查看: 9321|回复: 8
[求助] cadence ies12.20.003 安装license问题,求各路英雄指点
发表于 2014-12-21 16:08:42 | 显示全部楼层 |阅读模式
各路豪杰们,小弟在安装ies12.20.003时遇到ncsim没有lciense,具体现象如下,求名医指点哦:
1. 运行 irun +access+wr tb_top.v 提示如下错误:
2. .bashrc 配置如下:
3. 系统环境如下:
4. 运行 lmgrd -c $LM_LICENSE_FILE -l ius1220003_lic.log 产生如下图log,且log文件一直在变大,查看似乎是相同的东东一直在循环:
15:47:31 (lmgrd) -----------------------------------------------
15:47:31 (lmgrd)   Please Note:
15:47:31 (lmgrd)
15:47:31 (lmgrd)   This log is intended for debug purposes only.
15:47:31 (lmgrd)   In order to capture accurate license
15:47:31 (lmgrd)   usage data into an organized repository,
15:47:31 (lmgrd)   please enable report logging. Use Macrovision's
15:47:31 (lmgrd)   software license administration  solution,
15:47:31 (lmgrd)   FLEXnet Manager, to  readily gain visibility
15:47:31 (lmgrd)   into license usage data and to create
15:47:31 (lmgrd)   insightful reports on critical information like
15:47:31 (lmgrd)   license availability and usage. FLEXnet Manager
15:47:31 (lmgrd)   can be fully automated to run these reports on
15:47:31 (lmgrd)   schedule and can be used to track license
15:47:31 (lmgrd)   servers and usage across a heterogeneous
15:47:31 (lmgrd)   network of servers including Windows NT, Linux
15:47:31 (lmgrd)   and UNIX. Contact Macrovision at
15:47:31 (lmgrd)   www.macrovision.com for more details on how to
15:47:31 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
15:47:31 (lmgrd)   for your enterprise.
15:47:31 (lmgrd)
15:47:31 (lmgrd)
15:47:31 (lmgrd)
15:47:31 (lmgrd) The license server manager (lmgrd) running as root:
15:47:31 (lmgrd)
This is a potential security problem
15:47:31 (lmgrd)
and is not recommended.
15:47:31 (lmgrd) FLEXnet Licensing (v10.8.2.1 build 30341) started on localhost.localdomain (linux) (12/21/2014)
15:47:31 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
15:47:31 (lmgrd) US Patents 5,390,297 and 5,671,412.
15:47:31 (lmgrd) World Wide Web:  http://www.macrovision.com
15:47:31 (lmgrd) License file(s): /eda/cadence/license/ius12_20_003_lic.dat
15:47:31 (lmgrd) lmgrd tcp-port 26000
15:47:31 (lmgrd) Starting vendor daemons ...
15:47:31 (cdslmd) FLEXnet Licensing version v10.8.2.1 build 30341
15:47:31 (lmgrd) Started cdslmd (internet tcp_port 47838 pid 4925)
15:47:32 (cdslmd) Server started on localhost.localdomain for:
100
15:47:32 (cdslmd) 111
11300
11400
15:47:32 (cdslmd) 11701
11702
11703
15:47:32 (cdslmd) 11710
12110
12111
15:47:32 (cdslmd) 12121
12141
12141_64bit
15:47:32 (cdslmd) 12150
12500
14000
15:47:32 (cdslmd) 14010
14020
14030
15:47:32 (cdslmd) 14040
14060
14100
15:47:32 (cdslmd) 14101
14110
14111
15:47:32 (cdslmd) 14120
14130
14140
15:47:32 (cdslmd) 14400
14410
14420
15:47:32 (cdslmd) 200
20120
20121
15:47:32 (cdslmd) 20122
20123
20124
15:47:32 (cdslmd) 20127
20128
20220
15:47:32 (cdslmd) 20221
20222
20227
15:47:32 (cdslmd) 206
207
21000
15:47:32 (cdslmd) 21060
21200
21400
15:47:32 (cdslmd) 2141
_21900
21900
15:47:32 (cdslmd) 21920
223
224
15:47:32 (cdslmd) 22650
22800
22810
15:47:32 (cdslmd) 24015
24025
24100
15:47:32 (cdslmd) 24205
250
251
15:47:32 (cdslmd) 26000
274
276
15:47:32 (cdslmd) 278
279
283
15:47:32 (cdslmd) 300
3000
3001
15:47:32 (cdslmd) 30010
3002
300_64bit
15:47:32 (cdslmd) 3011
302
305
15:47:32 (cdslmd) 31000
311
3111
15:47:32 (cdslmd) 312
314
316
15:47:32 (cdslmd) 318
32015
32100
15:47:32 (cdslmd) 32101
32110
32120
15:47:32 (cdslmd) 32125
32130
32140
15:47:32 (cdslmd) 32150
32190
322
15:47:32 (cdslmd) 32500
32501
32502
15:47:32 (cdslmd) 32503
32505
32510
15:47:32 (cdslmd) 32520
32521
32530
15:47:32 (cdslmd) 32550
32600
32610
15:47:32 (cdslmd) 32620
32630
32640
15:47:32 (cdslmd) 32760
33000
33010
15:47:32 (cdslmd) 33011
33015
33016
15:47:32 (cdslmd) 33100
33300
33301
15:47:32 (cdslmd) 334
33500
33580
15:47:32 (cdslmd) 336
3405
34500
15:47:32 (cdslmd) 34510
34511
34530
15:47:32 (cdslmd) 34570
34580
35100
15:47:32 (cdslmd) 35200
360
362
15:47:32 (cdslmd) 365
365_64bit
370
15:47:32 (cdslmd) 371
37100
373
15:47:32 (cdslmd) 374
38500
38520
15:47:32 (cdslmd) 39000
39001
3D_FieldSolver_Engine
15:47:32 (cdslmd) 4000
40020
40030
15:47:32 (cdslmd) 40040
40500
41000
15:47:32 (cdslmd) 50000
50010
501
15:47:32 (cdslmd) 50110
50200
502A
15:47:32 (cdslmd) 5100
51022
51023
15:47:32 (cdslmd) 51060
51070
51170
15:47:32 (cdslmd) 550
570
61300
15:47:32 (cdslmd) 61400
681
7000
15:47:32 (cdslmd) 70000
70110
70110_64bit
15:47:32 (cdslmd) 70120
70120_64bit
70130
15:47:32 (cdslmd) 70510
70510_64_bit
70520
15:47:32 (cdslmd) 70520_64bit
71110
71110_64bit
15:47:32 (cdslmd) 71120
71130
71510
15:47:32 (cdslmd) 71520
72110
72120
15:47:32 (cdslmd) 72130
72131
72132
15:47:32 (cdslmd) 72133
72134
72135
15:47:32 (cdslmd) 72140
72150
727
15:47:32 (cdslmd) 728
729
730
15:47:32 (cdslmd) 730_64bit
733
73510
15:47:32 (cdslmd) 73520
761
780
15:47:32 (cdslmd) 780_64bit
900
9000
15:47:32 (cdslmd) 90001
920
940
15:47:32 (cdslmd) 945
950
95100
15:47:32 (cdslmd) 95115
95120
952
15:47:32 (cdslmd) 95200
95210
95220
15:47:32 (cdslmd) 95255
95300
95310
15:47:32 (cdslmd) 95320
95400
960
15:47:32 (cdslmd) 960_64bit
963
964
15:47:32 (cdslmd) 965
966
972
15:47:32 (cdslmd) 974
991
992
15:47:32 (cdslmd) 993
994
995
15:47:32 (cdslmd) a2dxf
aae-signalscan
aae-signalscan-transaction
15:47:32 (cdslmd) aae-transaction-explorer ABIT
Actel_FPGA
15:47:32 (cdslmd) actomd
ADE_ElectronStorm_Option ADE_VoltageStorm_Option
15:47:32 (cdslmd) ADV_2S10PUC_ALL ADV_2S15PUC_ALL ADV_2S20PUC_ALL
15:47:32 (cdslmd) ADV_2S40PUC_ALL ADV_2S60PUC_ALL ADV_2SUPUC_ALL
15:47:32 (cdslmd) ADV_4S10PUC_ALL ADV_4S20PUC_ALL ADV_4S40PUC_ALL
15:47:32 (cdslmd) ADV_4S60PUC_ALL ADV_4SUPUC_ALL
ADV_6S60PUC_ALL
15:47:32 (cdslmd) ADV_6S90PUC_ALL ADV_6SUPUC_ALL
Advanced_Cell_Placer
15:47:32 (cdslmd) advanced_package_designer Advanced_Pkg_Engineer_3D adv_package_designer_expert
15:47:32 (cdslmd) adv_package_engineer_expert Affirma_3rdParty_Sim_Interface Affirma_advanced_analysis_env
15:47:32 (cdslmd) Affirma_AMS_distrib_processing Affirma_ams_simulator Affirma_equivalence_checker
15:47:32 (cdslmd) Affirma_equiv_checker_prep Affirma_model_checker Affirma_model_packager_export
15:47:32 (cdslmd) Affirma_NC_Simulator Affirma_NC_VHDL_Desktop_Sim Affirma_RF_IC_package
15:47:32 (cdslmd) Affirma_RF_IC_package_modeler Affirma_RF_SPW_model_link affirma-signalscan
15:47:32 (cdslmd) affirma-signalscan-control affirma-signalscan-pro affirma-signalscan-schmatic
15:47:32 (cdslmd) affirma-signalscan-source affirma-signalscan-transaction Affirma_sim_analysis_env
15:47:32 (cdslmd) Affirma_transaction_analysis affirma-transaction-explorer Affirma_trans_logic_abstracter
15:47:32 (cdslmd) ALL_EBD
Allegro_CAD_Interface Allegro_Design_Editor_620
15:47:32 (cdslmd) Allegro_Designer Allegro_designer_suite Allegro_design_expert
15:47:32 (cdslmd) allegro_dfa
