查看: 8178|回复: 10
Error in DC Synopsys topo mode
发表于 2015-9-2 04:47:37 | 显示全部楼层 |阅读模式
Hi,
i was trying to use design compiler in topographical mode.
Then i set the physical library too, with set physical_library /.../tsmc090nvtlk_9lm_2thick.pdb
while for the target i used typical.db
After analyzing the files, i wrote: compile_ultra $top_module -exact_map, but DC shows me an error:
"Failed to compile physical library"... Why??
Thanks
发表于 2015-9-2 09:36:09 | 显示全部楼层
why don't you use the milkyway library ?
 楼主| 发表于 2015-9-2 18:41:02 | 显示全部楼层
Yes, I heared it, infact i tried to create MW library, but i don't know what i have to add in Reference library. I tried to add LEF folder but the library wasn't created. Thanks you're helping me!
mw_create_library
mw_create_library
发表于 2015-9-3 02:04:02 | 显示全部楼层
please share the library
 楼主| 发表于 2015-9-4 04:19:07 | 显示全部楼层
Then, my startup script is this:
set target_library /home/stefano/TSMC.90/aci/sc-x/synopsys/typical.db
set link_library [list {*} $target_library]
set synthetic_library [list dw_foundation.sldb]
set symbol_library [list generic.sdb]
create_mw_lib -technology /home/stefano/TSMC.90/aci/sc-x/astro/tf/tsmc090_9lm_2thick.tf -mw_reference_library /home/stefano/TSMC.90/aci/sc-x/astro/tsmc090g_fram/ -bus_naming_style {[%d]} ./tsmc90_mw
open_mw_lib tsmc90_mw
set vhdlout_show_unconnected_pins true
I managed to create mw library, so i tried to use it and compile my design with compile_ultra command.
Now i have these errors and at this point i don't know if tsmc libraries are correct.
error1
error1
this is link where you can take the entire library https://drive.google.com/open?id=0B1KkQQrGHxeXUThtcVFRNFlBc00
(TSMC SAGE-X 90nm)
发表于 2015-9-4 12:43:08 | 显示全部楼层
Do you have technology file ?
 楼主| 发表于 2015-9-4 16:23:07 | 显示全部楼层
Yes tf.rar (974.14 KB , 下载次数: 41 )
发表于 2015-9-6 12:57:21 | 显示全部楼层
please share
 楼主| 发表于 2015-9-7 19:37:01 | 显示全部楼层
You controlled technology files? Please
phoenixson
发表于 2017-7-20 00:20:02 | 显示全部楼层
thank you very much
GMT+8, 2025-12-26 01:09 , Processed in 0.026954 second(s), 6 queries , Gzip On, Redis On.
