查看: 4810|回复: 5
求ION ITM 2015会议论文光盘
发表于 2015-2-18 03:56:09 | 显示全部楼层 |阅读模式
同时继续求2014年的ITM
 楼主| 发表于 2015-4-8 04:48:50 | 显示全部楼层
TITLE        AUTHOR        PAGES
Analysis, Modelling and Mitigation of Cross-Rate Interference in eLoran        J. Safar, P. Williams, A. Grant, F. Vejrazka        1 - 26
eLoran Initial Operational Capability in the United Kingdom – First Results        Gerard Offermans, Erik Johannessen, Stephen Bartlett, Charles Schue, Andrei Grebnev, Martin Bransby, Paul Williams, Chris Hargreaves        27 - 39
eDME On Air: Design, Implementation, and Flight-Test Demonstration        Wouter Pelgrum, Kuangmin Li, Adam Naab-Levy, Achim Soelter, George Weida, Arthur Helwig        40 - 61
The JAGER Project: GPS Jammer Hunting with a Multi-Purpose UAV Test Platform        James Spicer, Adrien Perkins, Louis Dressel, Mark James, Yu-Hsuan Chen, David S. De Lorenzo, Per Enge        62 - 70
Techniques to Provide Resilient Alternative Positioning, Navigation, and Timing (APNT) Using Automatic Dependent Surveillance - Broadcast (ADS-B) Ground Stations        Sherman Lo, Yu Hsuan Chen, Per Enge, Mitch Narins        71 - 83
The Combined use of Doppler Observation and DTOA Measurement of 1090 MHz ADS-B Signals for Wide Area Multilateration        Jason Guo, Shau-Shiun Jan        84 - 93
Development of a Jammer Localization System for Precise Landing        D. W. Lim, J. M. Kang, M. B.  Heo        94 - 102
A Human-Centered Approach to Automated Ground Route Navigation        Megan L. Mitchell, Andrea K. Webb, Emily Vincent, Laura Major, Christopher D. Abbott, Randy L. Milbert        103 - 113
Event Identification & Recording for Scintillation Monitoring Stations        James T. Curran, Michele Bavaro, Aiden Morrison, Joaquim Fortuny        114 - 122
A Centralized Approach to Pedestrian Localization Using Multiple Odometry Sources        J. Daniel Pierce, David M. Bevly        123 - 128
Manual Optical Attitude Re-initialization for a Crew Vehicle in Space        Christopher J. Gioia, Joshua D. Gerhard, John A. Christian        129 - 136
VBOC2(alpha,1-alpha) Generalized Multidimensional Geolocation Modulation Waveforms        Ilir F. Progri        137 - 148
Position Accuracy Enhancements with the Next Generation GPS System        Janaki R. Potukuchi, Edward J. Fernandez, Kazuma Gunning        149 - 154
Performance Evaluation of the Early CNAV Navigation Message        P. Steigenberger, O. Montenbruck, U. Hessels        155 - 163
Combining L1 Signals for Improved Sensitivity        Yu Hsuan Chen, Sherman Lo, Per Enge, Dennis Akos        164 - 172
A New Choice of Spreading Codes for Satellite Navigation System        Xuan Xia, Jiaolong Wei, Zuping Tang, Jianfeng Shi, Jingling Li        173 - 178
Requirements Analysis of LDPC Code for C-band High Precision Wide Area Differential GNSS Applications        Jing Ke, Xiaochun Lu, Xue Wang, Xiaofei Chen        179 - 184
IRNSS Orbit Determination and Broadcast Ephemeris Assessment        O. Montenbruck, P. Steigenberger, S. Riley        185 - 193
VBOC2(alpha,1-alpha) ACF Pure Signal Optimization        Ilir F. Progri        194 - 206
Advanced Monitoring Technique to Strengthen the Performance of Maritime DGPS        Miyoung Shin, Jaeyoung Go, Younghoon Han, Kiyeol Seo, Deukjae Cho        207 - 212
Navigation Augmentation in Urban Area with Pseudolite Equipped High Altitude Long Endurance UAV        O-Jong Kim, Minwoo Choi, Sunkyoung Yu, Heekwon No, Hyojeong Seok, Donghwan Yoon, Byungwoon Park, Changdon Kee, Cheolkyu Jee        213 - 222
Slant Range Analysis and Compensation of Radar Altimeter Flight Test Data        Philip Spiegel, Michael Kriegel, Johann Dambeck, Florian Holzapfel        223 - 233
