楼主: istart_2002
[原创] Asymmetric LDMOS 可以做传输门么?
 楼主| 发表于 2014-11-1 12:40:01 | 显示全部楼层
发表于 2022-8-31 10:56:29 | 显示全部楼层
mpig09 发表于 2014-10-30 22:54
Hi istart_2002:
You need to check VGS when the X=Y is meet device property or not.
Hi mpig09:
Here is a question I want to consult you that how to design the gate control circuit of this P-LDMOS switch when its source is connected to a cap and drain is connected to a PAD which its voltage varies  from zero to high voltage?Look forward to your reply!
Thank you!
发表于 2022-8-31 11:08:40 | 显示全部楼层
前辈,请教一下,在一些stepwise对电容充放电的情况下, 会用p-LDMOS做开关,其source会接到电容,在建立过程中,source电压从0V逐渐升到平衡高压,那么他的栅极控制电路怎么去设计呢?既使他建立过程中能不断切换导通关断,也能不过压击穿栅氧,因为Vgs<5V
GMT+8, 2025-9-16 05:20 , Processed in 0.016062 second(s), 4 queries , Gzip On, Redis On.
