查看: 4461|回复: 1
[求助] cadence QRC提参遇到hierarchical edge file的error
发表于 2014-9-28 17:04:11 | 显示全部楼层 |阅读模式
在后端区发的帖沉了,转这里请教高手
小弟正在尝试calibre LVS+QRC的提参流程,工艺是SMIC 28nm PS,遇到以下两方面问题,求给建议
软件及环境:
1)Redhead 5
2)Cadence IC 6.1
3)Cadence Extraction QRC - Parasitic Extractor - Version 10.1.3-p065
(安装文件用的http://bbs.eetop.cn/thread-355374-1-1.html,patch将就用的IUS 9.2http://bbs.eetop.cn/thread-268069-1-1.html
4)calibre 2013.3_39.24
一、virtuoso layout XL无法加载QRC UI
按网上说明,在cdsinit文件加入配置,但layout工具栏上仍然看不到QRC的调用按钮。
二、使用命令运行QRC,生成capfile时报错
报错信息
WARNING (LBMISC-215001): file 'via1' is not a flat edge file
ERROR (LBMISC-215002):
it is a hierarchical edge file
做LVS时已选择Flatten
QRC命令行流程:
1. run lvs by GUI with lvs.cmd (fab provided), and make a clean result
2. run lvs by GUI with xrc.cmd (edited from lvs.cmd according to fab‘s guidance).
3. run calibre:calibre -query_input query_cmd -query svdb xrc_test
4. run:qrc -cmd qrc_cmd
qrc_cmd file:
output_setup -temporary_directory_name qrc_output
log_file -file_name qrc_output/qrc.log
process_technology -technology_library_file "qrc_rule/QRC_28PS_1P8M_6Ic_2TMc_ALPA1_V0.5_1T/rulefiles/tech.lib" -technology_name CMAX
input_db -type calibre -directory_name query_output -run_name Design -layer_map_file query_output/Design.gds.map -device_property_value 7 -instance_property_value 6 -net_property_value 5 -library_cell_list_file qrc_rule/assura_QRC/preserveCellList.txt -hierarchy_delimiter \/ -design_cell_name test_qrc av_extracted test_qrc
output_db -type dspf
qrc.log file:
(前面运行内容省略)
# Run pax16 to generate capfile
pax16 -V -scf sip.cmd -M_perim_off -cgnd ${CAP_GROUND},1.0 -c \
/home/yangsy/tmp/28qrc/xrc_test/qrc_rule/QRC_28PS_1P8M_6Ic_2TMc_ALPA1_V0.5_1T/rulefiles/CMAX/qrcTechFile \
-f FOXA active poly metal1 metal2 metal3 metal4 metal5 metal6 metal7 \
metal8 alpa_inter - \
- - NET - capfile
rdpaxcmd took
0.35 user, 0.15 sys, 1.00 elapsed, 47952.0 kbytes
ERROR (LBRCXM-609): Bad return status from RCX run. 0xff00
INFO (LBRCXM-709): *****
QRC terminated abnormally
发表于 2017-4-20 12:53:43 | 显示全部楼层
very nice info, thanks for sharing
GMT+8, 2025-12-29 14:03 , Processed in 0.017229 second(s), 6 queries , Gzip On, Redis On.
