technical support and so on.
Qualifications:
-Test Automation Software Development.
-GUI Tool Software Development.
-Driver Software Development.
-Manufacturing Software Development.
-Department/Enterprise Software Tool Development.
-BS/MS in EE/CE/CS.
-Must have good C/C++ program skill.
-Must be familiar with MS Window system.
-Must have good knowledge with computer system and data network system.
-Must be willing to work in a multi-tasking, fast pace, team oriented working environment.
-Must be able to quickly absorb different kinds of knowledge and apply them in the works.
-Working experience on software development are preferred.
-Familiarity with MS .net, Ethernet and network protocols are some pluses.
Responsibilities:
-Design and optimize algorithms for GNSS and/or hybrid positioning system based on GPS/GNSS, WiFi, BT (BLE), inertial sensors, etc;
-Develop and optimize hybrid positioning software based on existed codebase;
-perform algorithm and code optimization based on customer's requirement;
-Make documents on algorithm design, simulation results, software implement and test cases.
Qualifications:
-Master or PHD in EE, CS or geomatics with the knowledge on GPS or hybrid positioning technologies;
-Familiar with programming languages, including C/C++, Matlab and Python, etc.
-Understanding on ARM core architecture and embedded system;
-Good personality and communication skills.
Video: Software Engineer
Responsibilities:
The candidate will be responsible for video decoder & encoder (MPEG2/MPEG4/H264/H265/VP8/VP9) driver development, integration and bug fixing, he will act as core development engineer to support AE team resolving critical bugs and also participating resolving system level video pipeline related issues.
Qualifications:
-Master degree in Electrical Engineering or Computer Science
-C development experience;
- Experience of one of MPEG2/MPEG4/H264/H265/VP8/VP9 decoder or encoder
南京
Responsibilities:
-perform algorithm and code optimization based on customer's requirement; 4)
Qualifications:
Central Engineering: Analog IC Layout(Nanjing)-CE
Responsibilities
Be a part of the Central Analog design team. Your main responsibility is custom analog layout. You will be responsible for all levels of analog layout from block level up to the Analog top level integration and verification. You will communicate and get directions from experienced analog design engineers to ensure high quality.
Qualifications
-Bachelor Degree of Electronics, Electronic Engineering or equivalen
-Good communication skills in English.
-Be familiar with Unix OS.
-Understanding basic characteristic of transistor, resistor, capacitor and diode.
-Experience with Cadence or Silicon Canvas layout tools is plus.
-Experience with DRC/LVS verification tools is plus
GMT+8, 2025-12-29 16:56 , Processed in 0.024628 second(s), 6 queries , Gzip On, Redis On.
