查看: 2713|回复: 2
[求助] 求ieee论文
发表于 2014-8-22 13:56:37 | 显示全部楼层 |阅读模式
Quadratic-translinear CMOS multiplier-divider circuit
A novel current-mode analogue multiplier-divider based on the quadratic-translinear principle is presented. The input and output signals are all in current-mode. The circuit has favourable precision, wide dynamic range and is insensitive to variations in temperature and processing. It is suitable for VLSI implementation and can be used in many hardware design fields such as fuzzy logic controllers and analogue neural networks
Published in:Electronics Letters        (Volume:33                        ,                                   Issue:                                        10                        )        Date of Publication:                                8 May 1997                                                 Page(s):                                                860                                                -                                                861                                         ISSN :                                        0013-5194                                 INSPEC Accession Number:                                        5593078                                 DOI:10.1049/el:19970611                                 Date of Current Version :                                        06 八月 2002                                 Issue Date :                                        8 May 1997                                 Sponsored by :Institution of Engineering and Technology                                 Publisher:IET
非常感谢
发表于 2014-8-23 12:15:09 | 显示全部楼层
Hope it helps, FYI
IEEE00592611.pdf (234.09 KB , 下载次数: 4 )
 楼主| 发表于 2014-8-25 09:14:36 | 显示全部楼层
非常感谢
GMT+8, 2025-12-22 05:27 , Processed in 0.021815 second(s), 9 queries , Gzip On, Redis On.
