查看: 13883|回复: 47
[招聘] 2015年英伟达(NV)校园招聘开始了~~ 地点包括(上海深圳天津北京)
发表于 2014-8-17 19:28:08 | 显示全部楼层 |阅读模式
由于上次更新没有包括深证天津北京的职位,这次统一更新下~
如果你对下面的岗位感兴趣,可以讲简历发给我,可以包含2个志愿。当然如果有什么不明白的,也可以问我
邮箱:nvidia.china.hr@gmail.com  格式:姓名-学校-专业-第一志愿 -第二志愿
上海
硬件研发类
1 .Job Title: ASIC Physical Design Engineer
Department: GPU
As a result of the improvement in chip process, design scale and performance/power ratio expectation, physical design for digital chips have huge challenges on high frequency, low power, multiple application modes etc. Effective and high quality implementation of building chips is the guarantee of the company’s competitiveness.
As an ASIC-PD engineer at NVIDIA, you'll be responsible for the stage from RTL frozen to tape out, include synthesis, formal verification, constraints definition, timing closure/sign off, study on the timing impact of process and related methodology work. You will face the biggest challenge based on the most advanced processes on building chips in the world.
随着芯片工艺不断进步,设计规模的增大,对性能/功耗比期望的提高,数字芯片物理设计面临着高时钟,低功耗,多应用模式等巨大挑战。芯片的高效和高质量的物理实现是公司竞争力的保证。
作为NVIDIA的ASIC-PD工程师,你将负责从RTL冻结到流片这个阶段中综合,形式验证,约束文件制定,时序收敛以及相关方法学和工艺在时序方面影响的研究工作。在芯片实现方面,你将基于世界上最先进的流程面临最大的挑战。
Responsibilities:
Chip integration and netlist generation
Synthesis
RTL/netlist quality check
Formal Verification
Constraints creation and validation, timing budget.
Work with ASIC team to analyze/resolve special timing issues.
Co-work with PR engineers to implement chip partition and floorplan
Work in conjunction with RR engineers to achieve timing closure for both partition and full chip level
Achieve special mode timing closure, such as io, test etc.
Function eco creation
Develop and enhance entire timing closure flow from frontend (pre-layout) to backend (post-layout)
Flow automation development for above areas
Methodology in any of above areas.
芯片集成,网表生成
综合,网表质量分析
逻辑等价性验证
约束文件的创建和验证, 产生底层模块时序约束
与前端工程师一起分析解决时序问题
与P&R工程师合作完成芯片物理实现模块划分
芯片级和模块级时序分析和时序收敛
特殊工作模式的时序分析和时序收敛, 如IO,TEST等
产生功能ECO脚本
以上领域流程的开发,维护和增强
以上领域方法的研究
Requirements:
BSEE, MSEE is preferred
Project experience in IC design implementation
Courses taken in circuit design, digital design
Hand-on experience in EDA software from Synopsys (DC/PT/Formality), Cadence (RC compiler/LEC) is preferred
Proficient user of Perl or TCL is preferred
Excellent English communication skill
电子工程或相关专业硕士生或本科生
有芯片设计经验
有相关课程背景:电路设计,数字电路
有相关EDA工具使用经验者优先:Synopsys (DC/PT/Formality), Cadence (RC/LEC)
具有脚本编写能力者优先:Perl, TCL
良好的英语交流能力
2 . Job Title: VLSI Physical Design Engineer
Department: GPU
Responsible for all aspects of physical design (netlist->gds) of all chips at NVIDIA® (including GeForce®/Tegra™/Tesla™/Quadro™)
Work on floorplan, power/clock distribution, placement, routing, timing/power/noise analysis, chip assembly, and physical verification
Minimum Requirement:
MS in Microelectronics or related major
Courses taken in IC design or digital circuit design
Knowledge of device model, processing technology, or chip design
Preferred Requirement:
Project experience in IC design or ASIC design flow
