查看: 3335|回复: 0
[原创] 各位大侠,小弟在CCS环境下调试程序遇到一个问题,向各位请教
发表于 2007-3-27 10:28:25 | 显示全部楼层 |阅读模式
>>   error: relocation overflow occured at address 0x00000100 in section
            'vectors' of input file 'D:\dspyuyin\Dsp\vectors.obj'.  The 32-bit
            PC-relative displacement -536844631 at this location is too large
            to fit into the 21-bit PC-Relative field; the destination address
            is too far away from the instruction. You may need to add a mask to
            the assembly instruction or use other target specific assembly
            features if you really only need the lowest 21 bits of this symbol.
            Please see the section on Relocation in the Assembly User's Guide.
究竟这是怎么回事呀?怎么解决这个问题?请大家帮帮忙.
  之前我搜索一下,看到有人说选择Project->Build Options->Compiler->Advanced->Memory  Models
选择Far Calls & Far Data,但是我已经按照这样做了.可是还是不行...希望大家给点建议,谢谢
GMT+8, 2025-12-18 20:19 , Processed in 0.018729 second(s), 6 queries , Gzip On, Redis On.
