查看: 1140|回复: 0
[招聘] 【Marvell Cellular手机部门】招聘ASIC Design/DFT/Implementation工程师
发表于 2014-12-31 11:33:34 | 显示全部楼层 |阅读模式
1Job Title:SoC ASIC Engineer
Department: Cellular Engineering
Job Description: modem:
3G: TD-SCDMA and WCDMA modem development
4G: TD-LTE modem development
SoC: next generation cellphone SoC full design cycle from spec.to massproduction.
Largest chip inside Marvell.
1) R&D L2/L3 of the above protocol stacks.
2)Integration and Testing with the UE system.
Qualification:
MS degree in microelectronics, or electrical engineering.
At least three years working experience.
Experience in real design projects (front-end or backend) is a strongplus.
Good team work spirit and communication skill. Eager to learn, work and grow ina challenging project.
2Job Title: ASIC Implementation Engineer
Job Description:
- Block, IP macro or SoC level implementation in 28nm or20nm TSMC/UMC process
- UPF Synthesis with Synopsys DC or DCT/G flows
- RTL2Gate and Gate2Gate formal check with LEC and/orformality tools.
- Working with BE team to timing closure in Primetime-SIon multi-corners and multi-modes
Ability tobuild or perfect the EDA-methodology-flow with perl, tcl or shell
- Knowledge on DFT (mbist/scan)will be an added advantage
Qualifications:
- BSEE degree or above
- Strong understanding of synthesis flowusing DC/DCT/DCG - for a low power (UPF) and high speed- complex SoC
- Hands on experience with formalverification tools such as LEC and/or formality
- Must have the CTS conceptions in ICC atP&R stage
- Strong STA skills. Must have thorough knowledge on closing timing at unit andtop level
- Experience in mbist and scan will be plus
- Proficient in Perl, Tcl and Shellprogramming
-Good team work spirit
3Job Title: ASIC DFT design Engineer
Job Description:
-Block, IPand SoC level DFT implementation (JTAG, Scan, Mbist and analog/IP test etc.)and RTL integration;
-Participatein test spec/plan definition; create the DFT design document and signoffDFT review checklists;
-Testpatterns/vectors generation and verification;
-Interfaceto backend team on physical design and timing closure;
-Interfaceto test engineers on ATE and vectors bring-up and debugging;
-Chip DFTquality sign-off
-DFT STA,constraint generation, formal and timing closure
Qualifications:
- DFT design and integration experience
- Hands on DFT implementation experience (Bscan, Mbist, DC/AC Scan, analogIP test circuit integration, IDDQ test, ATPG and test pattern verification)
- Expertise with DFT tools from Synopsy, Mentor, Syntest etc.
- Strong logic design and verification background
- Experience in Synthesis and STA will be plus
- Proficient in Perl, tcl and shell programming
- Good team work spirit
If you are interested in the position, please send your resume to the following email address:   jiangrr@marvell.com
Subject of your email should be: School_Name_Applied position_Information source
Eg.SJTU_Zhang Peng _Data Analyst_BBS
GMT+8, 2025-12-27 08:39 , Processed in 0.043635 second(s), 6 queries , Gzip On, Redis On.
