楼主: snk88
ADS2015.01 win64/linux patch
发表于 2015-12-29 15:00:10 | 显示全部楼层
感谢楼主
发表于 2015-12-30 15:16:13 | 显示全部楼层
赞一个!!!!!!!
发表于 2015-12-31 11:13:21 | 显示全部楼层
dingdingding
发表于 2015-12-31 17:28:58 | 显示全部楼层
晕    搞完了还是不能用   lic加不进去
发表于 2016-1-1 22:36:40 | 显示全部楼层
ADS license installation on linux.
1. If working without local DNS /etc/hosts should be edited: one should add host IP address and hostname (ifconfig and hostname commands can be used).
2. Host ID (CPUID) has to be determined:
<PATH_TO_ADS_INSTALLATION_DIRECTORY>/Licensing/2014.07/linux_x86_64/bin/lmutil
3. The first line of the license file should be edited:
SERVER localhost INTERNET=*.*.*.* CPUID PORT
where CPUID was determined ealier, and for PORT should be chosen a TCP port number to avoid conflicts with other LM-servers.
4. For VENDOR_STRING phrase 112233445566 has to be replaced with INTERNET=*.* and for HOSTID phrase 112233445566 has to be replaced with INTERNET=*.*.*.*
5. Start license server:
<PATH_TO_ADS_INSTALLATION_DIRECTORY>/Licensing/2014.07/linux_x86_64/bin/lmgrd -c <PATH_TO_ADS_LICENSE_FILE>
This command can be added to /etc/rc.local to run license server on system boot.
ADS start with this license needs the next command:
export ADS_LICENSE_FILE=PORT@hostname
发表于 2016-1-1 22:39:05 | 显示全部楼层
The two variants of license file:
ads_license.lic.tar.gz (633 Bytes , 下载次数: 32 )
ads_license.lic.tar.gz (633 Bytes , 下载次数: 22 )
发表于 2016-1-3 18:40:33 | 显示全部楼层
软件在哪儿里
发表于 2016-1-4 21:18:47 | 显示全部楼层
回复 1# snk88
   谁安装LINUX版本成功啦!
发表于 2016-1-4 22:29:33 | 显示全部楼层
回复 1# snk88
   我装上了不行啊!
发表于 2016-1-4 23:43:25 | 显示全部楼层
TSMC 0.18um ads 2011 design kit and later
http://bbs.eetop.cn/viewthread.p ... %26amp%3Btypeid%3D1
GMT+8, 2025-12-12 13:46 , Processed in 0.021543 second(s), 6 queries , Gzip On, Redis On.
