查看: 2705|回复: 2
[求助] I creeated Text(drawing) in mos , I want to auto attatch it
发表于 2015-1-5 16:19:34 | 显示全部楼层 |阅读模式
I uesd the skill see below :
but When I load "CCSattachLabels.il"  in  CIW
there are the syntax error
  syntax error ( in line 5 column 3 of file) ,  What is the problem ?
procedure( CCSattachLabels()
   let( (cv allLabels x1 y1 box inst)
      cv=geGetWindowCellView()
      allLabels=setof(x cv~>shapes x~>objType=="label")
      foreach( label allLabels
         x1=car(label~>xy)
         y1=cadr(label~>xy)
         box=list(x1:y1 x1+0.001:y1+0.001)
         inst=car(dbProduceOverlapInst(cv box))
         leAttachFig(label inst)
         printf("Attached label %s at %L to inst %s\n" label~>theLabel label~>xy inst~>name)
      ) ;foreach
   ) ;let
) ;procedure
发表于 2015-1-18 11:59:28 | 显示全部楼层
load & work ok
No problem.
发表于 2015-1-18 12:25:27 | 显示全部楼层
if no inst under the label ?
use unless to box the last 2 code line
unless(inst==nil
GMT+8, 2025-12-25 12:12 , Processed in 0.016995 second(s), 6 queries , Gzip On, Redis On.