Requirements for Resilient PNT        Nick Ward, Martin Bransby        234 - 238
Terrain Reference Navigation Using SIFT Features in LiDAR Range-Based Data        Matthew T. Leines, John F. Raquet        239 - 250
A Real-time Black Box System for Airlines and Passengers: Democratizing Air Safety        Jerry J. Huang, Qunshan Gu, Leshing Shawn Huang        251 - 255
Evaluation of a Real-time GBAS Ground Facility Prototype and its user Performance        Kai-Yuan Hsiao, Shau-Shiun Jan        256 - 264
Absolute Positioning Using the Earth's Magnetic Anomaly Field        Aaron J. Canciani, John F. Raquet        265 - 278
Designing Models for Signals and Errors of Sensors in the Airborne Gravimetry Using Nonlinear Filtering Methods        O.A. Stepanov, D.A. Koshaev, A.V. Motorin        279 - 284
A Navigation Solution Using HD Radio Signals        Ananta Vidyarthi, H. Howard Fan        285 - 292
A Recovery System for SUAV Operations in GPS-Denied Environments Using Timing Advance Measurements        Trevor Layh, Jordan Larson, John Jackson, Brian Taylor, Demoz Gebre-Egziabher        293 - 303
Low-cost Sensor Information Fusion Technology for iPhone Aided Navigation        H. Hong, H. Guo, J. Xiong, M. Yu, Jiangxi, S. Fang, J. Guo        304 - 309
PRS Muting Pattern Assignment to Optimize RSTD Measurement Acquisition for OTDOA Positioning in 3GPP LTE        Ramya Srinivasan, Grant A. Marshall, Guttorm R. Opshaug, Borislav Ristic, Kirk A. Burroughs, Sven Fischer, Shuping Zhang, Daniel Henriksson A, François Cardinal        310 - 325
Quasi-Zenith Satellite System Overview        Yoshiyuki Murai, Daiju Ichinose        326 - 330
Assessment of QZSS L1-SAIF for 3D Map-Based Pedestrian Positioning Method in an Urban Environment        Li-Ta Hsu, Yanlei Gu, Feiyu Chen, Yutaro Wada, Shusuke Kamijo        331 - 342
Ionospheric Correction and Satellite Selection Techniques for the Medium-range Baseline RTK Positioning with GPS and QZSS        An-Lin Tao, Nobuaki Kubo, Shau-Shiun Jan        343 - 352
Quality Control of Ionospheric Corrections for Adoption of Wide Area Augmentation at the Low Latitude Regions        Takeyasu Sakai, Takahiro Aso, Kazuaki Hoshinoo, Ken Ito        353 - 363
Evolution of Corrections Processing for the MC/MF Ground Based Augmentation System (GBAS)        Carl Milner, Alizé Guilbert, Christophe Macabiau        364 - 373
Evaluation of GPS L5 and Galileo E1 and E5a Performance for Future Multi Frequency and Multi Constellation GBAS        M.-S Circiu, M. Felux, S. Thölert, F. Antreich, M. Vergara, M. Sgammini, C. Enneking, Sam Pullen        374 - 382
Methodology for Determining Pseudorange Noise and Multipath Models for a Multi-Constellation, Multi-frequency GBAS System        G. Rotondo, P. Thevenon, C. Milner, C. Macabiau, M. Felux, A. Hornbostel, M.S. Circiu        383 - 392
GPS-SPS Inter-PRN Pseudorange Biases Compared for Transversal SAW and LC Filters Using Live Sky Data and ChipShape Software Receiver Processing        Sanjeev Gunawardena, Frank van Graas        393 - 403
Refinement of Broadcast Integrity Methods for Space Based Augmentation System Selection        Jed Dennis, Mark Hemstad        404 - 414
Estimation of GNSS Signals’ Nominal Distortions from Correlation and Chip Domain        J.B. Pagot, P. Thevenon, O. Julien, Yoan Gregoire, Francisco Amarillo Fernandez, Denis Maillard        415 - 427
Improved WiFi Access Point Localization Using RSS Gradient        Mahsa Shafiee, Richard Klukas        428 - 436
Adaptive Integrated Indoor Pedestrian Tracking System Using MEMS sensors and Hybrid WiFi/Bluetooth-Beacons With Optimized Grid-based Bayesian Filtering Algorithm        Mohamed M. Atia, Umar Iqbal, Sidney Givigi, Aboelmagd Noureldin, Michael Korenberg        437 - 444
