查看: 2525|回复: 0
[招聘] [招聘] NVIDIA 7月第三周岗位更新,工作地点:上海北京
发表于 2014-7-22 12:13:20 | 显示全部楼层 |阅读模式
如果你对这些岗位有兴趣,可以将简历发送到:nvidia.china.hr@gmail.com
岗位介绍 :
上海
1. GPU ASIC Physical Design engineer
As a senior member of our ASIC-PD team, you'll be working on streamlining the chip infrastructure process across product designs, focusing on full chip layout planning (partitioning, planning clock distribution and other structure, methodology), partition/full chip timing closure (primetime scripts, other tools, etc) and gate-level design of high-speed logic
RESPONSIBILITIES:
• Chip integration and netlist generation
• -Synthesis, Formal verification, netlist quality check
• Work in conjunction with Place and Route Engineers to achieve timing closure for both partition level and full chip level
• Develop and enhance entire timing flow from frontend (pre-layout) to backend (post-layout) at both chip and block level.
&#8226; Develop custom timing scripts using tcl/primetime for clock skew analysis, special circuits such as clock dividers, core logic <-> IO macros interfaces such as PCI-E, Frame-Buffer/Memory, TMDS, etc.
&#8226; Develop flow to physically partition and floorplan the entire chip.
&#8226; Develop scripts for performing ECO's.
MINIMUM REQUIREMENTS:
&#8226; BS or MS in Electrical Engineering or Computer Science
&#8226; Above 3 years of relevant ASIC experience ideally with a focus in the chip integration /synthesis/formal and timing closure
&#8226; - Excellent scripts skills
&#8226; - Excellent written and verbal communication skills in English
&#8226; - Ability to multiplex many issues, set priorities, and work in a team environment
&#8226; - Keep up to date with leading edge technologies
2. Sr. PHYSICAL DESIGN ENGINEER (上海/北京)
DESCRIPTION:
A senior role in physical design for NVIDIA GPU and Mobile chips
Participate in various aspects of physical design, including full chip floorplanning, power/clock distribution, timing optimization, place & route, timing closure, power/signal integrity analysis, and physical verification
Troubleshoot a wide variety of design and flow complicated issues, and apply proactive intervention
Collaborate with RTL, DFT and Circuit designers to ensure the high quality of design implementation and optimization
- BS in Engineering or Science
Power user of EDA tools from Synopsys (ICC/DC/PT/STAR-RC), Cadence (EDI/EPS) or Mentor (Olympus-SOC)
Experience in Clock/Power Distribution, P&R, Timing closure, RC Extraction, and verification on 40nm, or 28nm technology
- 3+ years of experience in above areas
PREFERRED:
- MS in Engineering or Science
- Knowledge in 20nm or FinFET technology, circuit design, and package design
- Experience in physical verification tools from Synopsys (ICV/Mojave) or Mentor (Calibre)
- Proficiency in Perl, TCL and Makefile scripts
3.Position Title: Compute Arch
The NVIDIA GPU Computing Architecture group is looking for world class computer architects and scientists to join and lead our effort to advance the state of parallel computing. Our team is designing the fastest and most efficient parallel architectures that power energy-efficient smart phones and the world's fastest super computers.
RESPONSIBILITIES:
&#8226; Enhance GPU architectures to extend the state of the art in performance, efficiency, programmability and reliability
&#8226; Analyze, tune and prototype key applications for new GPU architectures
&#8226; Build model to predict performance, power and reliability on future architecture
&#8226; Design, and develop tools to analyze, simulate, validate, and verify application performance
&#8226; Collaborate across the company to guide the direction of GPU computing, working with software, research and product teams
DESIRED SKILLS and EXPERIENCE:
&#8226; MS Degree in relevant discipline (CS, EE, Math). PhD helpful
&#8226; Strong programming skills in C or C++
&#8226; Strong background in computer architecture, compilers, parallel processing, signal processing and/or high performance computing
&#8226; Experience in characterizing and modeling system-level performance, executing comparison studies, and documenting and publishing results
&#8226; Strong programming skills in CUDA, Perl, OpenMP, MPI or Python is big plus
&#8226; Experience in computer vision, machine learning, and molecular dynamics is big plus
4. Position Title:
DEVELOPER TECHNOLOGY ENGINEER - COMPUTER VISION
Description/Qualifications:
Work with cutting-edge applications of computer vision and image processing on NVIDIA's next-generation products. In this role you will build a close technical relationship with our partners during product development, interacting closely with NVIDIA's architecture and software teams to ensure the best possible performance, results, and developer experience on current and next-generation hardware. You will research and invent new computer vision and imaging algorithms, develop and optimize data-parallel implementations, create technical demos, write whitepapers and present your work at conferences.
