查看: 34138|回复: 155
波特图(bode plot) 的误导!!! ***** Thomas Lee 吐血推荐 *****
发表于 2007-5-21 16:26:41 | 显示全部楼层 |阅读模式
正如RFIC design的鼻祖 Thomas Lee所说的,bode plot 只是Nyquist判据的一个子集,并非在任何情况下都适用。。。。
stability criteria.pdf
490.15 KB, 下载次数: 789 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-5-21 16:49:19 | 显示全部楼层
kankan!
发表于 2007-5-21 21:52:15 | 显示全部楼层
thanks
发表于 2007-5-21 23:12:21 | 显示全部楼层
看看值得吐血不
发表于 2007-5-22 08:45:43 | 显示全部楼层
xiexie!
发表于 2007-5-22 09:33:09 | 显示全部楼层
看看什么东西
发表于 2007-5-22 10:10:14 | 显示全部楼层
Can anyone give an explanation about the view of paper?
So what can we do after reading and understanding this paper in our daily analog design?
 楼主| 发表于 2007-5-23 09:10:41 | 显示全部楼层
key points of this paper are:
1) A system should only be analyzed for stability using the Bode plot, if it has at most one phase crossover frequency. Additionally, if it has only one gain crossover frequency and the amplitude ratio as well as the phase angle are decreasing at the gain crossover and afterward, then the gain and phase margins can be calculated in a way found in control textbooks.
2) A system that has only one phase crossover frequency but multiple gain crossover frequencies is stable if the amplitude ratios, corresponding to frequencies where f= -180∞-n*360∞, are all less than unity and the open-loop system is stable. The gain margin is calculated from the crossover frequency or a frequency corresponding to a larger n, whichever exhibits the largest amplitude ratio.
3) If the Bode plot information is inconclusive, the Nyquist stability criterion should be applied for stability analysis of closed-loop systems.
Fortunately, systems in analog circuits  are usually not pathological, so bode plot works well.
but if you are an aggressive and creative designer, you'd better pay more attention to your stability
checking approach. Sometime bode plot might cheat you.
Best Regards,
River
发表于 2007-5-23 09:14:40 | 显示全部楼层
看不到阿看不到
发表于 2007-5-23 11:10:41 | 显示全部楼层
还有这一说?看看
GMT+8, 2025-12-20 18:07 , Processed in 0.023292 second(s), 7 queries , Gzip On, Redis On.
