查看: 4523|回复: 5
Bitcoin miner 随笔
发表于 2014-6-27 22:39:11 | 显示全部楼层 |阅读模式
下午在KC705上跑了一下bitcoin的代码,下半调试了一下。程序的接口比较简单,只有时钟复位和uart的引脚。
机器是用服务器跑的,自己的电脑室4g,32位的系统,但是在实现的时候出错,只能选择服务器跑了。
下面是资源消耗情况,芯片选择的是
XC7K325T-2FFG900C
|          Site Type         |  Used | Loced | Available | Util% |
| Slice LUTs*                | 58932 |     0 |    203800 | 28.91 |
|   LUT as Logic             | 27983 |     0 |    203800 | 13.73 |
|   LUT as Memory            | 30949 |     0 |     64000 | 48.35 |
|     LUT as Distributed RAM |     0 |     0 |           |       |
|     LUT as Shift Register  | 30949 |     0 |           |       |
| Slice Registers            | 87228 |     0 |    407600 | 21.40 |
|   Register as Flip Flop    | 87228 |     0 |    407600 | 21.40 |
|   Register as Latch        |     0 |     0 |    407600 |  0.00 |
| F7 Muxes                   |     0 |     0 |    101900 |  0.00 |
| F8 Muxes                   |     0 |     0 |     50950 |  0.00 |
3. DSP
| DSPs           |  682 |     0 |       840 | 81.19 |
|   DSP48E1 only |  682 |       |           |       |
7. Primitives
| Ref Name |  Used |
| FDRE     | 87207 |
| SRL16E   | 24901 |
| LUT3     | 19577 |
| LUT2     |  7823 |
| SRLC32E  |  6048 |
| DSP48E1  |   682 |
| LUT1     |   501 |
| CARRY4   |    96 |
| LUT6     |    43 |
| LUT4     |    34 |
| LUT5     |    27 |
| FDSE     |    21 |
| OBUF     |     1 |
| IBUF     |     1 |
Bitcoin_ytf.rar (5.34 MB , 下载次数: 85 )
发表于 2014-7-2 21:05:49 | 显示全部楼层
很好很强大
发表于 2014-7-8 00:50:17 | 显示全部楼层
感謝分享
发表于 2017-9-23 20:24:33 | 显示全部楼层
很好很强大
发表于 2017-12-11 23:25:08 | 显示全部楼层
thnx!
发表于 2018-5-24 14:56:33 | 显示全部楼层
代码都包含什么啊?比如说结构啊
GMT+8, 2025-11-4 07:19 , Processed in 0.023551 second(s), 10 queries , Gzip On, Redis On.
