查看: 2576|回复: 2
[求助] charge pump
发表于 2015-7-2 14:42:35 | 显示全部楼层 |阅读模式
一中全PMOS 的charge pump 。paper上说下面这种结构会更好,但仿真结构显示不是这样的,请大神指点。
发表于 2015-7-6 02:53:32 | 显示全部楼层
The choice of available transistor type and technology determine the efficiency of design from architecture point of view. Then engineering could affect performance quite significant. You can not rely on the paper since there are so many dependency.
Check out Vt, Lmin and backward leakage current in your sim.
 楼主| 发表于 2015-7-8 14:06:04 | 显示全部楼层
回复 2# jake10000
谢谢,会对管子的性能进行详细的仿真。
GMT+8, 2025-11-27 03:23 , Processed in 0.017660 second(s), 6 queries , Gzip On, Redis On.
