查看: 15574|回复: 17
silvaco2012安装中SFLM server问题求助
发表于 2014-11-13 21:42:17 | 显示全部楼层 |阅读模式
[root@localhost 桌面]# sflm -i
/App/silvaco2012/lib/sflm_monitord/7.4.15.R/x86_64-linux/sflm_monitord.exe: Command not found.
Version of rpc.sflmserverd : 8.2.7.R
Version of sflm_monitord : 7.4.15.R
Setting SFLM administrative password.
New Password    ?
Running s_install version: 2.0.3.R  please wait...
Terminating SFLM RPC servers ... done.
Currently 40264472 KB free in /tmp (>= 8000)
Preparing to install the SFLM server daemon.
This procedure will modify or create the following system files:
        /etc/rc.d/init.d/sflm
Backups will be created in /var/tmp/s_install.bak
before any files are modified.
Run '/App/silvaco2012/etc/s_install -rm-bak' or
'/var/tmp/s_install.bak/remove' to remove backup files.
Do you wish to proceed? [y|n] y
Verifying permissions ... done.
Installing servers in init.d ...
Backing up /etc/rc.d/init.d/sflm to /var/tmp/s_install.bak/bak.sflm~1~ ... done.
Installation done.
Starting and verifying servers ...
/App/silvaco2012/lib/rpc.sflmserverd/8.2.7.R/x86_64-linux/rpc.sflmserverd.sh: /App/silvaco2012/lib/rpc.sflmserverd/8.2.7.R/x86_64-linux/rpc.sflmserverd.exe: /lib/ld-linux.so.2: bad ELF interpreter: 没有那个文件或目录
rpcinfo: RPC: Program not registered
Verification failed for sflm on host localhost.localdomain.
 楼主| 发表于 2014-11-14 11:03:05 | 显示全部楼层
请问我是少装了什么包吗
 楼主| 发表于 2014-11-15 10:54:03 | 显示全部楼层
ding one time for myself
 楼主| 发表于 2014-11-16 10:04:38 | 显示全部楼层
ding ding more healthy
发表于 2014-11-16 12:49:16 | 显示全部楼层
同样的问题
发表于 2014-11-28 19:23:28 | 显示全部楼层
WOYEYUNXINGBULIAO
发表于 2014-12-30 12:19:47 | 显示全部楼层
sflm.exe没有安装成功吧,或者你用的redhat版本不够高安装不能成功
发表于 2015-5-17 14:34:13 | 显示全部楼层
同样的问题,楼主如果解决了,可以分享下吗
发表于 2015-6-10 01:41:29 | 显示全部楼层
我的问题也一样……下面是记录
[root@localhost gordonbai]# /home/gordonbai/Silvaco/TCAD/lib/sflm_monitord/7.4.16.R/x86_64-linux/sflm_monitord.exe: Command not found.
/home/gordonbai/Silvaco/TCAD/lib/deckbuild/3.44.12.R/x86_64-linux/deckbuild.exe: Command not found.
sflm -i
Version of rpc.sflmserverd : 8.2.10.R
Version of sflm_monitord : 7.4.16.R
New Password    ?
Currently 6679664 KB free in /tmp (>= 8000)
Run '/home/gordonbai/Silvaco/TCAD/etc/s_install -rm-bak' or
Installation done.
/home/gordonbai/Silvaco/TCAD/lib/rpc.sflmserverd/8.2.10.R/x86_64-linux/rpc.sflmserverd.sh: /home/gordonbai/Silvaco/TCAD/lib/rpc.sflmserverd/8.2.10.R/x86_64-linux/rpc.sflmserverd.exe: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
rpcinfo: RPC: Port mapper failure - Unable to receive: errno 111 (Connection refused)
RPC server verification failed.
发表于 2015-6-19 14:04:01 | 显示全部楼层
回复 9# IgniteWhite
   请问你这个问题解决了吗?我今天也遇到了,但是不知道该怎么解决。谢谢
GMT+8, 2025-12-14 07:32 , Processed in 0.019599 second(s), 5 queries , Gzip On, Redis On.
