查看: 2947|回复: 5
[求助] LEON3+NOR FLASH
发表于 2015-9-8 16:40:12 | 显示全部楼层 |阅读模式
大侠,
    请问如果希望code直接在NOR FLASH上运行,NOR FLASH是否需要有特殊接法?
我用的flash为JS28F512P33EFA,我不太确定这个芯片的clock脚是怎么使用的,请指导,谢谢!
发表于 2015-9-23 17:21:37 | 显示全部楼层
是spi接口吗?参考datasheet
 楼主| 发表于 2015-11-4 09:58:19 | 显示全部楼层
没人知道怎么弄吗?
发表于 2015-11-8 10:31:58 | 显示全部楼层
CLOCK: Synchronizes the device with the system’s bus frequency in synchronous-read mode.
During synchronous read operations, addresses are latched on the rising edge of ADV#, or on the
next valid CLK edge with ADV# low, whichever occurs first.
WARNING: Designs not using CLK for synchronous read mode must tie it to VCCQ or VSS
发表于 2015-11-14 14:33:05 | 显示全部楼层
LEON3+NOR FLASH
发表于 2017-12-7 13:03:33 | 显示全部楼层
不知道官网有没有
GMT+8, 2025-9-17 11:35 , Processed in 0.016997 second(s), 5 queries , Gzip On, Redis On.