Hands-on experience in EDA tools (physical design/verification, timing analysis or layout)
Familiar with Perl/Tcl/Shell scripting
工作内容:
负责NVIDIA® (英伟达™)公司所有芯片(包括GeForce®,Tegra™,Tesla™,Quadro™等系列)的物理设计及其实现的工作(Netlist->GDS)
致力于:
芯片规划及布局
电源/时钟分布及规划
布局布线
静态时序/功耗/噪声/信号完整性分析
物理验证
基本要求:
微电子及相关专业硕士生
有相关课程背景:集成电路设计或数字电路设计
有以下知识:器件模型,制造工艺,芯片设计
优先条件:
有数字芯片项目设计经验或者使用ASIC设计流程的经验
有EDA工具(物理设计验证,时序分析,版图设计等)的使用经验
有使用Perl,Tcl,和Shell等语言编写脚本的能力
3. Job Title: DFT Engineer
Department: GPU
Job Description/Requirements:
Design for Testability (DFT) has become a big challenge to VLSI and SOC design as a result of the unprecedented levels of design complexity and advanced manufacturing technologies. Effective and high quality testing is extremely important for IC products especially the high end products. DFT is a must to guarantee high quality of testing hence high quality and reliability of IC products. Moreover, DFT is a significant method to reduce test cost. Nowadays, DFT is also required to provide useful means for debug and diagnosis at chip/board/system level, which is Design for Debug and Diagnosis (DFD).
As a DFT engineer at NVIDIA, you'll be responsible for cutting edge DFT involving designing key DFT logic modules and verifying them. These include test mode controllers, IO bist, Memory Bist/Repair and Jtag. In addition you will be responsible for scan insertion,ATPG post silicon validation.
随着IC设计复杂度的空前增加和制造工艺的发展,可测性设计(DFT)逐渐成为芯片设计面临的巨大挑战。有效的高质量测试对芯片产品尤其是高端芯片产品变得越加重要。DFT技术是保证芯片高质量和高可靠性的必然选择,也是降低测试成本最重要的方法。此外,DFT技术也可以为芯片级,板级和系统级的调试(Design for Debug and Diagnosis)和验证提供有效途径和方法。
作为一个NVIDIA的DFT 工程师, 你所从事的将是第一流的DFT工作 。你会有机会设计和验证DFT的关键逻辑模块(测试模块控制,IOBIST, MBIST 和 JTAG)。此外, 你还可以接触到SCAN的插入,ATPG和流片后的测试工作
Responsibilities:
Responsible for DFT feature implementation and verification
Developing testbench and test procedures/scripts
Verifying Clock, Analog, JTAG, Boundary Scan, MBIST, Scan/ATPG, etc.
Generating test vectors and doing post silicon validation
Improving dft implementation and verification flow
负责相关DFT结构的实现和验证
完成相关的测试平台和测试脚本
完成对Clock, Analog, Jtag, Boundary Scan, MBIST, Scan/ATPG等相关部分的验证
负责产生测试向量并完成流片后的测试工作
优化DFT设计和验证流程
Requirements:
MSEE
Strong logic design and verification background
Possess basic knowledge of DFT (Scan/ATPG, MBIST, JTAG, etc.)
Skilled in Perl/tcl programming
Proficient at Verilog HDL
Prefer to have experience with logic simulators and debug tools (such as vcs, ncsim, verdi)
Familiar with C/C++, Makefile is a plus
Strong problem solving and analytical skills
Excellent communication skills and teamwork
硕士研究生学历
具有熟练的数字逻辑设计和验证背景
精通Tcl和Perl 脚本语言
能够熟练运用Verilog HDL语言进行数字逻辑设计
熟悉IC设计和调试工具(例如VCS, nvsim ,verdi等)
熟悉C/C++程序设计语言设计
具有较强的分析问题和解决问题的能力
优秀的沟通和合作能力
4. Job Title: Mask Layout Design Engineer
Department: GPU
Responsibilities:
Perform full-custom digital IC mask layout in ultra-deep submicron processes
Main Projects include Memories and Standard cells
Verification include all aspects of mask requirements, such as DRC/LVS, RC extraction, EM/IR and various requirements for special circuits
Layout data generation, maintain and quality control.