allegro_dfa_att Allegro_Expert
15:47:32 (cdslmd) Allegro_Librarian allegro_non_partner Allegro_Package_Designer_620
15:47:32 (cdslmd) Allegro_Package_SI_620 Allegro_Package_SI_620_Suite Allegro_PCB
15:47:32 (cdslmd) Allegro_PCB_Design_230 Allegro_PCB_Design_620 Allegro_PCB_Interface
15:47:32 (cdslmd) Allegro_PCB_Partitioning Allegro_PCB_RF
Allegro_PCB_Router_210
15:47:32 (cdslmd) Allegro_PCB_Router_230 Allegro_PCB_Router_610 Allegro_PCB_SI_230
15:47:32 (cdslmd) Allegro_PCB_SI_620 Allegro_PCB_SI_630 Allegro_PCB_SI_630_Suite
15:47:32 (cdslmd) Allegro_performance Allegro_Pkg_Designer_620_Suite allegroprance
15:47:32 (cdslmd) Allegro_studio
allegro_symbol
Allegro_Viewer_Plus
15:47:32 (cdslmd) Altera_MAX
Ambit_BuildGates Ambit_libcompile
15:47:32 (cdslmd) Ambit_RnD_option AMD_MACH
AmoebaPlace
15:47:32 (cdslmd) AMS_Designer_Link AMS_environment AMS_Methodology_Kit
15:47:32 (cdslmd) AMS_Option_to_Incisive Analog_Design_Environment_GXL Analog_Design_Environment_L
15:47:32 (cdslmd) Analog_Design_Environment_XL ANALOG_WORKBENCH APD
15:47:32 (cdslmd) Aptivia
archiver
arouter
15:47:32 (cdslmd) Artist_Optimizer Artist_Statistics Assura_DRC
15:47:32 (cdslmd) Assura_DV_design_rule_checker Assura_DV_LVS_checker Assura_DV_parasitic_extractor
15:47:32 (cdslmd) Assura_LVS
Assura_MP
Assura_OPC
15:47:32 (cdslmd) Assura_RCX
Assura_RCX_Adv_Process Assura_RCX-FS
15:47:32 (cdslmd) Assura_RCX-HF
Assura_RCX-MP
Assura_RCX-PL
15:47:32 (cdslmd) Assura_SI
Assura_SiMC
Assura_SI-TL
15:47:32 (cdslmd) Assura_SiVL
Assura_UI
Atmel_ATV
15:47:32 (cdslmd) AWB_Batch
AWB_BEHAVIOR
AWB_DIST_SIM
15:47:32 (cdslmd) AWB_MAGAZINE
AWB_MAGNETICS
AWB_MIX
15:47:32 (cdslmd) AWB_PPLOT
AWB_RESOLVE_OPT AWB_SIMULATOR
15:47:32 (cdslmd) AWB_SMOKE
AWB_SPICEPLUS
AWB_STATS
15:47:32 (cdslmd) Base_Digital_Body_Lib Base_Verilog_Lib BG
15:47:32 (cdslmd) BlockMaster_Characterizer BlockMaster_Optimizer BlockPlace
15:47:32 (cdslmd) BoardQuest_Designer BoardQuest_Team BOGUS
15:47:32 (cdslmd) BRDST_IF
BuildGates_Extreme Cadence_3D_Design_Viewer
15:47:32 (cdslmd) Cadence_chip_assembly_router CADIF_IF
caeviews
15:47:32 (cdslmd) cals_out
Capture
CaptureCIS
15:47:32 (cdslmd) Capture_CIS_Studio catia
cbds_in
15:47:32 (cdslmd) CCAR
CDMA_Simulation_Runtime cdxe_in
15:47:32 (cdslmd) CELL3
CELL3_ARO
CELL3_CROSSTALK
15:47:32 (cdslmd) CELL3_CTS
CELL3_DIST
CELL3_ECL
15:47:32 (cdslmd) CELL3_OPENDEV
CELL3_OPENEXE
CELL3_PA
15:47:32 (cdslmd) CELL3_PR
CELL3_QPLACE
CELL3_QPLACE_TIMING
15:47:32 (cdslmd) CELL3_QROUTE
CELL3_RGT
CELL3_SCAN
15:47:32 (cdslmd) CELL3_TIMING
CELL3_WIDEWIRE
celtic
15:47:32 (cdslmd) Celtic_Crosstalk_Analyzer Celtic_NDC
CHDL_DesignAccess
15:47:32 (cdslmd) CheckADV_ALL
CheckPlus
Checkplus_Expert
15:47:32 (cdslmd) Cierto_HW_design_sys_2000 Cierto_signal_proc_wrksys_2000 Cierto_SPW_CDMA_Library
15:47:32 (cdslmd) Cierto_SPW_comm_lib_flt_pt Cierto_SPW_comm_library_fxp_pt Cierto_SPW_GSM_VE
15:47:32 (cdslmd) Cierto_SPW_IS136_VE Cierto_SPW_link_to_Ambit_BG Cierto_SPW_link_to_NC_sim
15:47:32 (cdslmd) Cierto_SPW_model_manager Cierto_SPW_multimedia_kit Cierto_SPW_pcscdma_VE
15:47:32 (cdslmd) Cierto_Wireless_LAN_Library ClockSyn
Clock_Tree_Generation
15:47:32 (cdslmd) Cobra_Simulator comp
compose
15:47:32 (cdslmd) compose_autoplan compose_gcr
ComposerCheckPlus_AdvRules
15:47:32 (cdslmd) ComposerCheckPlus_Checker ComposerCheckPlus_RuleDev Composer_EDIF300_Connectivity
15:47:32 (cdslmd) Composer_EDIF300_Schematic Composer_Schematic_Generator Composer_Spectre_Sim_Solution
15:47:32 (cdslmd) compose_scells
compose_tlmr
compose_util
15:47:32 (cdslmd) concept
ConceptHDL
Concept_HDL_expert
15:47:32 (cdslmd) Concept_HDL_rules_checker Concept_HDL_studio conceptXPC
15:47:32 (cdslmd) ConcICe_Option
Conformal_Asic
Conformal_Constraint_Designer
15:47:32 (cdslmd) Conformal_Constraint_Dsgnr_XL Conformal_Custom conformal_datapath
15:47:32 (cdslmd) Conformal_ECO
Conformal_ECO_GXL Conformal_GXL
15:47:32 (cdslmd) conformal_ldd
conformal_lec
Conformal_Low_Power
15:47:32 (cdslmd) Conformal_Low_Power_GXL Conformal_LP_GXL conformal_lvr
15:47:32 (cdslmd) conformal_mem
Conformal_Ultra conformal_vhd
15:47:32 (cdslmd) conformal_vlg
Corners_Analysis cpe
15:47:32 (cdslmd) CP_Ele_Checks
CPF
cpte
15:47:32 (cdslmd) CPtoolkit
crefer
CTE
15:47:32 (cdslmd) cvtomd
CWAVES
CWB01
15:47:32 (cdslmd) CWB03
CWB04
CWB05
15:47:32 (cdslmd) Datapath_Preview_Option Datapath_Verilog Datapath_VHDL
15:47:32 (cdslmd) debug
DelayCal
DesignViewer
15:47:32 (cdslmd) Desktop_mgr
Device_Level_Placer Device_Level_Router
15:47:32 (cdslmd) DFM_2S10PUC_ALL DFM_2S15PUC_ALL DFM_2S20PUC_ALL
15:47:32 (cdslmd) DFM_2S40PUC_ALL DFM_2S60PUC_ALL DFM_2SUPUC_ALL
15:47:32 (cdslmd) DFM_4S10PUC_ALL DFM_4S20PUC_ALL DFM_4S40PUC_ALL
15:47:32 (cdslmd) DFM_4S60PUC_ALL DFM_4SUPUC_ALL
DFM_6S60PUC_ALL
15:47:32 (cdslmd) DFM_6S90PUC_ALL DFM_6SUPUC_ALL
DFM_Core_Technology
15:47:32 (cdslmd) dfsverifault
DISCRETE_LIB
Distributed_Dracula_Option
15:47:32 (cdslmd) DRAC2CORE
DRAC2DRC
DRAC2LVS
15:47:32 (cdslmd) DRAC3CORE
DRAC3DRC
DRAC3LVS
15:47:32 (cdslmd) DRACACCESS
DRACDIST
DRACERC
15:47:32 (cdslmd) DRACLAYDE
DRACLPE
DRACLVS
15:47:32 (cdslmd) DRACPG_E
DRACPLOT
DRACPRE
15:47:32 (cdslmd) DRACSLAVE
dracula_in
dxf2a
15:47:32 (cdslmd) e2v
EB_2S10PUC_ALL
EB_2S15PUC_ALL
15:47:32 (cdslmd) EB_2S20PUC_ALL
EB_2S40PUC_ALL
EB_2S60PUC_ALL
15:47:32 (cdslmd) EB_2SUPUC_ALL
EB_4S10PUC_ALL
EB_4S20PUC_ALL
15:47:32 (cdslmd) EB_4S40PUC_ALL
EB_4S60PUC_ALL
EB_4SUPUC_ALL
15:47:32 (cdslmd) EB_6S60PUC_ALL
EB_6S90PUC_ALL
EB_6SUPUC_ALL
15:47:32 (cdslmd) EBD_edit
EBD_floorplan
EBD_power
15:47:32 (cdslmd) eCapture
ECO
edif2ged
15:47:32 (cdslmd) EDIF_Netlist_Interface EDIF_Schematic_Interface EditBase
15:47:32 (cdslmd) EditBase_ALL
EditFST
EditFST_ALL
15:47:32 (cdslmd) EditPlace_ALL
EditRoute_ALL
EF_2SUPUC_ALL
15:47:32 (cdslmd) EF_4S40PUC_ALL
EF_4S60PUC_ALL
EF_4SUPUC_ALL
15:47:32 (cdslmd) EF_6S60PUC_ALL
EF_6S90PUC_ALL
EF_6SUPUC_ALL
15:47:32 (cdslmd) EMCdisplay
EMControl
EMControl_Float
15:47:32 (cdslmd) EMI_ALL
Encounter
Encounter_Adv_Node_GXL
15:47:32 (cdslmd) Encounter_C
Encounter_ClockSyn Encounter_Digital_Impl_Sys_L
15:47:32 (cdslmd) Encounter_Digital_Impl_Sys_XL Encounter_Low_Power_GXL Encounter_Mixed_Signal_GXL
15:47:32 (cdslmd) Encounter_QRC_Extraction_GXL Encounter_QRC_Extraction_L Encounter_QRC_Extraction_XL
15:47:32 (cdslmd) Encounter_Test_Architect Encounter_Timing_System_L Encounter_Timing_System_XL
15:47:32 (cdslmd) Encounter_True_Time Encounter_Wave_Viewer Encounter_X
15:47:32 (cdslmd) Envisia_DataPath_option Envisia_GE_ultra_place_route Envisia_LowPower_option
15:47:32 (cdslmd) Envisia_PKS
Envisia_RAC
Envisia_SE_SI_place_route
15:47:32 (cdslmd) Envisia_SE_ultra_place_route Envisia_Utility evc_verisity_ahb
15:47:32 (cdslmd) evc_verisity_axi evc_verisity_enet evc_verisity_pci
