查看: 2597|回复: 5
求助大神关于SYNOPSYS VCS的安装
发表于 2015-10-11 22:39:37 | 显示全部楼层 |阅读模式
我的是UBUNTU 14.04 64bit 的系统,但是每次打上“DVE”指令老是显示没有找到license,但是我的环境变量已经设置了,而且sssverify也通过了,我已经整了两天了,求求大神,谢谢了
发表于 2015-10-12 09:25:35 | 显示全部楼层
是开license服务的,还是直接指向license文件的?
 楼主| 发表于 2015-10-12 09:38:24 | 显示全部楼层
回复 2# daviehj point to the license(sorry I'm on linux.....)
发表于 2015-10-12 10:07:05 | 显示全部楼层
should start "lmgrd -c license.dat" (sort of, I don't remember the exact command)
all EDA tools need lmgrd and each company's demon
I don't understand what you mean by point to the license?
发表于 2015-11-11 09:03:25 | 显示全部楼层
you need to edit the license.dat first, configing the server port and the path of daemon program.
then run the following command
"lmgrd -c license.dat -l lic.log"
check the lic.log to see if the license server is up.
if there is no error, setting the LM_LICENSE_FILE to that <port_number>@<hostname>
发表于 2015-11-11 09:25:10 | 显示全部楼层
學習  學習  學習  學習  學習  學習
GMT+8, 2025-11-4 00:11 , Processed in 0.022538 second(s), 7 queries , Gzip On, Redis On.
