查看: 3704|回复: 7
我在移植linux2.6.14到S3C2410平台上的内核配置文件
发表于 2007-5-13 11:56:59 | 显示全部楼层 |阅读模式
我在移植linux2.6.14S3C2410平台上的内核配置文件。
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.14.1
# Mon Dec  4 21:58:44 2006
CONFIG_ARM=y
CONFIG_MMU=y
CONFIG_UID16=y
CONFIG_RWSEM_GENERIC_SPINLOCK=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
# Code maturity level options
CONFIG_EXPERIMENTAL=y
# CONFIG_CLEAN_COMPILE is not set
CONFIG_BROKEN=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
# General setup
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_POSIX_MQUEUE=y
# CONFIG_BSD_PROCESS_ACCT is not set
CONFIG_SYSCTL=y
# CONFIG_AUDIT is not set
CONFIG_HOTPLUG=y
CONFIG_KOBJECT_UEVENT=y
# CONFIG_IKCONFIG is not set
CONFIG_INITRAMFS_SOURCE=""
# CONFIG_EMBEDDED is not set
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
# CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_SHMEM=y
CONFIG_CC_ALIGN_FUNCTIONS=0
CONFIG_CC_ALIGN_LABELS=0
CONFIG_CC_ALIGN_LOOPS=0
CONFIG_CC_ALIGN_JUMPS=0
# CONFIG_TINY_SHMEM is not set
CONFIG_BASE_SMALL=0
# Loadable module support
CONFIG_MODULES=y
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
CONFIG_OBSOLETE_MODPARM=y
CONFIG_MODVERSIONS=y
# CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_KMOD=y
# System Type
# CONFIG_ARCH_CLPS7500 is not set
# CONFIG_ARCH_CLPS711X is not set
# CONFIG_ARCH_CO285 is not set
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_CAMELOT is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_INTEGRATOR is not set
# CONFIG_ARCH_IOP3XX is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_IXP2000 is not set
# CONFIG_ARCH_L7200 is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
CONFIG_ARCH_S3C2410=y
# CONFIG_ARCH_SHARK is not set
# CONFIG_ARCH_LH7A40X is not set
# CONFIG_ARCH_OMAP is not set
# CONFIG_ARCH_VERSATILE is not set
# CONFIG_ARCH_IMX is not set
# CONFIG_ARCH_H720X is not set
# CONFIG_ARCH_AAEC2000 is not set
# S3C24XX Implementations
# CONFIG_MACH_ANUBIS is not set
# CONFIG_ARCH_BAST is not set
# CONFIG_ARCH_H1940 is not set
# CONFIG_MACH_N30 is not set
CONFIG_ARCH_SMDK2410=y
# CONFIG_ARCH_S3C2440 is not set
# CONFIG_MACH_VR1000 is not set
# CONFIG_MACH_RX3715 is not set
# CONFIG_MACH_OTOM is not set
# CONFIG_MACH_NEXCODER_2440 is not set
CONFIG_CPU_S3C2410=y
# S3C2410 Boot
# S3C2410 Setup
CONFIG_S3C2410_DMA=y
CONFIG_S3C2410_DMA_DEBUG=y
CONFIG_S3C2410_LOWLEVEL_UART_PORT=0
# Processor Type
CONFIG_CPU_32=y
CONFIG_CPU_ARM920T=y
CONFIG_CPU_32v4=y
CONFIG_CPU_ABRT_EV4T=y
CONFIG_CPU_CACHE_V4WT=y
CONFIG_CPU_CACHE_VIVT=y
CONFIG_CPU_COPY_V4WB=y
CONFIG_CPU_TLB_V4WBI=y
# Processor Features
CONFIG_ARM_THUMB=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_DISABLE is not set
# CONFIG_CPU_DCACHE_WRITETHROUGH is not set
# Bus support
CONFIG_ISA=y
CONFIG_ISA_DMA_API=y
# PCCARD (PCMCIA/CardBus) support
# CONFIG_PCCARD is not set
# Kernel Features
# CONFIG_SMP is not set
# CONFIG_PREEMPT is not set
# CONFIG_NO_IDLE_HZ is not set
# CONFIG_ARCH_DISCONTIGMEM_ENABLE is not set
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_DISCONTIGMEM_MANUAL is not set
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