REQUIREMENTS: - BS/MS or higher in computer science or related engineering discipline.
- Strong knowledge of C/C++.
- Experience implementing algorithms in computer vision and image processing
- Strong knowledge of programming techniques, especially for parallel architectures.
- Strong mathematical fundamentals, including linear algebra and numerical methods.
- Good communication skills.
PREFERRED SKILLS:
- Understanding of embedded architectures.
- Experience with data-parallel and/or GPGPU programming. - Knowledge of image processing APIs (e.g. OpenCV) and Matlab tools. - Knowledge of automotive systems, notably for cluster, IVI, or ADAS applications. - Software development for modern OpenGL (Core Profile) and Linux.
- Experience in any of the following application areas: Signal and Image processing, Computer vision, Video Processing, Embedded Computing (also on DSP and FPGA), ARM architecture development (NEON optimizations), basics of modern OpenGL development. Some travel is required for on-site visits with developers and conferences. Good written and spoken English is a must.
5.System Design Software Engineer (GPU Architect)
RESPONSIBILITIES:
- We are looking for world class programmers to develop the core infrastructure for modeling, analysis, verification and debugging in the development of large scale graphics chips, which enables NVIDIA's driver stack, applications, tests and studies to all run unchanged on all functional, diagnostic, and performance models, simulations, emulations and silicon for all of NVIDIA's graphics chips.
- The candidates will work with a group of architects to design and develop proprietary internal tools for the visualization, analysis, and debug and verification of tests and applications on various functional and performance simulations of future chips
- The candidates will have opportunities to get involved in cutting-edge GPGPU applied architecture design, verification and optimization, including porting commercial applications to test bench, finding out performance hotspots and data mining for performance analysis.
- Bachelor Degree or higher majoring in CS/EE/Mathematics or relevant fields.
- Strong C/C++ programming ability. Scripting language (Perl, Python, Ruby) experience is a plus.
- Well organized problem solving capability and communication skills
- Strong software debugging capability and experiences
- Proactive, creative and a team player
- Excellent English writing for engineering documentation, English oral well enough to attend meetings - Experience in the following areas is a plus:
- Microprocessor architecture design & verification
- 3D graphics (d3d or OpenGL) application development - Multimedia (video, image processing, visualization) application development
- System level programming experience in OS, compiler, driver, tools, virtual memory system, etc.
- Parallel computing/CUDA/OpenCL/HPC development
6.Position: Sr. Security Architecture Engineer
Job Description: Define architecture for Nvidia security IP blocks which are widely used in both desktop and mobile products. It includes architectural modeling, architectural validation, microarchitecture, following standard bodies and developing infrastructure for hardware and performance verification
- Must have familiarity with ASIC design process.
- Must have strong knowledge and familiarity with data structures and Security Algorithms
- Must have strong knowledge and familiarity with Computer Security NIST Standards ECC, AES, SHA, RSA and RNG Cryptography Specifications
- Requires programming and debugging skills, C/C++, Verilog and scripting.
- MS, or Ph.D. in CS, EE (related technical field) or equivalent. 5+ years of experiences
DESIRABLE REQUIREMENTS: - SoC architecture
- ARM Security Architecture
- System Security Trustzone Hardware/Software Architectures
- Well versed with IP Flow
7. Position Title:
GPU GRAPHICS ARCHITECT
Description/Qualifications: GPU GRAPHICS ARCHITECT – PERFORMANCE /FUNCTIONAL MODELING, VALIDATION AND ANALYSIS
NVIDIA's GPUs and SOCs are world leaders in performance and efficiency. The GPU Graphics architects define, design, implement and validate the state of the art GPU Graphics architecture powering next generation Graphics Applications. They proactively solve challenging technical problems and prudently trade off between performance, power and cost, to deliver the best result.
RESPONSIBILITIES:
- Investigate and propose GPU graphics architecture ideas based on quantitative study of existing and projected architectures.
- Develop performance and functional simulation models and simulation infrastructure.
- Develop performance and functional testplan and tests for new Graphics units and architectural features.
- Test and debug on simulators, RTL and real silicon.
REQUIREMENTS:
- Solid knowledge of computer science, with the focus on computer graphics and/or computer architecture. - Good understanding of GPU concept and pipeline, in terms of Graphics processing and parallel computing.
