查看: 2251|回复: 1
[招聘] 【NVIDIA急招】ASIC Physical Design/后端工程师(英伟达上海)
发表于 2015-12-9 15:42:23 | 显示全部楼层 |阅读模式
一.公司简介
        NVIDIA (英伟达™)(www.nvidia.cn)公司(纳斯达克代码:NVDA)是全球视觉计算技术的行业领袖及GPU(图形处理器)的发明者。作为高性能处理器的GPU可在工作站、个人计算机、游戏机和移动设备上生成令人叹为观止的互动图形效果。公司在全球拥有超过8000名员工,总部在加利福尼亚州圣克拉拉。
工作地址:上海研发中心【上海申江路5709号(秋月路26号)矽岸国际2号楼】
二.投递方式
感兴趣请的请将简历发送至:yvettes@nvidia.com;邮件注明“BBS”
我们会认真对待每份简历,保证每份简历都有是否通过简历筛选的回复。同时欢迎随时电话或邮件咨询职位详情,申请进度等等:021-61043660
三.职位详情
1.        ASIC Physical Design engineer
As a senior member of our ASIC-PD team, you'll be working on streamlining the chip infrastructure process across product designs, focusing on full chip layout planning (partitioning, planning clock distribution and other structure, methodology), partition/full chip timing closure (primetime scripts, other tools, etc) and gate-level design of high-speed logic
RESPONSIBILITIES:
•        Chip integration and netlist generation
•        -Synthesis, Formal verification, netlist quality check
•        Work in conjunction with Place and Route Engineers to achieve timing closure for both partition level and full chip level
•        Develop and enhance entire timing flow from frontend (pre-layout) to backend (post-layout) at both chip and block level.
&#8226;        Develop custom timing scripts using tcl/primetime for clock skew analysis, special circuits such as clock dividers, core logic <-> IO macros interfaces such as PCI-E, Frame-Buffer/Memory, TMDS, etc.
&#8226;        Develop flow to physically partition and floorplan the entire chip.
&#8226;         Develop scripts for performing ECO's.
MINIMUM REQUIREMENTS:
&#8226;        BS or MS in Electrical Engineering or Computer Science
&#8226;        relevant ASIC experience ideally with a focus in the chip integration /synthesis/formal and timing closure
&#8226;        - Excellent scripts skills
&#8226;        - Excellent written and verbal communication skills in English
&#8226;        - Ability to multiplex many issues, set priorities, and work in a team environment
&#8226;        - Keep up to date with leading edge technologies
Best Regards,
Yvette Shen
APAC Staffing Team
NVIDIA SHANGHAI
Building 2, No. 5709 Shenjiang Road (No.26 Qiuyue Road)  201210.
Tel +(86 21) 61043660
yvettes@nvidia.com
发表于 2015-12-14 17:21:11 | 显示全部楼层
招的又是senior engineer 怎么不招应届的呢?忧伤!
GMT+8, 2025-12-21 17:27 , Processed in 0.017421 second(s), 6 queries , Gzip On, Redis On.
