查看: 1627|回复: 2
[招聘] 招聘验证工程师
发表于 2015-8-5 15:04:47 | 显示全部楼层 |阅读模式
感兴趣可发简历至 cissy_pq@163.com
SeniorVerification Engineer
Common:
1)    Familiarwith system Verilog and UVM methodology
2)    Familiarwith UNIX/Linux shell
3)    Familiarwith Perl script
4)    Providetest plan basing on the design spec
5)    Setupthe module level and chip level DV environment
6)    RTLsimulation and netlist with timing simulation
7)    Implementthe test cases basing test plan, and provide the test coverage
8)    Workwith design team to repeat the failure case and find out root cause
Position 1:
1)    Familiarwith the PCIe and NVMe protocol
2)    Familiarwith SATA protocol
3)    Familiarwith the NAND behavior and ONFI protocol
4)    Knowledgeon ARM9 CPU core and AHB bus
5)    Knowledgeon DDR3/LPDDR2
6)    Knowledgeon AES and BCH ECC will be a plus
Position 2:
1)    Familiarwith eMMC protocol
2)    Familiarwith the NAND behavior and ONFI protocol
3)    Knowledgeon BCH ECC
Postion 3:
1)    Familar with mixed signal design and/orverification
Postion 4:
1) Familar with one of the areas below:
a. ARM A9 subsystem
b. DDR3/DDR4
c. USB 3.0
d. SATA
e. PCIe
f. Ethernet
work inShanghai or Beijing
发表于 2015-8-5 16:34:29 | 显示全部楼层
实习生要吗
 楼主| 发表于 2015-8-5 16:43:17 | 显示全部楼层
回复 2# xzw_e
    我们需要有经验的工程师,谢谢!
GMT+8, 2025-12-30 09:14 , Processed in 0.021466 second(s), 6 queries , Gzip On, Redis On.