An Adaptive Positioning System for Smartphones in Zigbee Networks Using Channel Decomposition and Particle Swarm Optimization        Basem Amer, Mohamed M. Atia, Mostafa Hefnawi, Aboelmagd Noureldin        445 - 454
CMCD: Multipath Detection for Mobile GNSS Receivers        Anton Beitler, Andreas Tollkuehn, Domenico Giustiniano, Bernhard Plattner        455 - 464
Detecting Multipath Errors in Terrestrial GNSS Applications        Okuary Osechas, Kyeong Jin Kim, Kieran Parsons, Zafer Sahinoglu        465 - 474
A Real-time FFT Based Block Processing Method with Near Linear Scaling        M. Turner, A. Richardson        475 - 483
Fast Acquisition Algorithm of GPS L1C Signal Based on the Sparse Fast Fourier Transform        Dongkai Sun, Xiaowei Cui, Yonghui Zhu, Mingquan Lu        484 - 492
A Practical Oblique Projection Methods for GPS Cross-Correlation Interference Mitigation        Kwame N. Edjah, H. Howard Fan        493 - 503
Single-Frequency Multi-GNSS RTK Positioning for Moving Platform        Harish S. Sridhara, Nobuaki Kubo, Ren Kikuchi        504 - 511
OPUS Tools and Real Time Kinematic Networks        Daniel Roman, Gerald Mader, Richard Foote, Neil Weston        512 - 516
Follow-On Report of Activities of the GNSS SDR Metadata Standard Working Group        Sanjeev Gunawardena, Thomas Pany        517 - 520
GPS Carrier Parameters Characterization During Strong Equatorial Ionospheric Scintillation        Dongyang Xu, Yu (Jade) Morton        521 - 529
A Novel Approach for Monitoring Zonal Irregularity Drift Using a Stand-Alone GNSS Scintillation Monitor        Charles S. Carrano, Keith M. Groves, Susan H. Delay, Patricia H. Doherty        530 - 544
Modeling the Effects of Ionosphere Scintillation on GNSS Aviation Navigation Performance        Yang Liu, Yanbo Zhu, Alshaikhi Saleh Ibrahim        545 - 553
Analysis of Phase-Tracking Methods for Low Flux Millisecond Period X-ray Pulsars to Aid Spacecraft Navigation        Kevin D. Anderson, Darryll J. Pines        554 - 565
Orbit Determination of a LEO Orbiter with Less Than Four Visible GPS Satellites        Sunkyoung Yu, Ghangho Kim, Jungbeom Kim, Changdon Kee        566 - 571
Dual-Satellite Localization for Space-borne GNSS Receivers in the Space Service Volume        Shuai Jing, Xingqun Zhan        572 - 578
Atom Interferometry in Dynamic Environments        Richard Stoner, Justin Brown, David Butts, Jennifer Choy, David M.S. Johnson, Krish Kotru, Nicole Pomeroy, Stephen P. Smith, Nancy Wu        579 - 587
The World’s First MEMS Navigation Grade Inertial Navigation System        K. Shcheglov, D. Smukowski, K. Ezal, G. Johnson        588 - 592
A Study on Integrity Improvement of GBAS Ground Subsystem Using CSAC (Chip Scale Atomic Clock)        Takayuki Yoshihara, Francois Murashi, Susumu Saito, Kazuaki Hoshinoo        593 - 599
Robust GPS-based Timing for PMUs Based on Multi-receiver Position-Information-Aided Vector Tracking        Daniel Chou, Yuting Ng, Grace XingXin Gao        600 - 607
Precise Dead-reckoning Using Portable Navigation Device in Urban Environments        Kojiro Takeyama, Noriyoshi Suzuki, Yoshiko Kojima, Takahisa Yamashiro, Seigou Kumabe        608 - 613
Multi-Node Distributed GPS Receiver: Design Approach, Test Results and Real-Time Implementation Status        Michael Van Antwerp, Jeff Dickman, Andrey Soloviev, Eric Vinande        614 - 622
A Robust Method for Spoofing Prevention and Position Recovery in Attacks against Networked GPS Receivers        Nathaniel Carson, David Bevly        623 - 632