完成全定制数字电路掩膜设计在超深亚微米工艺
主要计划包含存储单元设计和标注单元库设计
掩膜验证包含全部传统验证部分如基本规则检查,逻辑连接检查,参数提取,电迁移,电压降, 以及各种针对不同电路模块特别的检查
掩膜数据的产生维护以及质量控制
Requirements:
BS or above in Electronics, Microelectronics or related fields
Basic knowledge of semiconductor physics and mask layout design
Good working knowledge of Unix required
Good command of written and spoken English
Experience of using common industry standard tools likes Virtuoso, Hercules/Calibre(plus)
Rich imagination in tri-dimensional graphics---(plus)
本科及以上学历,微电子或相关专业
基础半导体物理及相关掩膜设计知识
良好的unix使用能力
良好的英语读写能力
使用过业界常用设计工具例如Virtuoso、Calibre、Hercules(加分项)
具有丰富的三维图形想象能力(加分项)
5. Job Title: Circuit Design Engineer
Department: GPU
Responsibilities:
High performance, low power custom digital circuit design for graphic processors.
Circuit architecting, simulation and characterization of custom design circuit.
Logic equivalence checking and transistor level function verification.
Participating in building CAD flow for circuit design.
Layout floor planning and supervision.
高性能、低功耗定制数字电路设计
设计定制电路的电路结构、进行电路仿真和特征化参数提取
逻辑等效性检查和晶体管级功能验证
参与建立电路设计的CAD流程
版图规划和监督检查
Requirements:
BSEE minimum, MSEE preferred.
Strong background in deep submicron CMOS process and device.
Good knowledge in high speed digital circuit design techniques.
Understanding of on-chip inter connect and signal integrity.
Experience in circuit simulation, schematic capture and layout verification CAD tools.
Must be a team player with effective written and verbal communication skills.
Must be able to learn quickly and work independently.
Preferably if the applicant could come in early to serve as an intern till the graduation month; the training could be provided since the internship.
Key words: CMOS, digital circuit, SRAM, STD cell, ROM
本科及以上学历
对深亚微米CMOS工艺和器件有深入了解
熟悉高速数字电路设计
了解芯片互连线和信号完整性
熟悉电路仿真、电路图和版图生成及验证工具
具有团队合作精神,有很好的书面和口头的沟通技巧
有很强的学习能力,能独立工作
能够尽快入职、实习者优先考虑
二 、软件研发类
1 Job Title: System Design Software Engineer (GPU Architect)
Department: GPU
Responsibilities:
We are looking for world class engineers to design, model, analyze and verify next generations of GPU architecture.
The candidates will work with a group of architects to design and develop proprietary internal tools for the visualization, analysis, and debug and verification of tests and applications on various functional and performance simulations of future chips.
The candidates will have opportunities to get involved in cutting-edge GPU macro- and micro-architecture design, verification and optimization, including porting commercial applications to test benches, identifying performance hotspots and data mining for performance analysis.
NVIDIA需要世界级的工程师与我们一起对未来的GPU体系结构进行设计,分析,建模与验证。
应聘者将与一组架构师一起,设计和开发自有知识产权的工具,用于分析、验证和调试GPU芯片的功能与性能。
应聘者将有机会参与世界领先的GPU设计、验证与优化工作,包括将商用程序移植为测试用例,分析系统的性能热点以及为性能分析进行数据挖掘等。
Requirements:
Bachelor’s Degree or higher majoring in CS/EE/Mathematics or relevant fields
Strong C/C++ programming ability. Scripting language (Perl, Python, Ruby) experience is a plus.
