查看: 6514|回复: 18
“design a fully differential amplifier”大家看看有没有什么参考资料?
发表于 2004-12-9 21:14:00 | 显示全部楼层 |阅读模式
The design specifications of the amplifier are:
Supply VDD                      5V
Dynamic range at output (DR)    >=70dB
Closed-loop gain                    2
Feedback capacitance              0.5pF
Settling accuracy               <=0.05%
Settling time ts                  <=30ns
Power consumption              as low as possible
You must design the entire circuit including the CMFB and biasing network with the exception of one independent reference current source with one terminal tied to either ground or VDD. You need to add a 3pF capacitance as a load.
发表于 2004-12-10 04:02:00 | 显示全部楼层
我这里有一篇文章,你可以看看
3_773_1.pdf
399.89 KB, 下载次数: 73 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2004-12-10 17:44:08 | 显示全部楼层
多谢!!^_^
发表于 2007-9-5 19:10:25 | 显示全部楼层
谢谢哈哈
发表于 2008-1-16 09:31:41 | 显示全部楼层
全差分的slew rate 和 settle time 该怎么仿真?谁有比较好的建议?
发表于 2008-1-16 09:35:44 | 显示全部楼层
还有CMFB环路的稳定性仿真.谁有比较好的建议。
发表于 2008-1-29 00:31:49 | 显示全部楼层
如果CMFB没有设置好,会怎么影响电路?如何确定CMFB是比较合适的?
发表于 2008-2-24 12:58:16 | 显示全部楼层
thankyou very much
发表于 2008-2-24 12:59:15 | 显示全部楼层
good paper
发表于 2009-10-1 16:30:24 | 显示全部楼层
good thanks
GMT+8, 2025-12-20 16:13 , Processed in 0.026514 second(s), 8 queries , Gzip On, Redis On.
