查看: 7352|回复: 8
IC616 install error, ask for help
发表于 2015-7-6 10:41:47 | 显示全部楼层 |阅读模式
new debian 7.8.0 virtual machine. so i need to type in english..
i installed IC616 by iscape 04.23.
and .bashrc file's content:
export OA_HOME=/home/chpl/cadence/installs/IC616/oa_v22.43.018
export CDS_ROOT=/home/chpl/cadence/installs/IC616
export CDS_LIC_FILE=5288@yebian
but it don't work normally and give me these:
WARNING: HOST <yebian> DOES NOT APPEAR TO BE A CADENCE SUPPORTED LINUX CONFIGURATION.
         For More Info,  Please Run '<cdsroot>/tools.lnx86/bin/checkSysConf' <productId>.
virtuoso:   ERROR: The command /home/chpl/cadence/installs/IC616/oa_v22.43.018/bin/sysname returned an error status:
                            unknown
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
it takes me a whole day and i don't want another..
plus1:
IC616 patched
tried http://blog.sina.com.cn/s/blog_4ebc3d6c0102vbva.html, http://bbs.eetop.cn/viewthread.php?tid=400786&amp;extra=&page=1
发表于 2015-7-6 19:57:23 | 显示全部楼层
change $install_pat/tools/bin/.preHostEnvCheck
发表于 2015-7-6 21:08:19 | 显示全部楼层
It looks like IC616 does not support the debian OS, RHEL 5/6 is recommended.
发表于 2015-7-7 18:05:56 | 显示全部楼层
please check out "/etc/hosts" file.
127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4 devian
::1         localhost localhost.localdomain localhost6 localhost6.localdomain6 devian
192.168.200.103 devian
发表于 2015-7-8 08:12:52 | 显示全部楼层
试试
export OA_UNSUPPORTED_PLAT=linux_rhel40_gcc44x
或者
export OA_UNSUPPORTED_PLAT=linux_rhel50_gcc44x
 楼主| 发表于 2015-7-11 11:56:14 | 显示全部楼层
toad, stokley, young9999, YULONGUTK
thanks you all!!
sorry for reply lately.
I changed platform to fedora 22, redownload IC616, added
export OA_UNSUPPORTED_PLAT="linux_rhel50_gcc44x"
export CDS_LIC_FILE="5288@yedora"
export OA_HOME="/home/chpl/cadence/installs/IC616/oa_v22.43.018"
to my .bashrc, installed some library and launched it..
then I saw the possibly last error
*ERROR* (DB-320001): Unable to get the Cadence(R) Design Framework II license feature "111".
I had tried re-patch the installation, which didn't work.
the another method is edit license.dat file, but I can't find it...
 楼主| 发表于 2015-7-11 11:58:12 | 显示全部楼层
why does my reply not display immediately?
I found the post I sent was lost.......
re-post below
toad, stokley, young9999, YULONGUTK,
thanks you all for helping me. it realy works.
I am sorry for reply so lately.
I changed platform to Fedora 22, re-download IC616 and installed, edited my .bashrc file, patched,and installed some library files.
I thought I am almost finish, but there is an error block me:
I tried re-patching installation, whereas no effect.....
thanks again for your voluntary help~~ ..
发表于 2015-7-11 23:45:00 | 显示全部楼层
回复 7# chpl
Hi chpl,
    1. Please check the license manager has started first?
    2. After then, try the attached patch code of the following posts:
        --> cadencex64_patch.rar : http://bbs.eetop.cn/thread-373895-1-1.html
        --> cadence_64bit_patch_jcad.rar : http://bbs.eetop.cn/viewthread.php?tid=389580
Regards,
Stokley
 楼主| 发表于 2015-7-12 09:49:53 | 显示全部楼层
回复 8# stokley
thanks dude~
i changed .bashrc file's content
to
export LM_LICENSE_FILE=$CDS_HOME/IC616/share/license/license.dat
and the license.dat file is based on this post(http://bbs.eetop.cn/thread-470308-1-1.html)
after delete USER SERVER line and ############ line in the license file and launched lic_config in IC616/share/license folder some times.
it is no error now~~~~~~
GMT+8, 2025-12-30 08:46 , Processed in 0.019526 second(s), 5 queries , Gzip On, Redis On.