Strong problem solving capability, analytical and communication skills.
Proactive, creative and a team player.
Excellent English writing for engineering documentation, English oral well enough to attend meetings.
Experience in the following areas is a plus:
Microprocessor architecture design & verification.
3D graphics (D3D or OpenGL) application development.
Multimedia (video, image processing, visualization) application development
System level programming experience in OS, compiler, driver, tools, virtual memory system, etc.
Parallel computing/CUDA/OpenCL/HPC development.
本科以上学历,计算机/电子/数学或相关专业。
较强的C/C++编程能力。熟悉脚本语言(Perl, Python, Ruby)尤佳。
思维条理清楚,解决问题能力强,善于沟通。
积极主动,具有创造力和团队精神。
英文听说读写出色,可以用英文撰写技术文档和参加会议。
具备下列领域相关经验者尤佳:
微处理器体系结构设计或验证
3D图形软件开发(D3D或OpenGL)
多媒体软件开发(视频,图像处理,数据可视化)
系统级编程经验(操作系统,编译器,驱动程序,除错工具,虚拟内存系统等)
并行计算/CUDA/OpenCL/HPC开发
2 Position: Web/Database Applications Architect
Department: GPU
Job Description:
The NVIDIA Architecture group is looking for a web applications software engineer to develop the user interface and front end application for comprehensive workflows for the development of new graphics chips. This software development team is a fast-paced Agile software team with extremely high production quality standards producing tools used by engineering across the company for tracking and debugging operational and development issues.
In this position, you will in your ownership of the full tool development and release life-cycle, drive the UI design, database interaction, development, testing, and deployment. You will evaluate technology alternatives, work closely with other project members and users to specify the system, create schedules, and manage ongoing feedback and enhancement releases. You will learn and greatly improve the daily workflows of the world’s top chip modelers and designers.
MINIMUM REQUIREMENTS:
- Experience in developing web-based user interfaces and applications
- Experience with databases a requirement – MySQL or Postgress strongly preferred, No-SQL experience a plus
- Strong object-oriented programming background - Java or C# required
- Experience with Excel programming and the Excel Object Model a big plus
- Strong dynamic language skills a plus – Perl or python preferred
- BS in Computer Science preferred
- Excellent communication skills
- Flexibility/adaptability for working in a dynamic environment with different frameworks and requirements
3 . Job Title: Tesla/CUDA Cuda Automation Triage QA Engineer
Department: SW
Responsibilities:
GPU testing for GPU Computing with CUDA to ensure functionality and compatibility.
Triage CUDA nightly failures on a daily basis to determinate per changelist regressions.
Improve cuda infrastructure by finding out, fixing and implementing cuda infrastructure bugs.
Performance white box testing on CUDA modules.
Requirements:
Current master degree students in EE or CS
Solid Linux skills and strong windows knowledge
Strong C++ programming skills
Excellent problem-solving and critical thinking
Scripting language (Perl, Python) experience is plus.
Familiar with GPU computing is a plus
Strong verbal and written communication skills
Hands-on experience with hardware and software configuration is plus
4. Position: Embedded System Software Engineer
Department: SW
Job Description:
The candidate will participate in the Android-based software development for NVIDIA's new Tegra platforms including but not limited to Android based devices drivers, multimedia, frameworks, kernel and performance/power optimization.
You will have the opportunity to seamlessly work with HQ for cutting edge technologies, and also have opportunity and flexibility to create new innovations.
RESPONSIBILITIES:
- Design and implement software in an embedded software environment.
- New technology research and system architecture design.
- Work with hardware architects on the design of embedded products, providing feedback and guidance on CPU, bus, and device design to ensure that it can be supported well by software.
- BS or MS degree in EE/CS/CE
- Excellent C programming and debugging skills.
- Ability for strong problem solving and logical analysis skills.
- Ability for good English reading and writing.