15:47:32 (cdslmd) evc_verisity_pcie evc_verisity_pcie_ep evc_verisity_pcie_rc
15:47:32 (cdslmd) evc_verisity_usb evc_verisity_usb_otg expert
15:47:32 (cdslmd) expgen
explorer
Express
15:47:32 (cdslmd) ExpressPlus
Extended_Digital_Body_Lib Extended_Digital_Lib
15:47:32 (cdslmd) Extended_Verilog_Lib fcengine
fcheck
15:47:32 (cdslmd) FE_ASIC
FE_ASIC_Agere
FE_ASIC_Fujitsu
15:47:32 (cdslmd) FE_ASIC_IBM
FE_ASIC_LSILogic FE_ASIC_Mitsubishi
15:47:32 (cdslmd) FE_ASIC_NEC
FE_ASIC_Philips FE_ASIC_Samsung
15:47:32 (cdslmd) FE_ASIC_ST
FE_ASIC_TI
FE_ASIC_Toshiba
15:47:32 (cdslmd) FE_Classic
FE_GPS
fethman
15:47:32 (cdslmd) fetsetup
FE_Ultra
Fire_Ice_Cell
15:47:32 (cdslmd) Fire_Ice_Cell_Transistor Fire_IceQXC2_Cell Fire_Parallel
15:47:32 (cdslmd) FirstEncounter
First_Encounter_GPS First_Encounter_GXL
15:47:32 (cdslmd) FirstEncounterSOC First_Encounter_Ultra First_Encounter_VIP
15:47:32 (cdslmd) First_Encounter_XL FloatPC_ALL
FloorPlan
15:47:32 (cdslmd) fluke
FPGA_Flows
FPGA_OPTIMIZER
15:47:32 (cdslmd) FPGA_Tools
Framework
fsim
15:47:32 (cdslmd) FST_2SUPUC_ALL
FST_4S40PUC_ALL FST_4S60PUC_ALL
15:47:32 (cdslmd) FST_4SUPUC_ALL
FST_6S60PUC_ALL FST_6S90PUC_ALL
15:47:32 (cdslmd) FST_6SUPUC_ALL
FUNCTION_LIB
GATEENSEMBLE
15:47:32 (cdslmd) GATEENSEMBLE_ARO GATEENSEMBLE_CROSSTALK GATEENSEMBLE_CTS
15:47:32 (cdslmd) GATEENSEMBLE_CTS_LE GATEENSEMBLE_CTS_UL GATEENSEMBLE_DIST
15:47:32 (cdslmd) Gate_Ensemble_DSM Gate_Ensemble_DSM_Crosstalk GATEENSEMBLE_ECL
15:47:32 (cdslmd) GATEENSEMBLE_LOWEND GATEENSEMBLE_OPENDEV GATEENSEMBLE_OPENEXE
15:47:32 (cdslmd) GATEENSEMBLE_PA GATEENSEMBLE_PR_LE GATEENSEMBLE_PR_UL
15:47:32 (cdslmd) GATEENSEMBLE_QPLACE GATEENSEMBLE_QPLACE_TIMING GATEENSEMBLE_QROUTE
15:47:32 (cdslmd) GATEENSEMBLE_RGT GATEENSEMBLE_SCAN GATEENSEMBLE_TIMING
15:47:32 (cdslmd) GATEENSEMBLE_TIMING_LE GATEENSEMBLE_TIMING_UL GATEENSEMBLE_UNLIMITED
15:47:32 (cdslmd) Gate_Ensemble_WARP GATEENSEMBLE_WIDEWIRE gbom
15:47:32 (cdslmd) GDS_IF
GdsiiOut
GDT_IF
15:47:32 (cdslmd) ged2edif
glib
gloss
15:47:32 (cdslmd) gphysdly
gscald
GSM_Simulation_Runtime
15:47:32 (cdslmd) gspares
HDL-DESKTOP
hp3070
15:47:32 (cdslmd) HYB_2S10PUC_ALL HYB_2S15PUC_ALL HYB_2S20PUC_ALL
15:47:32 (cdslmd) HYB_2S40PUC_ALL HYB_2S60PUC_ALL HYB_4S40PUC_ALL
15:47:32 (cdslmd) HYB_4S60PUC_ALL HYB_4SUPUC_ALL
HYB_6S60PUC_ALL
15:47:32 (cdslmd) HYB_6S90PUC_ALL HYB_6SUPUC_ALL
IC_autoroute
15:47:32 (cdslmd) IC_autoroute_ALL IC_devicegen
IC_devicegen_ALL
15:47:32 (cdslmd) IC_deviceplace_ALL IC_edit
IC_edit_ALL
15:47:32 (cdslmd) IC_editfast_ALL Ice_Parallel
IC_gcell_route
15:47:32 (cdslmd) IC_gcell_route_ALL IC_hsrules
IC_hsrules_ALL
15:47:32 (cdslmd) IC_Inspector
IC_Inspector_ALL IC_InspectorEngr_ALL
15:47:32 (cdslmd) IC_mp_route
IC_mp_route_ALL IC_power_route
15:47:32 (cdslmd) IC_power_route_ALL IDF_Bi_Directional_Interface iges_electrical
15:47:32 (cdslmd) Incisive_Design_Team_Simulator Incisive_Desktop_Manager Incisive_Enterprise_Planner
15:47:32 (cdslmd) Incisive_Enterprise_Manager Incisive_Enterprise_Simulator Incisive_Formal_Verifier
15:47:32 (cdslmd) Incisive_HDL_Simulator Incisive_P2C_Methodology Incisive_Specman_interactive
15:47:32 (cdslmd) Incisive_Verif_Engine Incisive_Verif_Environ intrgloss
15:47:32 (cdslmd) Intrica_powerplane_builder intrroute
intrsignoise
15:47:32 (cdslmd) IPB_2S10PUC_ALL IPB_2S15PUC_ALL IPB_2S20PUC_ALL
15:47:32 (cdslmd) IPB_2S40PUC_ALL IPB_2S60PUC_ALL IPB_2SUPUC_ALL
15:47:32 (cdslmd) IPB_4S10PUC_ALL IPB_4S20PUC_ALL IPB_4S40PUC_ALL
15:47:32 (cdslmd) IPB_4S60PUC_ALL IPB_4SUPUC_ALL
IPB_6S60PUC_ALL
15:47:32 (cdslmd) IPB_6S90PUC_ALL IPB_6SUPUC_ALL
ipc_in
15:47:32 (cdslmd) ipc_out
IPlaceBase
IPlaceBase_ALL
15:47:32 (cdslmd) IPO
LAS_Cell_Optimization Layout
15:47:32 (cdslmd) LayoutEE
LayoutPlus
LEAPFROG-BV
15:47:32 (cdslmd) LEAPFROG-C
LEAPFROG-CV
LEAPFROG-SLAVE
15:47:32 (cdslmd) LEAPFROG-SV
LEAPFROG-SYS
LEFDEF_IF
15:47:32 (cdslmd) LID10
LID11
LINEAR_LIB
15:47:32 (cdslmd) LSE
lwb
MAG_LIB
15:47:32 (cdslmd) mdin
mdout
mdtoac
15:47:32 (cdslmd) mdtocv
MIXAD_LIB
Model_Check_Analysis
15:47:32 (cdslmd) MSMV
Multithread_Route_Option multiwire
15:47:32 (cdslmd) MV_4S40PUC_ALL
MV_6SUPUC_ALL
Nano_Encounter
15:47:32 (cdslmd) Nano_Encounter_DBS NanoRoute_Ultra NCSim_Desktop
15:47:32 (cdslmd) NC-simulator
nc_specman
ncsysc_specman
15:47:32 (cdslmd) NC_SystemC_Simulator NC_SystemVerilog_Simulator NC_Verilog_Compiler
15:47:32 (cdslmd) NC_Verilog_Data_Prep_Compiler NC_Verilog_Option NC_Verilog_Simulator
15:47:32 (cdslmd) NC_Vhdl_Compiler NC_Vhdl_Option
NC_Vhdl_Simulator
15:47:32 (cdslmd) NCVLOG_CGOPTS
NeoCell
Nihongoconcept
15:47:32 (cdslmd) OA
OASIS_RFDE
OASIS_Simulation_Interface
15:47:32 (cdslmd) odan
OpenModeler
OpenModeler_SFI
15:47:32 (cdslmd) OpenModeler_SWIFT OpenSim
OpenWaves
15:47:32 (cdslmd) Optimizer
OrCAD
OrCAD_PCB_Designer
15:47:32 (cdslmd) OrCAD_PCB_Designer_PSpice OrCAD_PCB_Router Pacific_Noise_Analyzer
15:47:32 (cdslmd) packager
PartitionOptimizer PAS_Assura_Drc_Generator
15:47:32 (cdslmd) PAS_Assura_Lvs_Generator PAS_Diva_Drc_Generator PAS_Diva_Lvs_Generator
15:47:32 (cdslmd) PAS_Dracula_Drc_Generator PAS_Dracula_Lvs_Generator PAS_ErrorCell_Generator
15:47:32 (cdslmd) PAS_Graphical_Tech_Editor PAS_Pcell_Generator PB_2S10PUC_ALL
15:47:32 (cdslmd) PB_2S15PUC_ALL
PB_2S20PUC_ALL
PB_2S40PUC_ALL
15:47:32 (cdslmd) PB_2S60PUC_ALL
PB_2SUPUC_ALL
PB_4S10PUC_ALL
15:47:32 (cdslmd) PB_4S40PUC_ALL
PB_4S60PUC_ALL
PB_4SUPUC_ALL
15:47:32 (cdslmd) PB_6S60PUC_ALL
PB_6SUPUC_ALL
PB_USUPUC_ALL
15:47:32 (cdslmd) PCB_designer
PCB_design_expert PCB_design_studio
15:47:32 (cdslmd) pcb_editor
pcb_engineer
pcb_interactive
15:47:32 (cdslmd) PCB_librarian_expert pcb_prep
pcb_review
15:47:32 (cdslmd) PCB_studio_variants pcomp
Pearl
15:47:32 (cdslmd) Pearl_Cell
PE_Librarian
Physical_Verification_Sys
15:47:32 (cdslmd) Physical_Verification_Sys_L Physical_Verification_Sys_XL Physical_Verification_Sys_Deb
15:47:32 (cdslmd) PICDesigner
PIC_Utilities
PKS
15:47:32 (cdslmd) PlaceBase
PlaceBase_ALL
placement
15:47:32 (cdslmd) Placement_Based_Optimization Placement_Based_Synthesis PlaceOrIPlace_ALL
15:47:32 (cdslmd) PLD
plotVersa
PowerAnalysis
15:47:32 (cdslmd) PowerIntegrity
PP_2SUPUC_ALL
PP_4S40PUC_ALL
15:47:32 (cdslmd) PP_4S60PUC_ALL
PP_6S60PUC_ALL
PP_6S90PUC_ALL
15:47:32 (cdslmd) PP_6SUPUC_ALL
PPRoute
PPRoute_ALL
15:47:32 (cdslmd) Prevail_Board_Designer Prevail_Correct_By_Design Prevail_Designer
15:47:32 (cdslmd) Preview_Synopsys_Interface Protel_IF
PSpice
15:47:32 (cdslmd) PspiceAA
PspiceAD
PSpiceBasics
15:47:32 (cdslmd) PSpiceStudio
ptc_in
ptc_out
15:47:32 (cdslmd) PWM_LIB
QPlace
QRC_Advanced_Analysis
15:47:32 (cdslmd) QRC_Advanced_Modeling quanticout
Quickturn_Model_Manager
15:47:32 (cdslmd) RapidPART
rapidsim
RB_2S10PUC_ALL
15:47:32 (cdslmd) RB_2S15PUC_ALL
RB_2S20PUC_ALL
RB_2S40PUC_ALL
15:47:32 (cdslmd) RB_2S60PUC_ALL
RB_2SUPUC_ALL
RB_4S10PUC_ALL