Multi-Receiver Vector Tracking Based on a Python Platform        Yuting Ng, Grace Xingxin Gao        633 - 639
Application of Extended and Unscented Kalman Filtering for Non-linear Positioning in Nearby Region of Navigation Sources        Sihao Zhao, Zheng Yao, Jianjun Yin, Mingquan Lu        640 - 650
Precise, Accurate, and Multipath-Resistant Networked Round-Trip Carrier Phase RF Ranging        Bradley D. Farnsworth, E.J. Kreinar, David W.A. Taylor        651 - 656
GNSS Spoof Detection Based on Pseudoranges from Multiple Receivers        David Radin, Peter F. Swaszek, Kelly C. Seals, Richard J. Hartnett        657 - 671
Design of Indoor Positioning System Based on LTE        Jinsong Xu, Haitao Wu, Xiaochun Lu, Decai Zou        672 - 675
Airborne Mitigation of Constellation Wide Faults        Todd Walter, Juan Blanch        676 - 686
Optimal Risk Allocation for BDS/GPS Advanced Receiver Autonomous Integrity Monitoring        Yuan Sun, Taosheng Wang, Zhipeng Wang, Zun Zhang        687 - 695
Fast Multiple Fault Exclusion with a Large Number of Measurements        Juan Blanch, Todd Walter, Per Enge        696 - 701
A Fault-Tolerant, Integrated Navigation System Architecture for UAVs        Trevor Layh, Demoz Gebre-Egziabher        702 - 712
Nominal Bias Analysis for ARAIM User        C. Macabiau, C. Milner, A. Chabory, N. Suard, C. Rodriguez, M. Mabilleau, J. Vuillaume, S. Hegron        713 - 732
Receiver Clock-Based Integrity Monitoring for GNSS Positioning        Takashi Iwamoto, Tomoaki Takewa, Wataru Tsujita        733 - 737
A Recursive Receiver Autonomous Integrity Monitoring (Recursive-RAIM) Technique for GNSS Anti-Spoofing        Huiqi Tao, Hong Li, Weinan Zhang, Mingquan Lu        738 - 744
Nonlinear Inverse Dynamics Used to Control a Quadrocopter with Tiltable Rotors        Georg Scholz, Philipp Crocoll, G.F. Trommer        745 - 755
Vision-Aided Integrity Monitor for Precision Relative Navigation Systems        Sean M. Calhoun, John Raquet, Gilbert Peterson        756 - 767
Panther Chameleon: Real-time Image-based Positioning and Mapping        Joakim Rydell, Erika Bilock        768 - 777
Towards Autonomous Navigation with Unmanned Ground Vehicles Using LiDAR        T. Krüger, S. Nowak, P. Hecker        778 - 788
A Novel Image-Based Navigation System using Stereo Visual Odometry for Indoor and Outdoor Navigation Applications        Jan Ruppelt, Manuel Popp, Michael Gansmann, Gert F. Trommer        789 - 797
The CSUF Ground Rover: A robotic Rover for Searching Unknown Areas        Ye Lu, Jidong Huang        798 - 803
Simultaneous State Estimation of UAV Trajectory Using Probabilistic Graph Models        Derek Chen, Grace Xingxin Gao        804 - 810
Wideband Patch Antennas for Multi-Constellation GNSS Connectivity        Kathleen D. Fasenfest        811 - 821
Multipath and Spoofing Detection Using Angle of Arrival in a Multi-Antenna System        Thomas Bitner, Sarah Preston, David Bevly        822 - 832
A CRPA Based Preprocessor Design for GNSS-Receivers with Optimized Output Signal        Ulrich Engel        833 - 841
Measurement Level Integration of Multiple Low-Cost GPS Receivers for UAVs        Akshay Shetty, Grace Xingxin Gao        842 - 848
A Narrowband GPS Receiver for Multipath Mitigation        Chaithanya Viswa, H. Howard Fan        849 - 859
Detecting and Locating GPS Jamming        Jeffrey Coffed, Joseph Rolli, Carl Slutsky        860 - 868
发表于 2015-5-30 20:56:45 | 显示全部楼层
同求论文集
发表于 2015-6-17 20:02:44 | 显示全部楼层
搭船同求,希望有的小伙伴可以上传
发表于 2015-8-23 15:48:53 | 显示全部楼层
need the proceedings
发表于 2015-12-22 16:23:31 | 显示全部楼层
同求,希望可以上载
GMT+8, 2025-10-19 23:43 , Processed in 0.020108 second(s), 6 queries , Gzip On, Redis On.
