楼主: 尘下之尘
[求助] VCO的共模差模死锁如何进行理论上的分析推导
发表于 2023-7-19 11:34:43 | 显示全部楼层
M.S.Liao 发表于 2023-7-18 17:58
请问共模死锁的原因是什么???
no idea, since never heard of it.
发表于 2023-7-19 15:35:40 | 显示全部楼层
就是说,因为一个delay cell是有正反馈,有latch,然后存在一个状态,vco没有振起来。一直维持01010101。
发表于 2023-7-19 15:52:57 | 显示全部楼层
這是因為differetial gain不夠大
发表于 2023-7-23 12:53:11 | 显示全部楼层
M.S.Liao 发表于 2023-7-19 15:35
就是说,因为一个delay cell是有正反馈,有latch,然后存在一个状态,vco没有振起来。一直维持01010101。 ...
do not think this can be sustained. I would still think all the stages might act like an amplifier (linear circuit) so the output is low-high-low-high..., the low and high here are not logic level.
but could this happen?
发表于 2023-7-24 16:55:01 | 显示全部楼层
icdane 发表于 2023-7-23 12:53
do not think this can be sustained. I would still think all the stages might act like an amplifier ...
额,可不可以说中文,看不懂。。。
发表于 2024-8-1 10:23:24 | 显示全部楼层
中式英语
发表于 2024-8-1 10:33:21 | 显示全部楼层
尘下之尘 发表于 2014-9-9 17:20
共模死锁 :
0 1 0 1
0 1 0 1
差模不会锁死,偶数阶的差分环振其中一级一般要反接,否则不起振
发表于 2024-8-2 13:36:09 | 显示全部楼层
enable的时候我一般给一个初始电压,强制他差模震荡
GMT+8, 2025-12-25 14:58 , Processed in 0.016359 second(s), 3 queries , Gzip On, Redis On.
