查看: 3941|回复: 5
current density(Id/Weff) plot in IC 616
发表于 2015-11-18 20:45:26 | 显示全部楼层 |阅读模式
Hi everyone,
I am trying to plot current density (Id/Weff) v/s Vgs i.e Vgs sweep, but unable to plot and get following error in CIW (IC616 virtuoso):-
expression evaluation failed: val is not legal.
expression evaluation failed: OPT("/M0","ids")/OPT("/M0","weff")
"("quotient" 0 t nil ("*Error* quotient: can't handle (srrWave:0x23af1020 / nil)"))"
I tried to make expression in calculator using  opt option and used ids/Weff. I have added the screenshot. Please help me to solve this problem.
发表于 2015-11-19 09:37:43 | 显示全部楼层
为何都喜欢用Ubuntu呢
发表于 2015-11-19 09:42:14 | 显示全部楼层
为何都喜欢用Ubuntu呢
发表于 2015-11-19 09:45:10 | 显示全部楼层
从出错信息上看, 分母上的波形不存在啊, 所以不能作除法.
发表于 2015-11-19 09:47:13 | 显示全部楼层
在sweep分析中,OP函数返回的是单一数值,你的用户函数需要从sweep分析产生的结果中构建,不能从OP函数构建。
 楼主| 发表于 2015-11-19 18:48:43 | 显示全部楼层
thank you @amodaman. So do i need to declare width as variable and sweep it?
GMT+8, 2025-12-8 05:07 , Processed in 0.022890 second(s), 6 queries , Gzip On, Redis On.