- Good knowledge of operation system (esp. Android, Linux) is a major plus.
- Good knowledge of communication technology (LTE, WCDMA etc) is a plus.
岗位描述:
为英伟达最新Tegra芯片开发基于Android平台的软件,包括但不限于Linux内核驱动、多媒体框架、性能优化、功耗调试等。
在这里您将有机会在业界领先的公司参与最新技术的研究与开发,并让您有机会展现你无限的创造力。
工作职责:
-基于Android平台的软件设计与开发
-新技术的研究与实现
-实现Tegra参考设计的软件需求,并给出反馈意见及建议
职位要求:
-计算机,通信,电子相关专业的学士或硕士(或同等学历)
-精通C编程以及调试技巧
-对创新及解决具有挑战性的问题充满激情
-具有较强的英文沟通能力
-熟悉Android,Linux优先
-熟悉通信技术(LTE、WCDMA)优先
深圳:
硬件研发:
1.Design Verification Engineer:
Job Title: Design Verification Engineer
Department: GPU
Board/System Qualifying Engineer for mobile systems and graphics products. This position will be responsible for qualification and signal integrity measurement of state-of-the-art board level/system level using NVIDIA silicon chip products. Qualification and signal integrity measurement may include tablet motherboards, graphics cards, embedded system products, multimedia systems, and more. Contribute system and board level engineering expertise to specification and design of the latest complex products. Successful candidate will be in a dynamic engineering environment, with the opportunity to participate in a wide variety of exciting and challenging projects.
显卡和移动产品的板级/系统级验证工程师。该职位将负责使用NVIDIA芯片产品对最先进的板极/系统级产品进行验证和信号完整性测量,可能包括平板电脑主板,显卡,嵌入式系统产品,多媒体系统及其他。运用系统和板级工程的专业知识对最新的复杂产品进行加工和设计。应聘成功者将会在一个动态的工程环境中工作,有机会参加各种各样的充满刺激和挑战的项目。
Responsibilities:
Qualification and signal integrity measurement for next generation mobile product and graphics platforms
Signal integrity/DC-DC Power solutions testing and debugging
Signal integrity failure analysis
Signal quality measurement and analysis of high speed busses.
Signal quality measurement and analysis of analog DC/DC power designs
Signal quality measurement and analysis of digital and analog display signals
为下一代移动和显卡平台进行验证和信号完整性测量。
信号完整性/DC-DC电源解决方案的测试和调试。
信号完整性失效原因分析。
高速总线的信号质量测量和分析。
模拟DC-DC电源设计的信号质量测量和分析。
数字和模拟显示信号的信号质量测量和分析。
Requirements:
Major in EE, or related field. BS or above.
Experience with PC architecture
Good system knowledge of Desktop PC motherboards, Notebook motherboards, Graphics, handheld products, embedded systems.
Knowledge with at least 2 of the followings: Signal integrity, Switch power supply, High speed bused such as PCI/PCI Express busses, SDRAM/DDR.
Good English speaking and listening.
电子工程及相关领域。本科或以上。
PC架构经验。
对台式机主板、笔记本主板、手持产品和嵌入式系统有专业系统的认识。
具备以下至少两个方面的知识:信号完整性、开关电源、PCI-PCI Express 等高速总线、SDRAM/DDR等。
Desirable Experience:
Experience in measuring/designing DC/DC power solution
Experience with using high speed oscilloscopes for signal quality measurement is a plus (e.g. tektronics TDS7404, DSA71254)
Experience in designing experiments and evaluating results are preferred.
C/C++ programming is preferred
Mat-lab /Lab-view is preferred
ARM application
有DC-DC电源方案的测量或设计经验。
有使用高速示波器进行信号质量测量经验(如tektronics TDS7404, DSA71254)
有设计经验和评测结果的经验。
C/C++编程能力。
Mat-lab /Lab-view。
ARM应用。
2. Project Manager
Job Title: Project Manager
Department: GPU
Responsibilities:
Monitors the project from initiation through delivery.