15:47:32 (cdslmd) RB_4S20PUC_ALL
RB_4S40PUC_ALL
RB_4S60PUC_ALL
15:47:32 (cdslmd) RB_4SUPUC_ALL
RB_6S60PUC_ALL
RB_6S90PUC_ALL
15:47:32 (cdslmd) RB_6SUPUC
RB_6SUPUC_ALL
RCExtraction
15:47:32 (cdslmd) RC-GXL
RC-L
realchiplm
15:47:32 (cdslmd) redifnet
RELXPERT
Route
15:47:32 (cdslmd) RouteADV
RouteADV_ALL
RouteBase
15:47:32 (cdslmd) RouteBase_ALL
RouteDF
RouteDFM
15:47:32 (cdslmd) RouteDFM_ALL
RouteFST
RouteFST_ALL
15:47:32 (cdslmd) RouteHYB
RouteHYB_ALL
RouteMin_ALL
15:47:32 (cdslmd) RouteMVIA_ALL
RouteOrEdit_ALL rt
15:47:32 (cdslmd) RTL_Compiler_Physical RTL_Compiler_RD RTL_Compiler_Ultra
15:47:32 (cdslmd) RTL_Compiler_Ultra_II_Option RTL_Compiler_Verification Schematic_Generator
15:47:32 (cdslmd) SDL_IF
sdrc_in
sdrc_out
15:47:32 (cdslmd) SDT_MODEL_MANAGER sepks
shapefill
15:47:32 (cdslmd) signal_explorer Signal_Integrity SignalIntegrity
15:47:32 (cdslmd) SignalStorm_Lib_Characterizer Signalstorm_NDC SignalStorm_Parallel_Sim
15:47:32 (cdslmd) signoise
SigNoiseCS
SigNoiseEngineer
15:47:32 (cdslmd) SigNoiseExpert
SigNoise_Float
SigNoiseStdDigLib
15:47:32 (cdslmd) Sigxp
sigxp_explorer
Sigxp_tier
15:47:32 (cdslmd) Sigxp_tier_EXPERT Silicon_Ensemble Silicon_Ensemble_CTS
15:47:32 (cdslmd) Silicon_Ensemble_DSM Silicon_Ensemble_DSM_Crosstalk Silicon_Ensemble_OpenDev
15:47:32 (cdslmd) Silicon_Ensemble_OpenExe Silicon_Ensemble_WARP SiliconQuest
15:47:32 (cdslmd) SiliconQuest_CTGen_Option Silicon_Synthesis_QPBS SimControl
15:47:32 (cdslmd) SimVision
SiP_Digital_Architect_GXL SiP_Digital_Architect_L
15:47:32 (cdslmd) SiP_Digital_Architect_XL SiP_Digital_Layout_GXL SiP_Digital_SI_XL
15:47:32 (cdslmd) SiP_RF_Architect_L SiP_RF_Architect_XL SiP_RF_Layout_GXL
15:47:32 (cdslmd) SI_Timing_Convergence SI_Timing_Convergence_VS skillDev
15:47:32 (cdslmd) soce
SOC_Encounter
SOC_Encounter_GPS
15:47:32 (cdslmd) SOC_Encounter_GXL SOC_Encounter_L SOC_Encounter_XL
15:47:32 (cdslmd) SONYBNTI
SPECCTRA_256U
SPECCTRA_6U
15:47:32 (cdslmd) SPECCTRA_ADV
SPECCTRA_APD
specctra_autoroute
15:47:32 (cdslmd) specctra_designer SPECCTRA_DFM
specctra_expert
15:47:32 (cdslmd) specctra_expert_system SPECCTRA_HP
specctra_pcb
15:47:32 (cdslmd) specctra_performance SPECCTRA_QE
SPECCTRAQuest
15:47:32 (cdslmd) SPECCTRAQuest_EE SPECCTRAQuest_Planner SPECCTRAQuest_SI_expert
15:47:32 (cdslmd) SPECCTRAQuest_signal_expert SPECCTRAQuest_signal_explorer SPECCTRA_Unison_PCB
15:47:32 (cdslmd) SPECCTRA_Unison_Ultra SPECCTRA_VT
SpecialRoute
15:47:32 (cdslmd) specman
SpectreBasic
Spectre_BTAHVMOS_Models
15:47:32 (cdslmd) Spectre_BTASOI_Models Spectre_Burst_AllegroSI SpectreHDL
15:47:32 (cdslmd) Spectre_NorTel_Models Spectre_Parallel_Analysis SpectreRF
15:47:32 (cdslmd) Spectre_Siemens_Models Spectre_ST_Models SPICE_IF
15:47:32 (cdslmd) SPW
SPW_BER_Sim
SPW_CGS_
15:47:32 (cdslmd) SPW_HLS
SPW_LSF_Link
SPW_MPX
15:47:32 (cdslmd) SPW_Smart_Antenna_Library SQ_Digital_Logic_SI_Lib SQ_FPGA_SI_Lib
15:47:32 (cdslmd) SQ_Memory_SI_Lib SQ_Microprocessor_SI_Lib stream_in
15:47:32 (cdslmd) stream_out
StudioPSpiceAD
STV90a
15:47:32 (cdslmd) Substrate_Coupling_Analysis Substrate_Noise_Analyst sv_surecov
15:47:32 (cdslmd) sv_suresight
swap
SWIFT
15:47:32 (cdslmd) sx
Synlink_Interface synSmartIF
15:47:32 (cdslmd) synSmartLib
synTiOpt
TANCELL
15:47:32 (cdslmd) Test_Design_Analysis Test_Design_ATPG_Plus Test_Design_Compression
15:47:32 (cdslmd) Test_Design_Generation Test_Design_Verification Test_Extension_Language
15:47:32 (cdslmd) Test_Mfg_Fault_Isolation TimingAnalysis
TimingBudget
15:47:32 (cdslmd) transformal_ltx TrialRoute
tscr
15:47:32 (cdslmd) tsTestGen
tsTestIntf
tsTSynVHDL
15:47:32 (cdslmd) tsTSynVLOG
tune
tw01
15:47:32 (cdslmd) tw02
UET
ULMdelta
15:47:32 (cdslmd) ULMecho
ULMhotel
ULMindia
15:47:32 (cdslmd) ULMjuliette
ULMmike
ULTRASIM
15:47:32 (cdslmd) Unison_SPECCTRA_4U UNISON_SPECCTRA_6U Universal_Smartpath
15:47:32 (cdslmd) v2e
Vampire_HDRC
Vampire_HLVS
15:47:32 (cdslmd) Vampire_MP
Vampire_RCX
Vampire_UI
15:47:32 (cdslmd) VB_2S10PUC_ALL
VB_2S15PUC_ALL
VB_2S20PUC_ALL
15:47:32 (cdslmd) VB_2S40PUC_ALL
VB_2S60PUC_ALL
VB_2SUPUC_ALL
15:47:32 (cdslmd) VB_4S10PUC_ALL
VB_4S20PUC_ALL
VB_4S40PUC_ALL
15:47:32 (cdslmd) VB_4S60PUC_ALL
VB_4SUPUC_ALL
VB_6S60PUC_ALL
15:47:32 (cdslmd) VB_6S90PUC_ALL
VB_6SUPUC
VB_6SUPUC_ALL
15:47:32 (cdslmd) VB_USUPUC_ALL
VCC_Editors
VCC_links_to_implementation
15:47:32 (cdslmd) VCC_Simulators
VCC_SW_Estimator VCR
15:47:32 (cdslmd) vc-signalscan
vc-signalscan-transaction vc-transaction-explorer
15:47:32 (cdslmd) verifault
Verif_Ckpit_Analysis_Env Verif_Ckpit_Runtime_Env
15:47:32 (cdslmd) Verify
Verilog_desktop VERILOG-SLAVE
15:47:32 (cdslmd) VERILOG-XL
Verilog_XL_Desktop Verilog_XL_Turbo_NT
15:47:32 (cdslmd) VERITIME
vgen
VHDL_desktop
15:47:32 (cdslmd) VHDLLink
viable
ViewBase
15:47:32 (cdslmd) ViewBase_ALL
ViewBaseEngr_ALL Virtuoso_Acceler_Parallel_L
15:47:32 (cdslmd) Virtuoso_Acceler_Parallel_XL Virtuoso_APS_MMSIM_LK virtuoso_chip_editor
15:47:32 (cdslmd) VIRTUOSO_CM_OPTION_FOR_VSDE Virtuoso_Constraint_API Virtuoso_Core_Characterizer
15:47:32 (cdslmd) Virtuoso_Core_Optimizer Virtuoso_custom_placer Virtuoso_custom_router
15:47:32 (cdslmd) Virtuoso_Digital_implement Virtuoso_Layout_Migrate Virtuoso_Layout_Suite_GX
15:47:32 (cdslmd) Virtuoso_Layout_Suite_GXL Virtuoso_Layout_Suite_L Virtuoso_Layout_Suite_XL
15:47:32 (cdslmd) Virtuoso_Multi_mode_Simulation Virtuoso_NeoCircuit_DFM Virtuoso_Phase_Designer
15:47:32 (cdslmd) Virtuoso_QRC_Extraction_GXL Virtuoso_QRC_Extraction_L Virtuoso_QRC_Extraction_XL
15:47:32 (cdslmd) Virtuoso_Schematic_Editor_GXL Virtuoso_Schematic_Editor_L Virtuoso_Schematic_Editor_XL
15:47:32 (cdslmd) Virtuoso_Schem_Option Virtuoso_SiI
VIRTUOSO_SPEC_DRIVEN_ENVIRO
15:47:32 (cdslmd) Virtuoso_Spectre Virtuoso_Spectre_GXL Virtuoso_Spectre_RF
15:47:32 (cdslmd) Virtuoso_Spectre_XL Virtuoso_Sprectre_GXL_MMSIM_LK Virtuoso_Turbo
15:47:32 (cdslmd) Virtuoso_Turbo_Basic Virtuoso_Visual_Analysis_XL Virtuoso_XL
15:47:32 (cdslmd) Virtuoso_XL_Basic visula_in
VITAL-XL
15:47:32 (cdslmd) vloglink
vmanager
VoltageStorm_Cell_Transistor2
15:47:32 (cdslmd) VoltageStorm_UI VXL-ALPHA
VXL-LMC-HW-IF
15:47:32 (cdslmd) VXL-SWITCH-RC
VXL-TURBO
VXL-VCW
15:47:32 (cdslmd) VXL-VET
VXL-VLS
VXL-VRA
15:47:32 (cdslmd) wedifsch
WinPlace
WireEdit
15:47:32 (cdslmd) WLAN_Simulation_Runtime X4ENC
xilCds
15:47:32 (cdslmd) xilComposerFE
xilConceptFE
xilEdif
15:47:32 (cdslmd) Xilinx_FPGA
15:47:32 (cdslmd)
15:47:32 (cdslmd) All FEATURE lines for cdslmd behave like INCREMENT lines
15:47:32 (cdslmd)
15:47:42 (cdslmd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
15:47:42 (cdslmd) EXITING DUE TO SIGNAL 37
15:47:42 (lmgrd) cdslmd exited with status 37 (Communications error)
15:47:42 (lmgrd) Since this is an unknown status, license server
15:47:42 (lmgrd) manager (lmgrd) will attempt to re-start the vendor daemon.
