查看: 33778|回复: 32
[求助] DC综合生成的ddc文件
发表于 2014-11-12 17:05:30 | 显示全部楼层 |阅读模式
资料里有说:dc_shell does not automatically save the designs loaded in memory. If you want to
save these designs before exiting, use the write command. For example,
dc_shell> write -format ddc -hierarchy -output my_design.ddc
那么,这个ddc文件是存入的什么内容呢 我看网上有说是db文件内容的,是吗?用什么可以打开呢
求大神告知
发表于 2014-11-12 18:32:15 | 显示全部楼层
回复 1# 522526tl
   在dc_shell里面read_ddc,就可以读取保存的信息(上次综合的全部数据)
 楼主| 发表于 2014-11-12 18:47:31 | 显示全部楼层
回复 2# seulzren
恩,确实打开了,里面内容大致如下:
Loading db file '/home/szl/software/synopsys/DC2009/libraries/syn/gtech.db'
Loading db file '/home/szl/software/synopsys/DC2009/libraries/syn/standard.sldb'
  Loading link library 'gtech'
Reading ddc file '/home/szl/project/new_backend/DC/calibration_top.rpt.201305141254/calibration_top.ddc'.
Loaded 157 designs.
Warning: Unable to find specified driving_cell for port 'clk_800M'. (DDB-81)
Warning: Unable to find specified driving_cell for port 'rst_n'. (DDB-81)
... (省略一些行)
mul_gain_cal_0_DW01_add_0 mul_gain_cal_0_DW01_add_1 mul_gain_cal_0_DW01_add_2 mul_gain_cal_0_DW01_add_3 mul_gain_cal_0_DW01_add_4 mul_gain_cal_0_DW01_add_5 mul_gain_cal_0_DW01_add_6 mul_gain_cal_0_DW01_add_7 mul_gain_cal_0_DW01_add_8 mul_gain_cal_0_DW01_add_9 mul_gain_cal_0_DW01_add_10 mul_gain_cal_0_DW01_add_11 mul_gain_cal_0_DW01_add_12 mul_gain_cal_0_DW01_add_13 mul_gain_cal_0_DW01_add_14 mul_gain_cal_0_DW01_add_15 mul_gain_cal_0_DW01_add_16 mul_gain_cal_0_DW01_add_17 mul_gain_cal_0_DW01_add_18 mul_gain_cal_0_DW01_add_19 mul_gain_cal_0_DW01_add_20 mul_gain_cal_0_DW01_add_21 mul_gain_cal_0_DW01_add_22 mul_gain_cal_0_DW01_add_23
看前两行,那是不是就是说ddc其实就是db文件内容,但是db文件内容不是那些吧,还有看最后这几行,ddc文件又和verilog.net文件很像
求指导
发表于 2014-11-13 09:00:35 | 显示全部楼层
回复 3# 522526tl
1.clk_800M是时钟信号吗?2.db是std cell、IP、memory等的时序、功耗等信息,可以由lib转得,相应的lib文件你打开看看就知道了;
3.ddc包含了设计的信息,跟db不一样
发表于 2014-11-13 10:43:54 | 显示全部楼层
ddc主要是design相关信息,包括timing ,db,lib等,
 楼主| 发表于 2014-11-13 10:52:59 | 显示全部楼层
回复 5# icfbicfb
多谢版主 再问个小问题啊手册上说:
You can use the report_reference command to report information about all references in
the current instance or current design
我的出现如下表格:
Attributes:
    b - black box (unknown)
   bo - allows boundary optimization
    d - dont_touch
   mo - map_only
    h - hierarchical
    n - noncombinational
    r - removable
    s - synthetic operator
    u - contains unmapped logic
Reference          Library       Unit Area   Count    Total Area   Attributes
**SEQGEN**                        0.000000     520      0.000000  n, u
*SELECT_OP_2.8_2.1_8              0.000000       1      0.000000  s, u
*SELECT_OP_64.8_64.1_8            0.000000       1      0.000000  s, u
GTECH_AND2         gtech          0.000000      74      0.000000  u
GTECH_BUF          gtech          0.000000      66      0.000000  u
GTECH_NOT          gtech          0.000000     134      0.000000  u
GTECH_OR2          gtech          0.000000     758      0.000000  u
想问下,比如 最后一行中的出现的 u 什么意思呢 是说 这个2输入的或门 contains unmapped logic??
 楼主| 发表于 2014-11-13 10:55:45 | 显示全部楼层
回复 5# icfbicfb
哦 多谢版主 但貌似没看到timing的信息
发表于 2015-7-9 18:26:41 | 显示全部楼层
回复 7# 522526tl
   楼主 你怎么看的.ddc文件,我输入read_ddc 工程名.ddc 只显示load进去了,如何查看这个ddc文件呢。。、。。。。 求解解
发表于 2015-7-9 20:52:57 | 显示全部楼层
回复 7# 522526tl
   这个是有的,打开设计可以用一些命令查看 时序信息。
发表于 2016-1-4 21:23:53 | 显示全部楼层
学习了
GMT+8, 2025-9-17 19:20 , Processed in 0.320117 second(s), 6 queries , Gzip On, Redis On.