# CONFIG_SPARSEMEM_STATIC is not set
CONFIG_ALIGNMENT_TRAP=y
# Boot options
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_CMDLINE="root=/dev/nfs nfsroot=192.168.1.180:/home/a/g15 ip=192.168.1.45:192.168.1.180:192.168.1.46:255.255.255.0:arm:eth0ff console=ttySAC0,115200 noinitrd init=/linuxrc"
# CONFIG_XIP_KERNEL is not set
# Floating point emulation
# At least one emulation must be selected
CONFIG_FPE_NWFPE=y
# CONFIG_FPE_NWFPE_XP is not set
# CONFIG_FPE_FASTFPE is not set
# Userspace binary formats
CONFIG_BINFMT_ELF=y
CONFIG_BINFMT_AOUT=y
# CONFIG_BINFMT_MISC is not set
# CONFIG_ARTHUR is not set
# Power management options
# CONFIG_PM is not set
# Networking
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_UNIX=y
# CONFIG_NET_KEY is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
CONFIG_IP_ADVANCED_ROUTER=y
CONFIG_ASK_IP_FIB_HASH=y
# CONFIG_IP_FIB_TRIE is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_MULTIPLE_TABLES=y
CONFIG_IP_ROUTE_MULTIPATH=y
CONFIG_IP_ROUTE_MULTIPATH_CACHED=y
# CONFIG_IP_ROUTE_MULTIPATH_RR is not set
# CONFIG_IP_ROUTE_MULTIPATH_RANDOM is not set
# CONFIG_IP_ROUTE_MULTIPATH_WRANDOM is not set
# CONFIG_IP_ROUTE_MULTIPATH_DRR is not set
# CONFIG_IP_ROUTE_VERBOSE is not set
CONFIG_IP_PNP=y
# CONFIG_IP_PNP_DHCP is not set
CONFIG_IP_PNP_BOOTP=y
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE is not set
CONFIG_IP_MROUTE=y
# CONFIG_IP_PIMSM_V1 is not set
# CONFIG_IP_PIMSM_V2 is not set
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_TUNNEL is not set
CONFIG_INET_DIAG=y
CONFIG_INET_TCP_DIAG=y
CONFIG_TCP_CONG_ADVANCED=y
# TCP congestion control
CONFIG_TCP_CONG_BIC=y
CONFIG_TCP_CONG_WESTWOOD=m
CONFIG_TCP_CONG_HTCP=m
# CONFIG_TCP_CONG_HSTCP is not set
# CONFIG_TCP_CONG_HYBLA is not set
# CONFIG_TCP_CONG_VEGAS is not set
# CONFIG_TCP_CONG_SCALABLE is not set
# CONFIG_IPV6 is not set
# CONFIG_NETFILTER is not set
# DCCP Configuration (EXPERIMENTAL)
# CONFIG_IP_DCCP is not set
# SCTP Configuration (EXPERIMENTAL)
# CONFIG_IP_SCTP is not set
# CONFIG_ATM is not set
# CONFIG_BRIDGE is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_NET_DIVERT is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
# CONFIG_NET_SCHED is not set
# CONFIG_NET_CLS_ROUTE is not set
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_IRDA is not set
# CONFIG_BT is not set
# CONFIG_IEEE80211 is not set
# Device Drivers
# Generic Driver Options
CONFIG_STANDALONE=y
# CONFIG_PREVENT_FIRMWARE_BUILD is not set
CONFIG_FW_LOADER=y
# CONFIG_DEBUG_DRIVER is not set
# Memory Technology Devices (MTD)
CONFIG_MTD=y
# CONFIG_MTD_DEBUG is not set
CONFIG_MTD_CONCAT=y
CONFIG_MTD_PARTITIONS=y
# CONFIG_MTD_REDBOOT_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_CHAR=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=y
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_GEN_PROBE=y
# CONFIG_MTD_CFI_ADV_OPTIONS is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
CONFIG_MTD_CFI_INTELEXT=y
CONFIG_MTD_CFI_AMDSTD=y
CONFIG_MTD_CFI_AMDSTD_RETRY=0
# CONFIG_MTD_CFI_STAA is not set
CONFIG_MTD_CFI_UTIL=y
CONFIG_MTD_RAM=y