15:47:42 (cdslmd) FLEXnet Licensing version v10.8.2.1 build 30341
15:47:42 (lmgrd) REStarted cdslmd (internet tcp_port 55316 pid 4936)
15:47:43 (cdslmd) Server started on localhost.localdomain for:
100
15:47:43 (cdslmd) 111
11300
11400
15:47:43 (cdslmd) 11701
11702
11703
15:47:43 (cdslmd) 11710
12110
12111
15:47:43 (cdslmd) 12121
12141
12141_64bit
15:47:43 (cdslmd) 12150
12500
14000
15:47:43 (cdslmd) 14010
14020
14030
15:47:43 (cdslmd) 14040
14060
14100
15:47:43 (cdslmd) 14101
14110
14111
15:47:43 (cdslmd) 14120
14130
14140
15:47:43 (cdslmd) 14400
14410
14420
15:47:43 (cdslmd) 200
20120
20121
15:47:43 (cdslmd) 20122
20123
20124
15:47:43 (cdslmd) 20127
20128
20220
15:47:43 (cdslmd) 20221
20222
20227
15:47:43 (cdslmd) 206
207
21000
15:47:43 (cdslmd) 21060
21200
21400
15:47:43 (cdslmd) 2141
_21900
21900
15:47:43 (cdslmd) 21920
223
224
15:47:43 (cdslmd) 22650
22800
22810
15:47:43 (cdslmd) 24015
24025
24100
15:47:43 (cdslmd) 24205
250
251
15:47:43 (cdslmd) 26000
274
276
15:47:43 (cdslmd) 278
279
283
15:47:43 (cdslmd) 300
3000
3001
15:47:43 (cdslmd) 30010
3002
300_64bit
15:47:43 (cdslmd) 3011
302
305
15:47:43 (cdslmd) 31000
311
3111
15:47:43 (cdslmd) 312
314
316
15:47:43 (cdslmd) 318
32015
32100
15:47:43 (cdslmd) 32101
32110
32120
15:47:43 (cdslmd) 32125
32130
32140
15:47:43 (cdslmd) 32150
32190
322
15:47:43 (cdslmd) 32500
32501
32502
15:47:43 (cdslmd) 32503
32505
32510
15:47:43 (cdslmd) 32520
32521
32530
15:47:43 (cdslmd) 32550
32600
32610
15:47:43 (cdslmd) 32620
32630
32640
15:47:43 (cdslmd) 32760
33000
33010
15:47:43 (cdslmd) 33011
33015
33016
15:47:43 (cdslmd) 33100
33300
33301
15:47:43 (cdslmd) 334
33500
33580
15:47:43 (cdslmd) 336
3405
34500
15:47:43 (cdslmd) 34510
34511
34530
15:47:43 (cdslmd) 34570
34580
35100
15:47:43 (cdslmd) 35200
360
362
15:47:43 (cdslmd) 365
365_64bit
370
15:47:43 (cdslmd) 371
37100
373
15:47:43 (cdslmd) 374
38500
38520
15:47:43 (cdslmd) 39000
39001
15:47:43 (cdslmd) 4000
40020
40030
15:47:43 (cdslmd) 40040
40500
41000
15:47:43 (cdslmd) 50000
50010
501
15:47:43 (cdslmd) 50110
50200
502A
15:47:43 (cdslmd) 5100
51022
51023
15:47:43 (cdslmd) 51060
51070
51170
15:47:43 (cdslmd) 550
570
61300
15:47:43 (cdslmd) 61400
681
7000
15:47:43 (cdslmd) 70000
70110
70110_64bit
15:47:43 (cdslmd) 70120
70120_64bit
70130
15:47:43 (cdslmd) 70510
70510_64_bit
70520
15:47:43 (cdslmd) 70520_64bit
71110
71110_64bit
15:47:43 (cdslmd) 71120
71130
71510
15:47:43 (cdslmd) 71520
72110
72120
15:47:43 (cdslmd) 72130
72131
72132
15:47:43 (cdslmd) 72133
72134
72135
15:47:43 (cdslmd) 72140
72150
727
15:47:43 (cdslmd) 728
729
730
15:47:43 (cdslmd) 730_64bit
733
73510
15:47:43 (cdslmd) 73520
761
780
15:47:43 (cdslmd) 780_64bit
900
9000
15:47:43 (cdslmd) 90001
920
940
15:47:43 (cdslmd) 945
950
95100
15:47:43 (cdslmd) 95115
95120
952
15:47:43 (cdslmd) 95200
95210
95220
15:47:43 (cdslmd) 95255
95300
95310
15:47:43 (cdslmd) 95320
95400
960
15:47:43 (cdslmd) 960_64bit
963
964
15:47:43 (cdslmd) 965
966
972
15:47:43 (cdslmd) 974
991
992
15:47:43 (cdslmd) 993
994
995
15:47:43 (cdslmd) a2dxf
aae-signalscan
15:47:43 (cdslmd) aae-transaction-explorer ABIT
Actel_FPGA
15:47:43 (cdslmd) actomd
15:47:43 (cdslmd) ADV_2S10PUC_ALL ADV_2S15PUC_ALL ADV_2S20PUC_ALL
15:47:43 (cdslmd) ADV_2S40PUC_ALL ADV_2S60PUC_ALL ADV_2SUPUC_ALL
15:47:43 (cdslmd) ADV_4S10PUC_ALL ADV_4S20PUC_ALL ADV_4S40PUC_ALL
15:47:43 (cdslmd) ADV_4S60PUC_ALL ADV_4SUPUC_ALL
ADV_6S60PUC_ALL
15:47:43 (cdslmd) ADV_6S90PUC_ALL ADV_6SUPUC_ALL
15:47:43 (cdslmd) advanced_package_designer Advanced_Pkg_Engineer_3D adv_package_designer_expert
15:47:43 (cdslmd) adv_package_engineer_expert Affirma_3rdParty_Sim_Interface Affirma_advanced_analysis_env
15:47:43 (cdslmd) Affirma_AMS_distrib_processing Affirma_ams_simulator Affirma_equivalence_checker
15:47:43 (cdslmd) Affirma_equiv_checker_prep Affirma_model_checker Affirma_model_packager_export
15:47:43 (cdslmd) Affirma_NC_Simulator Affirma_NC_VHDL_Desktop_Sim Affirma_RF_IC_package
15:47:43 (cdslmd) Affirma_RF_IC_package_modeler Affirma_RF_SPW_model_link affirma-signalscan
15:47:43 (cdslmd) affirma-signalscan-control affirma-signalscan-pro affirma-signalscan-schmatic
15:47:43 (cdslmd) affirma-signalscan-source affirma-signalscan-transaction Affirma_sim_analysis_env
15:47:43 (cdslmd) Affirma_transaction_analysis affirma-transaction-explorer Affirma_trans_logic_abstracter
15:47:43 (cdslmd) ALL_EBD
15:47:43 (cdslmd) Allegro_Designer Allegro_designer_suite Allegro_design_expert
15:47:43 (cdslmd) allegro_dfa
15:47:43 (cdslmd) Allegro_Librarian allegro_non_partner Allegro_Package_Designer_620
15:47:43 (cdslmd) Allegro_Package_SI_620 Allegro_Package_SI_620_Suite Allegro_PCB
15:47:43 (cdslmd) Allegro_PCB_Design_230 Allegro_PCB_Design_620 Allegro_PCB_Interface
15:47:43 (cdslmd) Allegro_PCB_Partitioning Allegro_PCB_RF
15:47:43 (cdslmd) Allegro_PCB_Router_230 Allegro_PCB_Router_610 Allegro_PCB_SI_230
15:47:43 (cdslmd) Allegro_PCB_SI_620 Allegro_PCB_SI_630 Allegro_PCB_SI_630_Suite
15:47:43 (cdslmd) Allegro_performance Allegro_Pkg_Designer_620_Suite allegroprance
15:47:43 (cdslmd) Allegro_studio
allegro_symbol
Allegro_Viewer_Plus
15:47:43 (cdslmd) Altera_MAX
15:47:43 (cdslmd) Ambit_RnD_option AMD_MACH
AmoebaPlace
15:47:43 (cdslmd) AMS_Designer_Link AMS_environment AMS_Methodology_Kit
15:47:43 (cdslmd) AMS_Option_to_Incisive Analog_Design_Environment_GXL Analog_Design_Environment_L
15:47:43 (cdslmd) Analog_Design_Environment_XL ANALOG_WORKBENCH APD
15:47:43 (cdslmd) Aptivia
archiver
arouter
15:47:43 (cdslmd) Artist_Optimizer Artist_Statistics Assura_DRC
15:47:43 (cdslmd) Assura_DV_design_rule_checker Assura_DV_LVS_checker Assura_DV_parasitic_extractor
15:47:43 (cdslmd) Assura_LVS
Assura_MP
Assura_OPC
15:47:43 (cdslmd) Assura_RCX
15:47:43 (cdslmd) Assura_RCX-HF
Assura_RCX-MP
Assura_RCX-PL
15:47:43 (cdslmd) Assura_SI
Assura_SiMC
Assura_SI-TL
15:47:43 (cdslmd) Assura_SiVL
Assura_UI
Atmel_ATV
15:47:43 (cdslmd) AWB_Batch