Communicate the issue status to the engineers’ internal & external teams.
Correctly represent the urgency of issues and escalate issues appropriately.
Organizes the interdepartmental activities ensuring completion of the project on schedule and within budget constraints.
Work closely with the hardware and layout engineers, and all the validation teams.
Regularly communicate the program status and key issues to management.
Requirements:
Written and oral fluency in English as must, CET-6 is request
Electronic engineering related faculty is request
Bachelor degree request for Shenzhen office
3. Signal Integrity Engineer
Job Title: Signal Integrity Engineer/ 信号完整性工程师
Department: GPU
RESPONSIBILITIES:
Perform board level SI/PI simulation
Generate viable routing constraint for high speed signals on board
Work with front end tools/applications to maintain a high level of simulation accuracy
SI/PI failure analysis
MSEE minimum
Strong background in signal integrity knowledge
Familiar with high speed digital design techniques
Familiar with simulation tools such as Allegro PCBSI, HFSS, and Hspice.
Experience with lab measurement tools such as scopes, TDRs, VNAs, and spectrum analyzers
Team work, working under pressure, independent work
Good verbal and writing communication skills
工作职责:
提供板卡的信号/电源完整性仿真分析
为单板的高速信号提供可行的布线规则
通过使用业界顶端的仿真软件和测试设备,以保持高水平的仿真准确性
对信号/电源完整性问题进行研究分析
职位要求:
研究生及以上学历
对信号完整性理论知识有深入了解
熟悉高速信号的设计知识
熟悉仿真软件的使用,比如Allegro PCBSI、HFSS、Hspice等
了解示波器、时域反射计、矢量分析仪和频谱分析仪等仪器的使用
具有团队合作精神,能承受工作压力,有独立工作能力
良好的书面和口头沟通技巧
软件研发:
1.
SW QA Engineer
Job Title: Software QA Engineer
Department: SW
Responsibilities:
Validation and Verification for Mobile computing
Work closely and collaboratively with other development and QA teams to gather new feature requirements and review and design test cases.
Test Execution and defect tracking
Requirements:
BS/MS in Computer Science/Engineering.
Good C/C++programming skills is desirable.
Design, implementation, and enforcement of software quality process and standards for mobile computing focusing on test execution.
Defect reporting and analysis, test plan development, defect verification, and providing QA support to the development.
Good knowledge on System level test development
Knowledge of Android OS and strong penchant towards mobile technology is desirable
Strong problem solving skills.
Excellent communication, self-driven & motivated, conscious of high quality software.
Ability to work closely & collaboratively with other Development & QA teams especially across geographies.
2.
Department: SW
Job Description:
RESPONSIBILITIES:
岗位描述:
工作职责:
-新技术的研究与实现
职位要求:
-精通C编程以及调试技巧
-对创新及解决具有挑战性的问题充满激情
-具有较强的英文沟通能力
-熟悉Android,Linux优先
生产运营类:
1.
Tesla Product Engineer
Job Title: Tesla Product Engineer
Department: SDM
As a member of our Tesla product engineering group, you will be responsible to sustain and improve all aspects of NVIDIA Tesla GPU products for the fastest super computers and high performance compute (HPC) products on the planet.
Responsibilities:
Identify and analyze all the reported customer technical issues
Provide System level, board level FA on Tesla RMA boards
Co-work with other engineering teams and operation teams to investigate design, component, manufacturing and testing issue to drive quality improvement
Develops, recommends and implements corrective actions based on FA result
Need occasional travel to Hong Kong and Fubao (Futian Free Trade Zone, Shenzhen)
Requirements:
Good English communication skills
Knowledge of Graphics, Servers, PCI-E bus, SDRAM/DDR
Experience with hardware verification/ debug and signal quality measurement
JAVA Scripts programming is preferred
2.
