查看: 1433|回复: 1
[招聘] Cadence招聘资深模拟电路版图设计工程师
发表于 2015-2-27 17:49:38 | 显示全部楼层 |阅读模式
Title: Seniordesign engineer-AMS
Location SH
更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you haveinterest, PLS send your update CV to zhangyl@cadence.com
Title: Senior designengineer-AMS
Position Description:
•Skillful capable of physical design of Analog and mixedsignal area: Matching sense from transistor, Resistor and capacitor, Power andGround coupling, Signal path from Differential pairs, etc
•Proficientwith Cadence layout tools specifically Virtuoso XL and Assura (Cadence 6.1experience a plus)
•Experiencein 65 nm and below analog CMOS layout, verification (DRC, LVS), and topintegrated tapeout to foundry
•Abilityto coordinate with the other analog IC circuit layout,  ensuring robust, efficient, consistent andsuccessful delivery of analog IC circuit layout.
•Fundamentalunderstanding of IC design technology and process/methodology
•Skilledin Analog IC top level chip assembly including floorplanning and block layout
•Dedicatedexperience on key macros is prefered: SerDes, High speed/high resolution DataConverters; High Speed PLL's; Low Noise Design;
•Hands-onexperience conducting DRC/LVS analysis and recommending appropriate solutions
•Solidunderstanding of IC design technology and process/methodology in AMS layout
PositionRequirements:
1. BSEE degree with >3+ years of applicable experience inadvanced analog and mixed signal design industry.
2. Essential that the individual demonstrates strongcommunication, verbal and written, and project management skills. Requires verygood communication skills in English and Chinese.
发表于 2015-2-27 23:18:24 | 显示全部楼层
内容来看看
GMT+8, 2025-12-27 16:25 , Processed in 0.012658 second(s), 4 queries , Gzip On, Redis On.