AWB_BEHAVIOR
AWB_DIST_SIM
15:47:43 (cdslmd) AWB_MAGAZINE
AWB_MAGNETICS
AWB_MIX
15:47:43 (cdslmd) AWB_PPLOT
15:47:43 (cdslmd) AWB_SMOKE
AWB_SPICEPLUS
AWB_STATS
15:47:43 (cdslmd) Base_Digital_Body_Lib Base_Verilog_Lib BG
15:47:43 (cdslmd) BlockMaster_Characterizer BlockMaster_Optimizer BlockPlace
15:47:43 (cdslmd) BoardQuest_Designer BoardQuest_Team BOGUS
15:47:43 (cdslmd) BRDST_IF
15:47:43 (cdslmd) Cadence_chip_assembly_router CADIF_IF
caeviews
15:47:43 (cdslmd) cals_out
Capture
CaptureCIS
15:47:43 (cdslmd) Capture_CIS_Studio catia
cbds_in
15:47:43 (cdslmd) CCAR
15:47:43 (cdslmd) CELL3
CELL3_ARO
CELL3_CROSSTALK
15:47:43 (cdslmd) CELL3_CTS
CELL3_DIST
CELL3_ECL
15:47:43 (cdslmd) CELL3_OPENDEV
CELL3_OPENEXE
CELL3_PA
15:47:43 (cdslmd) CELL3_PR
CELL3_QPLACE
CELL3_QPLACE_TIMING
15:47:43 (cdslmd) CELL3_QROUTE
CELL3_RGT
CELL3_SCAN
15:47:43 (cdslmd) CELL3_TIMING
CELL3_WIDEWIRE
celtic
15:47:43 (cdslmd) Celtic_Crosstalk_Analyzer Celtic_NDC
CHDL_DesignAccess
15:47:43 (cdslmd) CheckADV_ALL
CheckPlus
Checkplus_Expert
15:47:43 (cdslmd) Cierto_HW_design_sys_2000 Cierto_signal_proc_wrksys_2000 Cierto_SPW_CDMA_Library
15:47:43 (cdslmd) Cierto_SPW_comm_lib_flt_pt Cierto_SPW_comm_library_fxp_pt Cierto_SPW_GSM_VE
15:47:43 (cdslmd) Cierto_SPW_IS136_VE Cierto_SPW_link_to_Ambit_BG Cierto_SPW_link_to_NC_sim
15:47:43 (cdslmd) Cierto_SPW_model_manager Cierto_SPW_multimedia_kit Cierto_SPW_pcscdma_VE
15:47:43 (cdslmd) Cierto_Wireless_LAN_Library ClockSyn
15:47:43 (cdslmd) Cobra_Simulator comp
compose
15:47:43 (cdslmd) compose_autoplan compose_gcr
15:47:43 (cdslmd) ComposerCheckPlus_Checker ComposerCheckPlus_RuleDev Composer_EDIF300_Connectivity
15:47:43 (cdslmd) Composer_EDIF300_Schematic Composer_Schematic_Generator Composer_Spectre_Sim_Solution
15:47:43 (cdslmd) compose_scells
compose_tlmr
compose_util
15:47:43 (cdslmd) concept
ConceptHDL
Concept_HDL_expert
15:47:43 (cdslmd) Concept_HDL_rules_checker Concept_HDL_studio conceptXPC
15:47:43 (cdslmd) ConcICe_Option
Conformal_Asic
15:47:43 (cdslmd) Conformal_Constraint_Dsgnr_XL Conformal_Custom conformal_datapath
15:47:43 (cdslmd) Conformal_ECO
15:47:43 (cdslmd) conformal_ldd
conformal_lec
Conformal_Low_Power
15:47:43 (cdslmd) Conformal_Low_Power_GXL Conformal_LP_GXL conformal_lvr
15:47:43 (cdslmd) conformal_mem
15:47:43 (cdslmd) conformal_vlg
15:47:43 (cdslmd) CP_Ele_Checks
CPF
cpte
15:47:43 (cdslmd) CPtoolkit
crefer
CTE
15:47:43 (cdslmd) cvtomd
CWAVES
CWB01
15:47:43 (cdslmd) CWB03
CWB04
CWB05
15:47:43 (cdslmd) Datapath_Preview_Option Datapath_Verilog Datapath_VHDL
15:47:43 (cdslmd) debug
DelayCal
DesignViewer
15:47:43 (cdslmd) Desktop_mgr
15:47:43 (cdslmd) DFM_2S10PUC_ALL DFM_2S15PUC_ALL DFM_2S20PUC_ALL
15:47:43 (cdslmd) DFM_2S40PUC_ALL DFM_2S60PUC_ALL DFM_2SUPUC_ALL
15:47:43 (cdslmd) DFM_4S10PUC_ALL DFM_4S20PUC_ALL DFM_4S40PUC_ALL
15:47:43 (cdslmd) DFM_4S60PUC_ALL DFM_4SUPUC_ALL
DFM_6S60PUC_ALL
15:47:43 (cdslmd) DFM_6S90PUC_ALL DFM_6SUPUC_ALL
DFM_Core_Technology
15:47:43 (cdslmd) dfsverifault
DISCRETE_LIB
15:47:43 (cdslmd) DRAC2CORE
DRAC2DRC
DRAC2LVS
15:47:43 (cdslmd) DRAC3CORE
DRAC3DRC
DRAC3LVS
15:47:43 (cdslmd) DRACACCESS
DRACDIST
DRACERC
15:47:43 (cdslmd) DRACLAYDE
DRACLPE
DRACLVS
15:47:43 (cdslmd) DRACPG_E
DRACPLOT
DRACPRE
15:47:43 (cdslmd) DRACSLAVE
dracula_in
dxf2a
15:47:43 (cdslmd) e2v
EB_2S10PUC_ALL
EB_2S15PUC_ALL
15:47:43 (cdslmd) EB_2S20PUC_ALL
EB_2S40PUC_ALL
EB_2S60PUC_ALL
15:47:43 (cdslmd) EB_2SUPUC_ALL
EB_4S10PUC_ALL
EB_4S20PUC_ALL
15:47:43 (cdslmd) EB_4S40PUC_ALL
EB_4S60PUC_ALL
EB_4SUPUC_ALL
15:47:43 (cdslmd) EB_6S60PUC_ALL
EB_6S90PUC_ALL
EB_6SUPUC_ALL
15:47:43 (cdslmd) EBD_edit
EBD_floorplan
EBD_power
15:47:43 (cdslmd) eCapture
ECO
edif2ged
15:47:43 (cdslmd) EDIF_Netlist_Interface EDIF_Schematic_Interface EditBase
15:47:43 (cdslmd) EditBase_ALL
EditFST
EditFST_ALL
15:47:43 (cdslmd) EditPlace_ALL
EditRoute_ALL
EF_2SUPUC_ALL
15:47:43 (cdslmd) EF_4S40PUC_ALL
EF_4S60PUC_ALL
EF_4SUPUC_ALL
15:47:43 (cdslmd) EF_6S60PUC_ALL
EF_6S90PUC_ALL
EF_6SUPUC_ALL
15:47:43 (cdslmd) EMCdisplay
EMControl
EMControl_Float
15:47:43 (cdslmd) EMI_ALL
Encounter
15:47:43 (cdslmd) Encounter_C
15:47:43 (cdslmd) Encounter_Digital_Impl_Sys_XL Encounter_Low_Power_GXL Encounter_Mixed_Signal_GXL
15:47:43 (cdslmd) Encounter_QRC_Extraction_GXL Encounter_QRC_Extraction_L Encounter_QRC_Extraction_XL
15:47:43 (cdslmd) Encounter_Test_Architect Encounter_Timing_System_L Encounter_Timing_System_XL
15:47:43 (cdslmd) Encounter_True_Time Encounter_Wave_Viewer Encounter_X
15:47:43 (cdslmd) Envisia_DataPath_option Envisia_GE_ultra_place_route Envisia_LowPower_option
15:47:43 (cdslmd) Envisia_PKS
Envisia_RAC
15:47:43 (cdslmd) Envisia_SE_ultra_place_route Envisia_Utility evc_verisity_ahb
15:47:43 (cdslmd) evc_verisity_axi evc_verisity_enet evc_verisity_pci
15:47:43 (cdslmd) evc_verisity_pcie evc_verisity_pcie_ep evc_verisity_pcie_rc
15:47:43 (cdslmd) evc_verisity_usb evc_verisity_usb_otg expert
15:47:43 (cdslmd) expgen
explorer
Express
15:47:43 (cdslmd) ExpressPlus
15:47:43 (cdslmd) Extended_Verilog_Lib fcengine
fcheck
15:47:43 (cdslmd) FE_ASIC
FE_ASIC_Agere
FE_ASIC_Fujitsu
15:47:43 (cdslmd) FE_ASIC_IBM
15:47:43 (cdslmd) FE_ASIC_NEC
15:47:43 (cdslmd) FE_ASIC_ST
FE_ASIC_TI
FE_ASIC_Toshiba
15:47:43 (cdslmd) FE_Classic
FE_GPS
fethman
15:47:43 (cdslmd) fetsetup
FE_Ultra
Fire_Ice_Cell
15:47:43 (cdslmd) Fire_Ice_Cell_Transistor Fire_IceQXC2_Cell Fire_Parallel
15:47:43 (cdslmd) FirstEncounter
15:47:43 (cdslmd) FirstEncounterSOC First_Encounter_Ultra First_Encounter_VIP
15:47:43 (cdslmd) First_Encounter_XL FloatPC_ALL
FloorPlan
15:47:43 (cdslmd) fluke
FPGA_Flows
FPGA_OPTIMIZER
15:47:43 (cdslmd) FPGA_Tools
Framework
fsim
15:47:43 (cdslmd) FST_2SUPUC_ALL
15:47:43 (cdslmd) FST_4SUPUC_ALL
15:47:43 (cdslmd) FST_6SUPUC_ALL
FUNCTION_LIB
GATEENSEMBLE
15:47:43 (cdslmd) GATEENSEMBLE_ARO GATEENSEMBLE_CROSSTALK GATEENSEMBLE_CTS
15:47:43 (cdslmd) GATEENSEMBLE_CTS_LE GATEENSEMBLE_CTS_UL GATEENSEMBLE_DIST