CONFIG_MTD_ROM=y
# CONFIG_MTD_ABSENT is not set
# CONFIG_MTD_OBSOLETE_CHIPS is not set
# CONFIG_MTD_XIP is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PHYSMAP is not set
# CONFIG_MTD_ARM_INTEGRATOR is not set
CONFIG_MTD_S3C2410=y
# CONFIG_MTD_EDB7312 is not set
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_SLRAM is not set
CONFIG_MTD_PHRAM=y
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLKMTD is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOC2000 is not set
# CONFIG_MTD_DOC2001 is not set
# CONFIG_MTD_DOC2001PLUS is not set
# NAND Flash Device Drivers
CONFIG_MTD_NAND=y
# CONFIG_MTD_NAND_VERIFY_WRITE is not set
CONFIG_MTD_NAND_IDS=y
CONFIG_MTD_NAND_S3C2410=y
# CONFIG_MTD_NAND_S3C2410_DEBUG is not set
# CONFIG_MTD_NAND_S3C2410_HWECC is not set
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_NAND_NANDSIM is not set
# Parallel port support
# CONFIG_PARPORT is not set
# Plug and Play support
# CONFIG_PNP is not set
# Block devices
# CONFIG_BLK_DEV_XD is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=y
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
CONFIG_BLK_DEV_NBD=y
CONFIG_BLK_DEV_RAM=y
CONFIG_BLK_DEV_RAM_COUNT=16
CONFIG_BLK_DEV_RAM_SIZE=16384
CONFIG_BLK_DEV_INITRD=y
# CONFIG_CDROM_PKTCDVD is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
# CONFIG_IOSCHED_AS is not set
# CONFIG_IOSCHED_DEADLINE is not set
CONFIG_IOSCHED_CFQ=y
# CONFIG_ATA_OVER_ETH is not set
# ATA/ATAPI/MFM/RLL support
# CONFIG_IDE is not set
# SCSI device support
# CONFIG_RAID_ATTRS is not set
# CONFIG_SCSI is not set
# Multi-device support (RAID and LVM)
# CONFIG_MD is not set
# Fusion MPT device support
# CONFIG_FUSION is not set
# IEEE 1394 (FireWire) support
# CONFIG_IEEE1394 is not set
# I2O device support
# Network device support
CONFIG_NETDEVICES=y
# CONFIG_DUMMY is not set
# CONFIG_BONDING is not set
# CONFIG_EQUALIZER is not set
# CONFIG_TUN is not set
# ARCnet devices
# CONFIG_ARCNET is not set
# PHY device support
# CONFIG_PHYLIB is not set
# Ethernet (10 or 100Mbit)
CONFIG_NET_ETHERNET=y
CONFIG_MII=y
# CONFIG_NET_VENDOR_3COM is not set
# CONFIG_LANCE is not set
# CONFIG_NET_VENDOR_SMC is not set
# CONFIG_SMC91X is not set
# CONFIG_DM9000 is not set
# CONFIG_NET_VENDOR_RACAL is not set
# CONFIG_AT1700 is not set
# CONFIG_DEPCA is not set
# CONFIG_HP100 is not set
CONFIG_NET_ISA=y
# CONFIG_E2100 is not set
# CONFIG_EWRK3 is not set
# CONFIG_EEXPRESS is not set
# CONFIG_EEXPRESS_PRO is not set
# CONFIG_HPLAN_PLUS is not set
# CONFIG_HPLAN is not set
# CONFIG_LP486E is not set
# CONFIG_ETH16I is not set
CONFIG_NE2000=y
# CONFIG_ZNET is not set
# CONFIG_SEEQ8005 is not set
# CONFIG_NET_PCI is not set
# Ethernet (1000 Mbit)
# Ethernet (10000 Mbit)
# Token Ring devices
# CONFIG_TR is not set
# Wireless LAN (non-hamradio)
# CONFIG_NET_RADIO is not set
# Wan interfaces
# CONFIG_WAN is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
# CONFIG_SHAPER is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# ISDN subsystem
# CONFIG_ISDN is not set
# Input device support
CONFIG_INPUT=y
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=640
