查看: 2672|回复: 4
[招聘] Synopsys武汉急招 数字IP前端验证工程师
发表于 2015-4-23 15:42:29 | 显示全部楼层 |阅读模式
接收简历地址:zhuqin.tang@synopsys.com
Job Title: 数字IP前端验证工程师
The candidate will be part of the Solutions Group at our new Design Center at Wuhan, China. This is a Technical Individual Contributor role and offers challenges to work in a multi-site environment on technically challenging IP Cores in the Verification domain. The position offers learning and growth opportunities in Synopsys’ new Design Center at Wuhan.
Job Responsibilities
-Be an individual contributor in the Verification Tasks – coding of TE, debug, verification coverage improvement, etc.
-May need to understand Standard Specifications/ the functional specifications/ feature enhancements for the product and create micro-architecture and detailed design documents for some of the components of small complexity modules in the Test Environment for the DesignWare family of synthesizable cores in protocol areas such some interface IP.
-Creates deliverables which do not require close review or supervision by a Senior Technical Lead.
-May learn to do technical review of TE Code of small complexity.
-The candidate should be able to analyze the coverage metrics and improve them with definition of additional test cases in CRV environment, at least for small/ medium complexity features of the protocol/ product specs.
-The candidate will work in a project and team oriented environment with teams spread across multiple sites, worldwide.
Must have relevant experience in the following areas:
-Verification of IP Cores or SoC Designs for Set Top Boxes, Mobile handsets, Smart Devices, etc.
-Knowledge of one or more of interface IP protocols is pluse.
-Hands on experience with creating detailed design of certain simple components of Test Environment from Functional Specifications/ Test Environment Specifications. The TE must have used methodologies such as UVM/ VMM.
-Hands on experience with System Verilog/ VERA coding and Simulation tools; Knowledge of C++/ OOPs Concepts
-Experience with Perforce or similar revision control environment
-Knowledge of Perl/Shell scripts.
欢迎关注Synopsys微信公共号:新思科技招聘 ,了解最新热招职位!
发表于 2015-4-26 23:20:50 | 显示全部楼层
请问,Synopsis武汉招后端工程师吗?
 楼主| 发表于 2015-4-30 16:51:59 | 显示全部楼层
回复 2# jiangchen
   目前武汉没有,上海有后端的职位哦
发表于 2015-4-30 16:54:49 | 显示全部楼层
好公司 好职位!
 楼主| 发表于 2018-12-18 14:34:29 | 显示全部楼层
update
GMT+8, 2025-12-14 05:10 , Processed in 0.017383 second(s), 6 queries , Gzip On, Redis On.