15:47:43 (cdslmd) Gate_Ensemble_DSM Gate_Ensemble_DSM_Crosstalk GATEENSEMBLE_ECL
15:47:43 (cdslmd) GATEENSEMBLE_LOWEND GATEENSEMBLE_OPENDEV GATEENSEMBLE_OPENEXE
15:47:43 (cdslmd) GATEENSEMBLE_PA GATEENSEMBLE_PR_LE GATEENSEMBLE_PR_UL
15:47:43 (cdslmd) GATEENSEMBLE_QPLACE GATEENSEMBLE_QPLACE_TIMING GATEENSEMBLE_QROUTE
15:47:43 (cdslmd) GATEENSEMBLE_RGT GATEENSEMBLE_SCAN GATEENSEMBLE_TIMING
15:47:43 (cdslmd) GATEENSEMBLE_TIMING_LE GATEENSEMBLE_TIMING_UL GATEENSEMBLE_UNLIMITED
15:47:43 (cdslmd) Gate_Ensemble_WARP GATEENSEMBLE_WIDEWIRE gbom
15:47:43 (cdslmd) GDS_IF
GdsiiOut
GDT_IF
15:47:43 (cdslmd) ged2edif
glib
gloss
15:47:43 (cdslmd) gphysdly
gscald
15:47:43 (cdslmd) gspares
HDL-DESKTOP
hp3070
15:47:43 (cdslmd) HYB_2S10PUC_ALL HYB_2S15PUC_ALL HYB_2S20PUC_ALL
15:47:43 (cdslmd) HYB_2S40PUC_ALL HYB_2S60PUC_ALL HYB_4S40PUC_ALL
15:47:43 (cdslmd) HYB_4S60PUC_ALL HYB_4SUPUC_ALL
HYB_6S60PUC_ALL
15:47:43 (cdslmd) HYB_6S90PUC_ALL HYB_6SUPUC_ALL
IC_autoroute
15:47:43 (cdslmd) IC_autoroute_ALL IC_devicegen
IC_devicegen_ALL
15:47:43 (cdslmd) IC_deviceplace_ALL IC_edit
IC_edit_ALL
15:47:43 (cdslmd) IC_editfast_ALL Ice_Parallel
IC_gcell_route
15:47:43 (cdslmd) IC_gcell_route_ALL IC_hsrules
IC_hsrules_ALL
15:47:43 (cdslmd) IC_Inspector
15:47:43 (cdslmd) IC_mp_route
15:47:43 (cdslmd) IC_power_route_ALL IDF_Bi_Directional_Interface iges_electrical
15:47:43 (cdslmd) Incisive_Design_Team_Simulator Incisive_Desktop_Manager Incisive_Enterprise_Planner
15:47:43 (cdslmd) Incisive_Enterprise_Manager Incisive_Enterprise_Simulator Incisive_Formal_Verifier
15:47:43 (cdslmd) Incisive_HDL_Simulator Incisive_P2C_Methodology Incisive_Specman_interactive
15:47:43 (cdslmd) Incisive_Verif_Engine Incisive_Verif_Environ intrgloss
15:47:43 (cdslmd) Intrica_powerplane_builder intrroute
intrsignoise
15:47:43 (cdslmd) IPB_2S10PUC_ALL IPB_2S15PUC_ALL IPB_2S20PUC_ALL
15:47:43 (cdslmd) IPB_2S40PUC_ALL IPB_2S60PUC_ALL IPB_2SUPUC_ALL
15:47:43 (cdslmd) IPB_4S10PUC_ALL IPB_4S20PUC_ALL IPB_4S40PUC_ALL
15:47:43 (cdslmd) IPB_4S60PUC_ALL IPB_4SUPUC_ALL
IPB_6S60PUC_ALL
15:47:43 (cdslmd) IPB_6S90PUC_ALL IPB_6SUPUC_ALL
ipc_in
15:47:43 (cdslmd) ipc_out
IPlaceBase
IPlaceBase_ALL
15:47:43 (cdslmd) IPO
15:47:43 (cdslmd) LayoutEE
LayoutPlus
LEAPFROG-BV
15:47:43 (cdslmd) LEAPFROG-C
LEAPFROG-CV
LEAPFROG-SLAVE
15:47:43 (cdslmd) LEAPFROG-SV
LEAPFROG-SYS
LEFDEF_IF
15:47:43 (cdslmd) LID10
LID11
LINEAR_LIB
15:47:43 (cdslmd) LSE
lwb
MAG_LIB
15:47:43 (cdslmd) mdin
mdout
mdtoac
15:47:43 (cdslmd) mdtocv
MIXAD_LIB
15:47:43 (cdslmd) MSMV
15:47:43 (cdslmd) MV_4S40PUC_ALL
MV_6SUPUC_ALL
Nano_Encounter
15:47:43 (cdslmd) Nano_Encounter_DBS NanoRoute_Ultra NCSim_Desktop
15:47:43 (cdslmd) NC-simulator
nc_specman
ncsysc_specman
15:47:43 (cdslmd) NC_SystemC_Simulator NC_SystemVerilog_Simulator NC_Verilog_Compiler
15:47:43 (cdslmd) NC_Verilog_Data_Prep_Compiler NC_Verilog_Option NC_Verilog_Simulator
15:47:43 (cdslmd) NC_Vhdl_Compiler NC_Vhdl_Option
NC_Vhdl_Simulator
15:47:43 (cdslmd) NCVLOG_CGOPTS
NeoCell
Nihongoconcept
15:47:43 (cdslmd) OA
OASIS_RFDE
15:47:43 (cdslmd) odan
OpenModeler
OpenModeler_SFI
15:47:43 (cdslmd) OpenModeler_SWIFT OpenSim
OpenWaves
15:47:43 (cdslmd) Optimizer
OrCAD
OrCAD_PCB_Designer
15:47:43 (cdslmd) OrCAD_PCB_Designer_PSpice OrCAD_PCB_Router Pacific_Noise_Analyzer
15:47:43 (cdslmd) packager
15:47:43 (cdslmd) PAS_Assura_Lvs_Generator PAS_Diva_Drc_Generator PAS_Diva_Lvs_Generator
15:47:43 (cdslmd) PAS_Dracula_Drc_Generator PAS_Dracula_Lvs_Generator PAS_ErrorCell_Generator
15:47:43 (cdslmd) PAS_Graphical_Tech_Editor PAS_Pcell_Generator PB_2S10PUC_ALL
15:47:43 (cdslmd) PB_2S15PUC_ALL
PB_2S20PUC_ALL
PB_2S40PUC_ALL
15:47:43 (cdslmd) PB_2S60PUC_ALL
PB_2SUPUC_ALL
PB_4S10PUC_ALL
15:47:43 (cdslmd) PB_4S40PUC_ALL
PB_4S60PUC_ALL
PB_4SUPUC_ALL
15:47:43 (cdslmd) PB_6S60PUC_ALL
PB_6SUPUC_ALL
PB_USUPUC_ALL
15:47:43 (cdslmd) PCB_designer
15:47:43 (cdslmd) pcb_editor
pcb_engineer
pcb_interactive
15:47:43 (cdslmd) PCB_librarian_expert pcb_prep
pcb_review
15:47:43 (cdslmd) PCB_studio_variants pcomp
Pearl
15:47:43 (cdslmd) Pearl_Cell
PE_Librarian
15:47:43 (cdslmd) Physical_Verification_Sys_L Physical_Verification_Sys_XL Physical_Verification_Sys_Deb
15:47:43 (cdslmd) PICDesigner
PIC_Utilities
PKS
15:47:43 (cdslmd) PlaceBase
PlaceBase_ALL
placement
15:47:43 (cdslmd) Placement_Based_Optimization Placement_Based_Synthesis PlaceOrIPlace_ALL
15:47:43 (cdslmd) PLD
plotVersa
PowerAnalysis
15:47:43 (cdslmd) PowerIntegrity
PP_2SUPUC_ALL
PP_4S40PUC_ALL
15:47:43 (cdslmd) PP_4S60PUC_ALL
PP_6S60PUC_ALL
PP_6S90PUC_ALL
15:47:43 (cdslmd) PP_6SUPUC_ALL
PPRoute
PPRoute_ALL
15:47:43 (cdslmd) Prevail_Board_Designer Prevail_Correct_By_Design Prevail_Designer
15:47:43 (cdslmd) Preview_Synopsys_Interface Protel_IF
PSpice
15:47:43 (cdslmd) PspiceAA
PspiceAD
PSpiceBasics
15:47:43 (cdslmd) PSpiceStudio
ptc_in
ptc_out
15:47:43 (cdslmd) PWM_LIB
QPlace
15:47:43 (cdslmd) QRC_Advanced_Modeling quanticout
15:47:43 (cdslmd) RapidPART
rapidsim
RB_2S10PUC_ALL
15:47:43 (cdslmd) RB_2S15PUC_ALL
RB_2S20PUC_ALL
RB_2S40PUC_ALL
15:47:43 (cdslmd) RB_2S60PUC_ALL
RB_2SUPUC_ALL
RB_4S10PUC_ALL
15:47:43 (cdslmd) RB_4S20PUC_ALL
RB_4S40PUC_ALL
RB_4S60PUC_ALL
15:47:43 (cdslmd) RB_4SUPUC_ALL
RB_6S60PUC_ALL
RB_6S90PUC_ALL
15:47:43 (cdslmd) RB_6SUPUC
RB_6SUPUC_ALL
RCExtraction
15:47:43 (cdslmd) RC-GXL
RC-L
realchiplm
15:47:43 (cdslmd) redifnet
RELXPERT
Route
15:47:43 (cdslmd) RouteADV
RouteADV_ALL
RouteBase
15:47:43 (cdslmd) RouteBase_ALL
RouteDF
RouteDFM
15:47:43 (cdslmd) RouteDFM_ALL
RouteFST
RouteFST_ALL
15:47:43 (cdslmd) RouteHYB
RouteHYB_ALL
RouteMin_ALL
15:47:43 (cdslmd) RouteMVIA_ALL
RouteOrEdit_ALL rt
15:47:43 (cdslmd) RTL_Compiler_Physical RTL_Compiler_RD RTL_Compiler_Ultra
15:47:43 (cdslmd) RTL_Compiler_Ultra_II_Option RTL_Compiler_Verification Schematic_Generator
15:47:43 (cdslmd) SDL_IF
sdrc_in
sdrc_out
15:47:43 (cdslmd) SDT_MODEL_MANAGER sepks
shapefill
15:47:43 (cdslmd) signal_explorer Signal_Integrity SignalIntegrity
