查看: 2326|回复: 0
请问基于PIC18f4520的DS1820温度感测器怎么设计,以下的缺一个主程式
发表于 2015-1-6 09:41:33 | 显示全部楼层 |阅读模式
#include      <p18f4520.h>
#include      <delays.h>
#include      *ov.h*
#include      *ds18b20.h*
#pragma config   OSC=HSPLL,BOREN=OFF,BORV=2,PWRT=ON,WDT=OFF,LVP=OFF
#define OSC_CLOCK 40
#define LCD_RS PORTEbits.RE0
#define LCD_RW PORTEbits.RE1
#define LCD_EN PORTEbits.RE2
void LCDdata_4bit(unsigned char data);
void LCDcommand_4bit(unsigned char data);
void LCDdata(unsigned char data);
void LCDcommand(unsigned char data);
void delay_ms(long A);
void main () {
int i;
unsigned char  ADCValue;
unsigned char  D(3);
         ADCON1  =0x0c;     ??
   TRISD      = 0;                                             ?
         TRISE      = 0;                          ?
   LCD_EN   = 0;
         LCDcommand(0b00000001);
         LCDcommand(0b00000010);
         LCDcommand(0b00000110);
         LCDcommand(0b00001111);  ?
         LCDcommand(0b00101000);  ??
         while(1);
ADCValue=ds_get_temp();
PORTD=ADCValue;
Delay_ms(1000);
Nop();
LCDcommand(0b100000000);
D[0]=ADCValue/100%10;
D[1]=ADCValue/10%10;
D[2]=ADCValue%10;
For(i=0;i<3;i++){
if(D<10;D+= '0')
         LCDdata('D');LCDdata('1')
LCDdata('Q'); LCDdata('1')
         LCDdata('C');LCDdata('=');
         LCDdata(D[0]);LCDdata(D[1]);
         LCDdata(D[2];)
         inti;
         LCD_RW=0;
         LCD_RS=1;
         LATD=data;
         LCD_EN=1;                                   ?
         for(i=0;i<180;i++);
         LCD_EN=0;
         inti;
         LCD_RW=0;                                 ???
         LCD_RS=0;
         LATD=data;
         LCD_EN=1;                                   ?
         for(i=0;i<300;i++);
         LCD_EN=0;
         unsignedchar temp;
         temp=data&0xF0;
   LCDdata_4bit(temp);
         Nop();
         temp=(data<<4)&0xF0;
         LCDdata_4bit(temp);
         unsignedchar temp;
         temp=data&0xF0;
   LCDcommand_4bit(temp);
         Nop();
         longi;
         intus2TCY;
         us2TCY=(10*OSC_CLOCK)>>2;
         for(i=0;i<A;i++)Delay100TCYx(us2TCY);
GMT+8, 2025-12-30 02:06 , Processed in 0.014789 second(s), 9 queries , Gzip On, Redis On.
