查看: 3346|回复: 7
Design on Power-Rail ESD Clamp Circuit for 3.3V in a 130nm(Ming-Dou Ker)
发表于 2007-5-5 10:24:26 | 显示全部楼层 |阅读模式
Design on Power-Rail ESD Clamp Circuit for 3.3-V
I/O Interface by Using Only 1-V/2.5-V Low-Voltage
Devices in a 130-nm CMOS Process
Ming-Dou Ker, Senior Member, IEEE, Wen-Yi Chen, and Kuo-Chun Hsu, Member, IEEE
Abstract—A new power-rail electrostatic discharge (ESD) clamp
circuit for application in 3.3-V mixed-voltage input–output (I/O)
interface is proposed and verified in a 130-nm 1-V/2.5-V CMOS
process. The devices in this power-rail ESD clamp circuit are all
1-V or 2.5-V low-voltage nMOS/pMOS devices, which are specially
designed without suffering the gate-oxide reliability issue under
3.3-V I/O interface applications. A special ESD detection circuit
realized with the low-voltage devices is designed and added in the
power-rail ESD clamp circuit to improve ESD robustness of ESD
clamp devices by substrate-triggered technique. The experimental
results verified in a 130-nm CMOS process have proven the excellent
effectiveness of this new proposed power-rail ESD clamp circuit.
Index Terms—Electrostatic discharge (ESD), ESD protection
circuit, high-voltage tolerant, power-rail ESD clamp circuit,
Ker_WYChen_KCHsu_TCAS1_Oct_2006.pdf
714.78 KB, 下载次数: 181 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-4-28 23:05:52 | 显示全部楼层
又见到这个作者的文章 ,顶之!
发表于 2011-7-13 02:52:54 | 显示全部楼层
thanks
发表于 2011-8-17 16:42:55 | 显示全部楼层
thank you for your sharing!
发表于 2011-12-9 14:50:13 | 显示全部楼层
thanks for sharing
发表于 2012-10-19 16:15:26 | 显示全部楼层
kankan
发表于 2013-4-2 22:18:22 | 显示全部楼层
下载了,谢谢分享
发表于 2014-1-19 04:15:07 | 显示全部楼层
3kyyyyyyyyyyyyyyyyyyy
GMT+8, 2025-12-1 03:09 , Processed in 0.465133 second(s), 7 queries , Gzip On, Redis On.
