查看: 1676|回复: 0
[招聘] Micron Puodng is hiring-Analog Design Engineer
发表于 2014-7-15 20:48:51 | 显示全部楼层 |阅读模式
Please send your resume to Cindyling@micron.com
Job Description:
Summary: Detailed design of analog/mixed-signal circuits, including design capture, layout, test, evaluation and debugging of circuit and design support for mass production.
Has the flash memory design experience is preferred.
Essential Functions:
Architects, designs and verifies circuits, logic, systems, algorithms, etc. to meet product requirements.
Determines design approaches and parameters. Responsible for custom layout, including overseeing the work of layout designers. Conducts evaluation of design results by laboratory measurements of ICs.
Reports on design results through design reviews, in accordance with company quality requirements and resolves action items generated as a result of these reviews. Attends design reviews to provide input and guidance to other designers.
Education and/or Experience: Major of micro-electronic is preferred. Bachelor's degree with 1+ year experience or Master degree required. An advanced degree may reduce the minimum experience required.
Knowledge, Skills and Abilities:
Understanding of engineering fundamentals
Knowledge of complex AC/DC analysis (poles, zeros, compensation)
Signal analysis knowledge (convolution, transforms)
Parasitic analysis knowledge (capacitance, resistance, power grid, package)
MOS Device modeling skills (noise, excess thermal noise, DIBL)
Knowledge of CMOS fabrication processes.
Knowledge of MOS transistors and analog/digital circuit design
Knowledge of digital design and design flows for optimal design results (area, timing, power)
Knowledge of design EDA tools such as Cadence Schematic entry, Eldo/Hspice experience
GMT+8, 2025-12-20 18:37 , Processed in 0.015942 second(s), 7 queries , Gzip On, Redis On.