15:47:43 (cdslmd) SignalStorm_Lib_Characterizer Signalstorm_NDC SignalStorm_Parallel_Sim
15:47:43 (cdslmd) signoise
SigNoiseCS
SigNoiseEngineer
15:47:43 (cdslmd) SigNoiseExpert
SigNoise_Float
SigNoiseStdDigLib
15:47:43 (cdslmd) Sigxp
sigxp_explorer
Sigxp_tier
15:47:43 (cdslmd) Sigxp_tier_EXPERT Silicon_Ensemble Silicon_Ensemble_CTS
15:47:43 (cdslmd) Silicon_Ensemble_DSM Silicon_Ensemble_DSM_Crosstalk Silicon_Ensemble_OpenDev
15:47:43 (cdslmd) Silicon_Ensemble_OpenExe Silicon_Ensemble_WARP SiliconQuest
15:47:43 (cdslmd) SiliconQuest_CTGen_Option Silicon_Synthesis_QPBS SimControl
15:47:43 (cdslmd) SimVision
15:47:43 (cdslmd) SiP_Digital_Architect_XL SiP_Digital_Layout_GXL SiP_Digital_SI_XL
15:47:43 (cdslmd) SiP_RF_Architect_L SiP_RF_Architect_XL SiP_RF_Layout_GXL
15:47:43 (cdslmd) SI_Timing_Convergence SI_Timing_Convergence_VS skillDev
15:47:43 (cdslmd) soce
SOC_Encounter
SOC_Encounter_GPS
15:47:43 (cdslmd) SOC_Encounter_GXL SOC_Encounter_L SOC_Encounter_XL
15:47:43 (cdslmd) SONYBNTI
SPECCTRA_256U
SPECCTRA_6U
15:47:43 (cdslmd) SPECCTRA_ADV
SPECCTRA_APD
specctra_autoroute
15:47:43 (cdslmd) specctra_designer SPECCTRA_DFM
specctra_expert
15:47:43 (cdslmd) specctra_expert_system SPECCTRA_HP
specctra_pcb
15:47:43 (cdslmd) specctra_performance SPECCTRA_QE
SPECCTRAQuest
15:47:43 (cdslmd) SPECCTRAQuest_EE SPECCTRAQuest_Planner SPECCTRAQuest_SI_expert
15:47:43 (cdslmd) SPECCTRAQuest_signal_expert SPECCTRAQuest_signal_explorer SPECCTRA_Unison_PCB
15:47:43 (cdslmd) SPECCTRA_Unison_Ultra SPECCTRA_VT
SpecialRoute
15:47:43 (cdslmd) specman
SpectreBasic
15:47:43 (cdslmd) Spectre_BTASOI_Models Spectre_Burst_AllegroSI SpectreHDL
15:47:43 (cdslmd) Spectre_NorTel_Models Spectre_Parallel_Analysis SpectreRF
15:47:43 (cdslmd) Spectre_Siemens_Models Spectre_ST_Models SPICE_IF
15:47:43 (cdslmd) SPW
SPW_BER_Sim
SPW_CGS_
15:47:43 (cdslmd) SPW_HLS
SPW_LSF_Link
SPW_MPX
15:47:43 (cdslmd) SPW_Smart_Antenna_Library SQ_Digital_Logic_SI_Lib SQ_FPGA_SI_Lib
15:47:43 (cdslmd) SQ_Memory_SI_Lib SQ_Microprocessor_SI_Lib stream_in
15:47:43 (cdslmd) stream_out
StudioPSpiceAD
STV90a
15:47:43 (cdslmd) Substrate_Coupling_Analysis Substrate_Noise_Analyst sv_surecov
15:47:43 (cdslmd) sv_suresight
swap
SWIFT
15:47:43 (cdslmd) sx
15:47:43 (cdslmd) synSmartLib
synTiOpt
TANCELL
15:47:43 (cdslmd) Test_Design_Analysis Test_Design_ATPG_Plus Test_Design_Compression
15:47:43 (cdslmd) Test_Design_Generation Test_Design_Verification Test_Extension_Language
15:47:43 (cdslmd) Test_Mfg_Fault_Isolation TimingAnalysis
TimingBudget
15:47:43 (cdslmd) transformal_ltx TrialRoute
tscr
15:47:43 (cdslmd) tsTestGen
tsTestIntf
tsTSynVHDL
15:47:43 (cdslmd) tsTSynVLOG
tune
tw01
15:47:43 (cdslmd) tw02
UET
ULMdelta
15:47:43 (cdslmd) ULMecho
ULMhotel
ULMindia
15:47:43 (cdslmd) ULMjuliette
ULMmike
ULTRASIM
15:47:43 (cdslmd) Unison_SPECCTRA_4U UNISON_SPECCTRA_6U Universal_Smartpath
15:47:43 (cdslmd) v2e
Vampire_HDRC
Vampire_HLVS
15:47:43 (cdslmd) Vampire_MP
Vampire_RCX
Vampire_UI
15:47:43 (cdslmd) VB_2S10PUC_ALL
VB_2S15PUC_ALL
VB_2S20PUC_ALL
15:47:43 (cdslmd) VB_2S40PUC_ALL
VB_2S60PUC_ALL
VB_2SUPUC_ALL
15:47:43 (cdslmd) VB_4S10PUC_ALL
VB_4S20PUC_ALL
VB_4S40PUC_ALL
15:47:43 (cdslmd) VB_4S60PUC_ALL
VB_4SUPUC_ALL
VB_6S60PUC_ALL
15:47:43 (cdslmd) VB_6S90PUC_ALL
VB_6SUPUC
VB_6SUPUC_ALL
15:47:43 (cdslmd) VB_USUPUC_ALL
VCC_Editors
15:47:43 (cdslmd) VCC_Simulators
15:47:43 (cdslmd) vc-signalscan
15:47:43 (cdslmd) verifault
15:47:43 (cdslmd) Verify
15:47:43 (cdslmd) VERILOG-XL
15:47:43 (cdslmd) VERITIME
vgen
VHDL_desktop
15:47:43 (cdslmd) VHDLLink
viable
ViewBase
15:47:43 (cdslmd) ViewBase_ALL
15:47:43 (cdslmd) Virtuoso_Acceler_Parallel_XL Virtuoso_APS_MMSIM_LK virtuoso_chip_editor
15:47:43 (cdslmd) VIRTUOSO_CM_OPTION_FOR_VSDE Virtuoso_Constraint_API Virtuoso_Core_Characterizer
15:47:43 (cdslmd) Virtuoso_Core_Optimizer Virtuoso_custom_placer Virtuoso_custom_router
15:47:43 (cdslmd) Virtuoso_Digital_implement Virtuoso_Layout_Migrate Virtuoso_Layout_Suite_GX
15:47:43 (cdslmd) Virtuoso_Layout_Suite_GXL Virtuoso_Layout_Suite_L Virtuoso_Layout_Suite_XL
15:47:43 (cdslmd) Virtuoso_Multi_mode_Simulation Virtuoso_NeoCircuit_DFM Virtuoso_Phase_Designer
15:47:43 (cdslmd) Virtuoso_QRC_Extraction_GXL Virtuoso_QRC_Extraction_L Virtuoso_QRC_Extraction_XL
15:47:43 (cdslmd) Virtuoso_Schematic_Editor_GXL Virtuoso_Schematic_Editor_L Virtuoso_Schematic_Editor_XL
15:47:43 (cdslmd) Virtuoso_Schem_Option Virtuoso_SiI
15:47:43 (cdslmd) Virtuoso_Spectre Virtuoso_Spectre_GXL Virtuoso_Spectre_RF
15:47:43 (cdslmd) Virtuoso_Spectre_XL Virtuoso_Sprectre_GXL_MMSIM_LK Virtuoso_Turbo
15:47:43 (cdslmd) Virtuoso_Turbo_Basic Virtuoso_Visual_Analysis_XL Virtuoso_XL
15:47:43 (cdslmd) Virtuoso_XL_Basic visula_in
VITAL-XL
15:47:43 (cdslmd) vloglink
vmanager
15:47:43 (cdslmd) VoltageStorm_UI VXL-ALPHA
VXL-LMC-HW-IF
15:47:43 (cdslmd) VXL-SWITCH-RC
VXL-TURBO
VXL-VCW
15:47:43 (cdslmd) VXL-VET
VXL-VLS
VXL-VRA
15:47:43 (cdslmd) wedifsch
WinPlace
WireEdit
15:47:43 (cdslmd) WLAN_Simulation_Runtime X4ENC
xilCds
15:47:43 (cdslmd) xilComposerFE
xilConceptFE
xilEdif
15:47:43 (cdslmd) Xilinx_FPGA
15:47:43 (cdslmd)
15:47:43 (cdslmd) All FEATURE lines for cdslmd behave like INCREMENT lines
15:47:43 (cdslmd)
15:47:53 (cdslmd) Vendor daemon can't talk to lmgrd (Cannot connect to license server system. (-15,570:115 "Operation now in progress"))
15:47:53 (cdslmd) EXITING DUE TO SIGNAL 37
 楼主| 发表于 2014-12-21 22:24:12 | 显示全部楼层
求大神指点哦,坐等大神哦
 楼主| 发表于 2014-12-22 09:24:10 | 显示全部楼层
坐等高手哦,高手快快现身吧
发表于 2015-1-13 23:59:25 | 显示全部楼层
坐等高手哦,高手快快现身吧
发表于 2015-1-14 15:48:50 | 显示全部楼层
回复 1# hasodron
   顶了!下来看看。
发表于 2016-11-1 19:57:52 | 显示全部楼层
Is it the universal crack flow for other cadence tools?
发表于 2017-2-8 13:22:37 | 显示全部楼层
感谢分享!多多学习!
发表于 2018-1-4 20:25:07 | 显示全部楼层
感谢分享!多多学习!
发表于 2021-3-9 10:37:09 | 显示全部楼层
请问楼主,问题解决了吗
GMT+8, 2025-12-19 10:30 , Processed in 0.094759 second(s), 6 queries , Gzip On, Redis On.