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=480
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_TSDEV=y
CONFIG_INPUT_TSDEV_SCREEN_X=640
CONFIG_INPUT_TSDEV_SCREEN_Y=480
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_SUNKBD is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_NEWTON is not set
CONFIG_INPUT_MOUSE=y
CONFIG_MOUSE_PS2=y
# CONFIG_MOUSE_SERIAL is not set
# CONFIG_MOUSE_INPORT is not set
# CONFIG_MOUSE_LOGIBM is not set
# CONFIG_MOUSE_PC110PAD is not set
# CONFIG_MOUSE_VSXXXAA is not set
# CONFIG_INPUT_JOYSTICK is not set
CONFIG_INPUT_TOUCHSCREEN=y
# CONFIG_TOUCHSCREEN_GUNZE is not set
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_INPUT_MISC is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_VT=y
CONFIG_VT_CONSOLE=y
CONFIG_HW_CONSOLE=y
# CONFIG_SERIAL_NONSTANDARD is not set
# Serial drivers
# CONFIG_SERIAL_8250 is not set
# Non-8250 serial port support
CONFIG_SERIAL_S3C2410=y
CONFIG_SERIAL_S3C2410_CONSOLE=y
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# IPMI
# CONFIG_IPMI_HANDLER is not set
# Watchdog Cards
# CONFIG_WATCHDOG is not set
# CONFIG_NVRAM is not set
# CONFIG_RTC is not set
CONFIG_S3C2410_RTC=y
# CONFIG_DTLK is not set
# CONFIG_R3964 is not set
# Ftape, the floppy tape device driver
CONFIG_RAW_DRIVER=y
CONFIG_MAX_RAW_DEVS=256
# TPM devices
# I2C support
# CONFIG_I2C is not set
# Hardware Monitoring support
CONFIG_HWMON=y
# CONFIG_HWMON_VID is not set
# CONFIG_HWMON_DEBUG_CHIP is not set
# Misc devices
# Multimedia Capabilities Port drivers
# Multimedia devices
# CONFIG_VIDEO_DEV is not set
# Digital Video Broadcasting Devices
# CONFIG_DVB is not set
# Graphics support
CONFIG_FB=y
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
CONFIG_FB_SOFT_CURSOR=y
# CONFIG_FB_MACMODES is not set
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# CONFIG_FB_S1D13XXX is not set
CONFIG_FB_S3C2410=y
# CONFIG_FB_S3C2410_DEBUG is not set
CONFIG_FB_VIRTUAL=y
# Console display driver support
# CONFIG_VGA_CONSOLE is not set
# CONFIG_MDA_CONSOLE is not set
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# Logo configuration
CONFIG_LOGO=y
# CONFIG_LOGO_LINUX_MONO is not set
CONFIG_LOGO_LINUX_VGA16=y
# CONFIG_LOGO_LINUX_CLUT224 is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Sound
# CONFIG_SOUND is not set
# USB support
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
# CONFIG_USB is not set
# USB Gadget Support
# CONFIG_USB_GADGET is not set
# MMC/SD Card support
# CONFIG_MMC is not set
# File systems
CONFIG_EXT2_FS=y
# CONFIG_EXT2_FS_XATTR is not set
# CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
# CONFIG_EXT3_FS_XATTR is not set
CONFIG_JBD=y
# CONFIG_JBD_DEBUG is not set
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_FS_POSIX_ACL is not set
# CONFIG_XFS_FS is not set
# CONFIG_MINIX_FS is not set
CONFIG_ROMFS_FS=y
CONFIG_INOTIFY=y
# CONFIG_QUOTA is not set
CONFIG_DNOTIFY=y
CONFIG_AUTOFS_FS=y
CONFIG_AUTOFS4_FS=y
# CONFIG_FUSE_FS is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
# CONFIG_MSDOS_FS is not set
# CONFIG_VFAT_FS is not set
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_DEVFS_FS=y
