查看: 1266|回复: 2
[招聘] 【Marvell招聘】ASIC DFT design Engineer
发表于 2014-12-15 17:52:26 | 显示全部楼层 |阅读模式
Job Title: ASIC DFT design Engineer
Job Description:
-Block, IP and SoC level DFT implementation (JTAG, Scan, Mbist andanalog/IP test etc.) and RTL integration;
-Participate in test spec/plan definition; create the DFT design documentand signoff DFT review checklists;
-Test patterns/vectors generation and verification;
-Interface to backend team on physical design and timing closure;
-Interface to test engineers on ATE and vectors bring-up and debugging;
-Chip DFT quality sign-off
-DFT STA, constraint generation, formal and timing closure
Qualifications:
- DFT design and integration experience
- Hands on DFT implementation experience(Bscan, Mbist, DC/AC Scan, analog IP test circuit integration, IDDQ test, ATPGand test pattern verification)
- Expertise with DFT tools from Synopsy,Mentor, Syntest etc.
- Strong logic design and verificationbackground
- Experience in Synthesis and STA willbe plus
- Proficient in Perl, tcl and shellprogramming
- BSEE degree or above
- Good team work spirit
If you are interested in the position, please send your resume to the following email address:   jiangrr@marvell.com
Subject of your email should be: School_Name_Applied position_Information source
Eg.SJTU_Zhang Peng _Data Analyst_BBS
发表于 2014-12-15 21:59:04 | 显示全部楼层
需要新人吗?
 楼主| 发表于 2014-12-16 15:06:09 | 显示全部楼层
回复 2# chen1q
   你好!我们这个职位是社招,一般看有一定工作经验的候选人!
GMT+8, 2025-12-27 12:14 , Processed in 0.037084 second(s), 4 queries , Gzip On, Redis On.
