查看: 2186|回复: 0
[求助] calibreview,post- layout simulation,error
发表于 2015-8-6 10:24:51 | 显示全部楼层 |阅读模式
用calibre+cadence进行后仿真,
calibre PEX提取寄生参数,
LVS通过了,
并且生成了calibre view,用此view来进行后仿真,一直报错,如下所示。
Error found by spectre in `mphamacro':`I1_M27', in `P183_2_4227A_calibre':`I1',
        during hierarchy flattening.
    I1.I1_M27.dsbf_pa of mphamacro: Value of `perim' should be greater than or
        equal to zero.
Internal error found in spectre in `mphamacro':`I1_M27', in
        `P183_2_4227A_calibre':`I1', during hierarchy flattening, during
        circuit read-in.  Please run `getSpectreFiles' or send the netlist, the
        spectre log file, the behavioral model files, and any other information
        that can help identify the problem to support@cadence.com.
    Error detected in file `ipsm.c' at line 219.
    Assertion failed.
一直查不出原因,望不吝指教。
GMT+8, 2025-12-25 21:36 , Processed in 0.019172 second(s), 6 queries , Gzip On, Redis On.
