查看: 2836|回复: 6
[求助] need paper 300 V integrated charge pump
发表于 2015-6-11 06:58:55 | 显示全部楼层 |阅读模式
300 V integrated charge pump for lab on chip application
In this paper we demonstrate a fully integrated 300 V low current charge pump design which has been manufactured using Teledyne DALSA's triple well 800 nm high voltage IC process. This charge pump is powered by a 5 V supply, drawing less than 2% of the USB 2.0 maximum current, thus enabling future low-cost compact point-of-care diagnostic devices that would be connected to and powered off a laptop or smart phone. We have demonstrated this device to be capable of producing 300 V while sourcing up to 10 μA.
how to on-die 300v charge pump design ??
发表于 2015-6-12 09:08:05 | 显示全部楼层
回复 1# peterlin2010
    06968182.pdf (961.32 KB , 下载次数: 27 )
请查收。
发表于 2015-6-12 09:49:32 | 显示全部楼层
看看。。。
 楼主| 发表于 2015-6-12 20:53:46 | 显示全部楼层
thank you
    最近看些 charge pump paper ..想知道一般低压下如何 做高压
charge pump 须要 cap ..一般能耐压都是 drain ..gate 除非後厚oxide 1000A
可能使用 40v process ,
300v ? 多厚oxide ?
发表于 2016-6-23 17:24:12 | 显示全部楼层
THANK YOU
发表于 2016-6-23 19:54:47 | 显示全部楼层
一看就是想做同步整流的。
 楼主| 发表于 2016-6-24 00:24:12 | 显示全部楼层
GMT+8, 2025-12-28 16:19 , Processed in 0.026846 second(s), 7 queries , Gzip On, Redis On.
