查看: 3109|回复: 6
License Design Compiler
发表于 2015-8-22 21:08:43 | 显示全部楼层 |阅读模式
Hi guys, i'm not able to start lmgrd on Fedora 17.I have SCL 11.5 i86_lsb, DC 2013.03 and installer v3 downloaded at http://bbs.eetop.cn/thread-418738-1-1.html
I generated license on Windows 7/8, and verificated with sssverify on linux.
The 3 first lines of my license are:
SERVER localhost 000000000000 27000
VENDOR snpslmd /usr/synopsys/11.5/linux/bin/snpslmd
USE_SERVER
I used MAC of zeros because lmhosid returned it, but i tried also with the real MAC of PC.When i write lmgrd -c /usr/syonpsys/synopsys.dat -l , it returns "lmgrd exited with status 0, signal 17". Why?
While, the lines of bashrc are:
export SNPSLMD_LICENSE_FILE="27000@localhost"
export LM_LICENSE_FILE="27000@localhost"
exportPATH=$PATH:/usr/synopsys/H-2013.03/bin
exportSYNOPSYS=/usr/synopsys/H-2013.03
Anyone can help me please?
There are other post about this problem, but i don't find the correct solution
发表于 2015-8-23 08:49:09 | 显示全部楼层
Fedora? aggressive linux release , normally speaking, it is not friendly to general eda tools.
 楼主| 发表于 2015-8-23 08:53:07 | 显示全部楼层
Now, i'm trying to use CentOS 6.5, maybe SCL 11.5 is not supported by Fedore 17, however both are based on red hat. I'll let you know
发表于 2015-8-23 09:18:22 | 显示全部楼层
回复 1# stedd
    caused by your ethernet card name, it should be ethX, not emX
 楼主| 发表于 2015-8-23 09:59:07 | 显示全部楼层
true, i have em1, lo and wlan0. have i to change all interfaces? or only that of my interest?
 楼主| 发表于 2015-8-24 00:20:00 | 显示全部楼层
Alright, Design Compiler starts. Now i would to open gui of Design Vision, but the it doesn't show. Then i wrote export DISPLAY=unix:0 but nothing. I'm running DC on virtual machine. Do you have another trick?
发表于 2015-9-1 19:42:07 | 显示全部楼层
use the vnc appliction connecting into you Linux virtual machine, then start the design_vision, you will see the gui
GMT+8, 2025-12-9 03:27 , Processed in 0.021834 second(s), 6 queries , Gzip On, Redis On.
