查看: 2441|回复: 0
[求助] 英语翻译
发表于 2015-7-21 11:21:19 | 显示全部楼层 |阅读模式
在看一篇Flash存储器(型号MX25L3205DM2I)的英文手册,里面有几句话,不知是何意,用了翻译软件,结果翻译出来的结果也让人搞不明白,希望懂的高手不吝赐教:
(1)If the eight least significant address bits (A7-A0) are not all 0, all transmitted data which goes beyond the end of the current page are programmed from the start address if the same page (from the address whose 8 least significant address bits (A7-A0) are all 0). (datasheet的COMMAND DESCRIPTION第12点Page Program第一段第2行)
    (2) The first byte data will be programmed to the initial address range with A0=0 and second byte
data with A0=1.(datasheet 的 COMMAND DESCRIPTION第13点Continuously program mode第二段第4行)
    (3)the CS# goes low will drive out the RY/BY# status on SO. (datasheet 的 COMMAND DESCRIPTION第13点Continuously program mode最后一 段倒数第4行)
GMT+8, 2025-12-31 02:55 , Processed in 0.016509 second(s), 6 queries , Gzip On, Redis On.
