查看: 1201|回复: 0
[招聘] Synopsys SH/SZ 急招DDR CAE
发表于 2014-10-17 17:43:09 | 显示全部楼层 |阅读模式
[table]
If you have any interest in the position, please send your bilingual resume as
attachments to
dmliu@synopsys.com
[table]
[table]
[table]
Synopsys DDR PHY CAE
http://search.51job.com/job/62297691,c.html
Description
As a Corporate Applications Engineer (CAE) team in the Solutions Group at Synopsys, you will be responsible for technical support of customers using Synopsys DesignWare DDRn IP. You will analyze and resolve complex IP usage issues and provide timely, accurate technical guidance to customers. You will be interfacing with our Design Engineering team to report on any issues related to the IP’s design, reliability and maintenance or defects
Requirements
Qualified applicants will have a BSEE, MSEE, + 5 years relevant experience in ASIC design.
Strong communication skills and ability to interact with customers as well as peers is required.
Recent experience with ASIC implementation EDA tools and flows in the areas of Synthesis, Simulation, STA, Verification, Testability, Place and Route, Design Reuse and/or Physical Design is highly desired.
Domain knowledge of the DDR3/2 Protocols with relevant experience is a plus.
Hardware debug and troubleshooting skills are highly desirable.
Relevant experience in design, implementation or technical support with mixed signal designs is highly desired.
[/td][/tr]
[/table][/td][/tr]
[/table][/td][/tr]
[/table][/td][/tr]
[/table]
GMT+8, 2025-12-27 08:40 , Processed in 0.027224 second(s), 3 queries , Gzip On, Redis On.
