查看: 6508|回复: 3
[求助] windriver扫描PCIE设备出现问题,打不开设备
发表于 2015-3-24 16:16:54 | 显示全部楼层 |阅读模式
Found 1 matching device [ Vendor ID 0x10EE, Device ID 0x7028 ]:
1. Vendor ID: 0x10EE, Device ID: 0x7028
    Memory range [BAR 0]: base 0xE1000000, size 0x100000
    Interrupt: IRQ 6
    Interrupt Options (supported interrupts):
        Level-Sensitive Interrupt
DeviceOpen: Failed opening a handle to the device: Failed opening a WDC device h
andle. Error 0x2000000e - Resource overlap
PCIE_64 main menu
1. Scan PCI bus
2. Find and open a PCIE_64 device
99. Exit
Enter option:
请各位大神告诉我什么原因?明明用windriver软件可以对memory进行读写,为什么产生的代码不行?
 楼主| 发表于 2015-3-24 16:50:30 | 显示全部楼层
注释一下,我用的是VC707
 楼主| 发表于 2015-3-26 11:19:00 | 显示全部楼层
找到原因了,原来是我一直开着windriver,导致其一直占用改设备,关了它就可以了
发表于 2023-12-15 13:56:11 | 显示全部楼层
感谢楼主,我也还在奇怪为啥呢,看到你的帖子,豁然开朗
GMT+8, 2025-9-13 04:47 , Processed in 0.016406 second(s), 7 queries , Gzip On, Redis On.