- Good mastery of C++ language and at least 3 years of C/C++ development experience.
- Experience of performance/functional modelling, profiling and analysis is a plus
- Experience with trace-driven and execution-driven simulation model development is a plus.
- BSEE, BSCSE, or equivalent required. MS or PhD is a plus.
- Candidates with experience of GPU graphics unit design and/or RTL module development are preferred.
8. Hardware Architect
Job Description/Qualifications:
The architect will be expected to work at NVIDIA in the area of IP architecture, algorithms, and software development, building on NVIDIA's current architecture and products and helping to define the next generation hardware architecture. In this capacity, the architect will be expected to become familiar with NVIDIA's current architecture, algorithms, products, and design methodologies, and support the development of new algorithms and their hardware implementations. The architect will also be expected to analyze the performance of proposed and current NVIDIA products, and develop algorithms and architectures to support NVIDIA's product plans.
- M.S./PhD. in signal processing, applied mathematics, computer science, electrical engineering and related discipline with good mathematical knowledge
- 3+ years strong experience in algorithms development in one or some of the following signal processing technologies: digital video hardware or software codec development; computer vision/image processing/multimedia database design; embedded DSP software development; real-time and embedded system design.
- Solid software skills - C, C++.
- Fluent English (both written and spoken) and excellent communication skills
- Demonstrated ability to work independently as well as in a multi-disciplinary group environment
o Video/Camera related project involved.
o Familiar with Compute architecture
o Scripting language (Perl, Python, Ruby)
o Understand Verilog, VHDL
9.Position Title: MOBILE SYSTEM SOFTWARE ENGINEER
Department: SW-TEGRA
Region: APAC
You will work with software engineers to develop and maintain ChromeOS/Linux support for NVIDIA multi-core SOCs in clamshell, tablet and other applications. You will be involved in co-development and new technology development and support with strategic NVIDIA partners and customers.
BS or higher degree in Computer Science, Electrical Engineering or related degree.
2+ years of relevant system software/testing experience
Familiarity with ChromeOS/Linux internal, computer system architecture.
Excellent programming skills in Python, C and C++ Prior experience with manufacture mass-production skill is a plus.
Prior experience with bios, uboot, coreboot skill is a plus.
Good communication and plan skills.
Proactive find out revolution for technical issues and Drive the product to a best quality.
Must be willing to work together with partners and customers.
Must be willing to take new challenge and adapt new technology
10. Position Title: Regional Sales Manager(EC or CC)
(based in any city of east/center China)
Manager all key partners relationship include BP local office/disti/i-caf¨| SI/e-shop/retail shops, drive their commitment together with NVIDIA biz growth Drive all NVIDIA products sales out thru key partners in covered region, include GeForce/NB/Quadro/Tesla/Tegra TAB/SHIELD or game console etc.
Manage key partners activities to growth NVIDIA MSS and sales out.
Drive and develop an effective key partner channel management system align with NVIDIA strategy.
Provide visibility of the sales thru @ all levels of key partners.
Drive effective marketing programs and promotions in region through key partners.
Build good relationship and connections with all key partners and good co-work with internal team fully support to achieve the goal.
Lead and manage the team achieve biz goal.
Qualifications:
8+ Years sales experience at multinational company, experience with DIY business and channel business prefer.
people manager experience
Bachelor degree is the mini. Requirement, MBA prefer.
北京
1. Job Title: Field Application Engineer
Department: Sales
Description:
First and primary point of technical support for all NVIDIA products provided to the customer. Qualifications: Identify and analyze all reported customer issues, and will personally solve technical issues to the extent possible.
- Coordinate the setup of experiments, tests, equipment, and otherwise facilitate the rapid resolution of the problem. –
Work closely with the entire customer team, including sales and program management, as well as applications engineering.
- Escalate, as necessary, critical customer issues and provide timely advance warning of critical customer issues that need attention.
- Technical expert on all NVIDIA products, directly supporting Sales Account Managers, and working closely with Sales Account Managers to secure design wins, and to manage the support of the product through the design-in phase all the way to product end of life.
- Establish close personal technical ties to the customer account, establishing personal relationships to facilitate rapid resolution of customer issues and promote the highest levels of customer satisfaction. MINIMUM REQUIREMENTS:
- 2 Year’s experience in a high tech electronics industry in design role or technical customer support role. - Previous experience in the PC or related industries is beneficial.
- BSEE minimum, Master's degree preferred. - Previous experience in a direct customer support role is beneficial.