CONFIG_DEVFS_MOUNT=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_HUGETLBFS is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_RAMFS=y
# CONFIG_RELAYFS_FS is not set
# Miscellaneous filesystems
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_JFFS_FS=y
CONFIG_JFFS_FS_VERBOSE=0
# CONFIG_JFFS_PROC_FS is not set
CONFIG_JFFS2_FS=y
CONFIG_JFFS2_FS_DEBUG=0
# CONFIG_JFFS2_FS_WRITEBUFFER is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_RTIME=y
# CONFIG_JFFS2_RUBIN is not set
CONFIG_CRAMFS=y
# CONFIG_VXFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# Network File Systems
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
# CONFIG_NFS_V3_ACL is not set
# CONFIG_NFS_V4 is not set
# CONFIG_NFS_DIRECTIO is not set
# CONFIG_NFSD is not set
CONFIG_ROOT_NFS=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
# CONFIG_RPCSEC_GSS_KRB5 is not set
# CONFIG_RPCSEC_GSS_SPKM3 is not set
# CONFIG_SMB_FS is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
# CONFIG_9P_FS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
# CONFIG_MSDOS_PARTITION is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_EFI_PARTITION is not set
# Native Language Support
# CONFIG_NLS is not set
# Profiling support
# CONFIG_PROFILING is not set
# Kernel hacking
# CONFIG_PRINTK_TIME is not set
CONFIG_DEBUG_KERNEL=y
# CONFIG_MAGIC_SYSRQ is not set
CONFIG_LOG_BUF_SHIFT=14
CONFIG_DETECT_SOFTLOCKUP=y
# CONFIG_SCHEDSTATS is not set
# CONFIG_DEBUG_SLAB is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_SPINLOCK_SLEEP is not set
# CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_FS is not set
CONFIG_FRAME_POINTER=y
CONFIG_DEBUG_USER=y
# CONFIG_DEBUG_WAITQ is not set
# CONFIG_DEBUG_ERRORS is not set
CONFIG_DEBUG_LL=y
# CONFIG_DEBUG_ICEDCC is not set
CONFIG_DEBUG_S3C2410_PORT=y
CONFIG_DEBUG_S3C2410_UART=0
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY is not set
# Cryptographic options
# CONFIG_CRYPTO is not set
# Hardware crypto devices
# Library routines
# CONFIG_CRC_CCITT is not set
# CONFIG_CRC16 is not set
CONFIG_CRC32=y
CONFIG_LIBCRC32C=y
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
发表于 2007-5-13 12:40:54 | 显示全部楼层
够详细的,谢谢!
发表于 2007-12-20 00:39:58 | 显示全部楼层
感謝大大
感謝大大
发表于 2008-1-9 14:03:38 | 显示全部楼层
非常感谢!
发表于 2014-4-9 13:14:17 | 显示全部楼层
深圳市爱欣文科技有限公司是台湾联杰国际(DAVICOM) 股份有限公司﹑台湾磁威(MAGCOM)公司在中国大陆的授权代理商,供应DAVICOM全系列產品DM9000EP DM9161AEP DM9000AEP DM9601EP DM9161EP DM9620 DM9006EP DM8806AFP 及MAGCOM全系列产品:HS12369 HS12361 HS9001 HS9016 .....原装正品,供货稳定价格优惠,欢迎大家咨询订购。我们不仅负责销售,更加注重的是产品的推广和服务;
贵公司在开发产品时,我们可以免费为贵公司提供:
1)芯片的数据手册,原理图.
2)Layoeut PCB(布板指南).
3) 中文编程指南
4)Drive.   ps:Linux drive/wince drive/vxworks/neucleus/.c/csos
5)如遇技术问题,原厂FAE免费提供技术支持。
[联系我们]:如需开发资料的请与我联系,谢谢!
李 sir:027-87880506,027-87207595
Mobile:13469977252
E-mail:baron_li@axwdragon.com
MSN:baron_li1@hotmail.com
QQ:1596190376
发表于 2014-4-24 19:12:46 | 显示全部楼层
可是你说可能。。。。。。。。。。。。。。。。。。
发表于 2014-10-9 13:18:14 | 显示全部楼层
顶。。。。。。。。。。。。。。。
发表于 2015-1-16 04:58:04 | 显示全部楼层
非常感谢!
GMT+8, 2025-12-14 10:47 , Processed in 0.074071 second(s), 8 queries , Gzip On, Redis On.