Test Engineer
Job Title: Test Engineer - Manufacturing Diagnositics Validation
Department: SDM
Responsibilities:
Test Engineer responsible for successful accomplishment of Modular Diagnostic Software (MODS) production validation activities.
Minimum Requirements:
Possess a university degree in electrical, electronic, computer or industrial engineering, or equivalent.
Be able to communicate well in spoken and written English.
Demonstrates ability to describe workflow and prepares draft in form of procedure/plan.
Has hands-on experience in operating various computing environments, such as DOS, UNIX/Linux, Windows (98, NT, XP, Vista)
Has hands-on debug experience on hardware electronics circuits with the help of diagnositics software.
Understands the basic of graphics hardware functions in GPU, VGA, TMDS, TIVO, video memory, etc.
Understands the basic functionality of motherboards such as CPU, memory, PCI Bus, PCIe Bus, SATA, USB, etc.
Relevant Experiences Valuable to This Position
Utilizes NVIDIA products (e.g. during academic projects)
Interacts with foreigners (e.g. in school, volunteer works, exchange program, etc...).
Exposes to electronic manufacturing environment (e.g. through intern, part-time job, etc...)
3.
System Design Engineer(Memory Interface)
Job Title: System Design Engineer (Memory Interface)
Job Description/Qualifications:
Responsibilities:
Designs, defines and implements complex system requirements for customers.
Supports the entire product lifecycle from New Product Introduction to obsolescence.
Prepares studies, analyzes existing systems and uses this data to meet customer specifications
Qualify memory subsystem on NVIDIA boards
Determines system specifications and working parameters for hardware/software compatibility
Collect and analyze signal integrity data using high speed oscilloscopes
Work with NVIDIA engineering groups to support released boards
Work with new derivative boards or new boards with alternate components
Collect and analyze signal integrity of affected circuits using advanced test equipment
Work with SW team to generate BIOS and ensure BIOS works on new boards
BSEE (or equivalent) required.
Must have the ability to work well in a team environment and have good written and verbal communication skill.
4. Electrical Product Engineer-FA(Huizhou)
Job Title: Electrical Product Engineer - Failure Analysis
Department: SDM
Qualifications:
Handle escalated failure analysis from factory or NVIDIA FA personnel in a production environment
Perform failure analysis on PCBA of mobile products down to component level
Provide root cause and corrective action in a timely manner
Write clear and complete FA reports detailing steps taken and findings
Work closely with factory personnel and NVIDIA program managers on production issues
Work with NVIDIA Quality department on DPPM improvement
Ability to communicate with design engineer, factory personnel and cross-functional teams
Requirements:
Hands-on experience in troubleshooting PCBA down to component level is a plus
BSEE or equivalent in related technical field
Excellent problem solving and troubleshooting skills
Experience in debugging mechanical/assembly issues on tablet or handheld consumer electronic related product is a plus.
Able to design experiments and collect/analyze data for FA
Able to perform under deadline pressure
Good communication skills
Self-starter
Working knowledge of lab test equipment (DMM, oscilloscopes, etc.)
Located in Huizhou.
天津:
硬件研发类
1 Design Engineer
Job Title: Design Engineer
Department: GPU
Responsibilities:
Hardware Design for Graphics card and Tegra device
Board/System level circuit research and Development
Schematic concept design, Component selection and Bill of Material generation
Board/system level Hardware debug and verification
Responsible for product design issue in overall life cycle
Guide PCB layout engineer for placement, power and high speed signals routing
Guide design Validation engineer for signal measurement
Co-work with SI/EMC team for high speed interface design and EMC solution
Co-work with chip solution team for chip level bring up
Co-work SW engineer on debug and FA
Coordinate with thermal and mechanical engineer for thermal and mechanical design
板卡或系统级硬件电子电路以及电源的开发与研究.
原理图设计,元器件选择,创建生产材料清单.
板卡或系统级硬件电子电路以及电源的调试和验证.