- Comfortable working hands-on in a lab environment with electronic test equipment and procedures.
- In-depth knowledge of PC architecture beneficial.
- Software development (especially windows device driver) experience beneficial.
2. GEF Program Manager
Main Job Tasks and Responsibilities
&#8226; Lead the planning and implementation of NVIDIA application platform, such as Geforce experience, Espresso etc
&#8226; Facilitate the definition of project scope, goals and deliverables
&#8226; Develop full scale project plans, plan and schedule project timelines
&#8226; Internal coordination to achieve KPI target of each projects/promotion events
&#8226;&#61472;Initiatives of strategies to grow installation base, and user loyalty
&#8226; Tracking and analyzing data to constantly improve the results
&#8226; Coordinate across internal teams to initiate promotion events in the established platform
&#8226; Develop partnership with other SW ISVs
Education and Experience/Key competencies
&#8226; 5 years and above direct experience in related field, IT/ISV/Gaming companies are more relevant
&#8226; Excellent command of English in speaking and writing
&#8226; Extra experience in social media/IT media is a plus
&#8226; Direct experience in running forums/online media is a plus
&#8226; Solid experience on website/application programing/design is a plus
&#8226; Need to demonstrate strong communication and data analysis competences
&#8226; Proven experience in strategic planning or go to market capability
Key competencies
&#8226; critical thinking and problem solving skills
&#8226; planning and organizing
&#8226; decision-making
&#8226; communication skills
&#8226; influencing and leading
&#8226; delegation
&#8226; team work
&#8226; negotiation
3. Senior Regional Marketing Manager RESPONSIBILITIES:
&#8226; Develop NVIDIA mobile communication platform for partner network management, implement digital strategic marketing plan for partner interactive, Support company growth and creating local value and applicability
&#8226; lead the creative concept and work with cross function team to develop customer loyalty program that drive frequency to the business and create relevancy to China loyalty customers
&#8226;&#61472;Ensures communication of plans and project execution details to regional distributors, icafe SIs, retailers and etailer
&#8226; Provides digital marketing insight and direction for cross-functional teams throughout the Company
&#8226; Develop strategic and operational plans around overall customer digital experience for the work group
&#8226; Manage execution, budget and measuring results
&#8226; 8+ years proven working experience with e-Commerce industry preferred
&#8226; Strong marketing sense and campaign knowledge
&#8226; Strong interpersonal skills and creative mind-set
&#8226; Excellent written and verbal communication skills both in Chinese and English
&#8226; Business analysis skills
&#8226; Good knowledge of marketing tools and techniques
&#8226; Strong negotiation, organization and time management skills
&#8226; Bachelor’s degree & above
4. Parallel Computing Software Engineer
Description/Qualifications To spearhead its breakthroughs in High Performance Computing, NVIDIA is looking for a passionate, world-class Software Engineer to work in its Developer Technology Team. In this role, you will open up new domains of application for GPUs by researching and developing GPU computing algorithms, driving their adoption with key application developers and ensuring best possible performance of GPU computing applications on current and next-generation architectures. Application domains include geosciences, life sciences, computer-aided engineering, computational fluid dynamics, computational chemistry, computational physics, computational finance, electronic design automation, data mining, medical imaging, and many more.
RESPONSIBILITIES: - Work directly with key US developers on their scientific applications, educating them on the latest NVIDIA technologies.
- Closely collaborate with the architecture and software teams at NVIDIA to influence the design of next-generation architectures.
- Some travel to conferences and for on-site visits with developers will be required.
- A good degree from a leading university in an engineering or computer science related discipline. - Strong knowledge of programming languages such as Fortran and C/C++.
- Strong knowledge of programming techniques and algorithms.
- Strong mathematical fundamentals, including linear algebra and numerical methods. - Experience with parallel programming, especially data-parallel using MPI, OpenMP, OpenACC or CUDA C/C++/Fortran.
- Good communication and organization skills, with a logical approach to problem solving, good time management and task prioritization skills. With highly competitive salaries and a comprehensive benefits package, NVIDIA is widely considered to be one of the technology world most desirable employers. We have some of the most brilliant and talented people on the planet working for us and, due to unprecedented and ongoing growth, our world-class engineering teams are expanding fast. If you're a creative and autonomous Software Engineer with a genuine passion for parallel computing, we want to hear from you.
GMT+8, 2025-12-21 06:43 , Processed in 0.031315 second(s), 7 queries , Gzip On, Redis On.
