查看: 1821|回复: 3
[招聘] Hot job: Senior Verification Engineer-Shanghai
发表于 2015-8-20 14:23:31 | 显示全部楼层 |阅读模式
POSITION LOCATION:Shanghai, China
ROLE AND RESPONSIBILITIES
 Broadly experienced verification engineer to be a key member of methodology/verification team.
 The candidate must have demonstrated success in verification of complex digital ASICs. Will be expected to lead verification on multiple SOCs.
 Responsibilities will include developing verification environment; developing test plans for and verifying the function of ASIC/SOC; hands-on implementation work for every aspect of ASIC/SOC verification.
 The candidate will be working closely with the system group, architects, and design/verification teams implementing the necessary tests to attain high design quality.
 Will also be expected to support pre and post-silicon design validation (reproducing bugs etc.) internally as well as in customer platform.
QUALIFICATIONS AND EDUCATION REQUIREMENTS:
 Excellent critical thinking & problem solving
 Strong verification and advanced debugging skills
 Systems level thinking/awareness of big-picture
 Ability to understand and own complex problems
 Ability to translate design specifications into test requirements
 Ability to identify corner cases and target them in verification
 Ability to structure verification efforts/work break down
 BSEE + 4 or MSEE + 2 plus years of experience in digital ASIC/FPGA/SOC design verification
DESIRED SKILLS/COMPETENCIES
 General knowledge of ASIC design process, digital design, verification tools and techniques
 Design verification experience (developing test plan, test bench, tests, assertions, functional & code coverage, debugging tests and designs)
 Familiarity with design, verification and assertion languages
 Working knowledge of Verilog/System-Verilog is required; UVM is a plus
 Working knowledge of C programming; C++/OO coding principles a plus
 Scripting and automation skills: Unix/Linux shell programming, Perl, Python, etc…
 Experience with industry standard tools and methodologies
 Experience in power management industry a plus.
If you are interested , please send you updated resume to DXi@antal.com.cn or you can contact me with:0512-62621227!
 楼主| 发表于 2015-8-20 18:09:10 | 显示全部楼层
没人理,自己顶!d=====( ̄▽ ̄*)b
 楼主| 发表于 2015-8-21 09:23:11 | 显示全部楼层
真没人理么。。。
 楼主| 发表于 2015-8-24 11:22:06 | 显示全部楼层
GMT+8, 2025-12-27 02:02 , Processed in 0.019049 second(s), 7 queries , Gzip On, Redis On.