负责解决在整个产品生命周期内的设计问题.
设定和设置PCB布线规则, 并指导PCB设计工程师进行PCB布局设计以及电源和高速信号布线.
指导测试工程师作信号测量,并分析测试结果.
与SI/EMC团队合作进行信号和电源的完整性分析以及电磁兼容性设计
与芯片设计团队合作,调试新芯片。
与软件工程师合作,分析解决问题.
和其他team合作进行热学和机械设计
Requirements:
BS/MSEE
Successful Candidate will possess the following traits:
Can do attitude
High energy
Leadership
Ability to learn complex concepts in a fast pace environment
Strong desire on creativity
Quick thinking and good decision making skills
Good communication skills (written and oral)
大学本科/研究生. 电气工程,计算机技术或相关专业.
精通模电/数电理论
精通高速信号设计
良好的电源设计理论
良好的EMC设计理论
做事积极,进取,有活力.
有一定的领导才能.
有很强的学习和自学能力.
渴望创新.
思维敏捷,做事果断.
良好的沟通能力.
良好的英文读写和口语能力.
2. Design Verification Engineer
Department: GPU
Responsibilities:
信号完整性失效原因分析。
高速总线的信号质量测量和分析。
Requirements:
电子工程及相关领域。本科或以上。
PC架构经验。
ARM application
有DC-DC电源方案的测量或设计经验。
有设计经验和评测结果的经验。
C/C++编程能力。
Mat-lab /Lab-view。
ARM应用。
北京
软件研发类
Parallel Computing SW Engineer
Job Title: Parallel Computing Software Engineer
Department: PSB
To spearhead its breakthroughs in High Performance Computing, NVIDIA is building a team with a unique and critical position within the company and is looking for passionate world-class software engineers.
In this role, you will open up new domains of application for GPUs by researching and developing GPU computing algorithms, driving their adoption with key application developers, and ensuring best possible performance of GPU computing applications on current and next-generation architectures.
Main responsibilities entail educating developers on latest NVIDIA technologies, working with key developers on their applications, and closely collaborating with the architecture and software teams at NVIDIA to influence the design of next-generation architectures.
Application domains include geosciences, life sciences, computer-aided engineering, computational fluid dynamics, computational chemistry, computational physics, computational finance, electronic design automation, data mining, medical imaging, and many more.
Requirements:
Strong knowledge of C/C++, programming techniques, and algorithms
Strong mathematical fundamentals, including linear algebra and numerical methods
Familiar with CPU system architecture and OS fundamentals
Experience with parallel programming, especially data-parallel and/or CUDA programming, a plus
Degree in Computer Science, Engineering, Physics, or Mathematical field (BS minimum, MS or PhD preferred)
Good problem solving skills
Some travel to conferences and for on-site visits with developers will be required
 楼主| 发表于 2014-8-19 14:45:38 | 显示全部楼层
up up
 楼主| 发表于 2014-8-20 07:08:50 | 显示全部楼层
upupup
发表于 2014-8-20 08:37:09 | 显示全部楼层
回复 3# zxtcuo
   应届毕业生可以吗?
发表于 2014-8-20 08:45:46 | 显示全部楼层
这个就是校园招聘 15年毕业的
发表于 2014-8-20 09:04:45 | 显示全部楼层
回复 1# zxtcuo
   已发送    一定要看啊
 楼主| 发表于 2014-8-20 12:31:44 | 显示全部楼层
回复 4# zhenglibin86
   只针对应届生
 楼主| 发表于 2014-8-21 15:06:41 | 显示全部楼层
upupup
 楼主| 发表于 2014-8-22 09:08:15 | 显示全部楼层
upupup
发表于 2014-8-22 16:13:40 | 显示全部楼层
别抱什么太大的希望就好了
GMT+8, 2025-11-19 00:56 , Processed in 0.024785 second(s), 5 queries , Gzip On, Redis On.
