查看: 6605|回复: 7
[资料] MIPI M-PHY VIP 和 MIPI Unipro VIP
发表于 2014-6-27 23:43:54 | 显示全部楼层 |阅读模式
MIPI M-PHY VIP
WWAGO MIPI M-PHY Verification IP provides an effective & efficient way to verify the components interfacing with MIPI M-PHY interface of an IP or  SoC . The MIPI M-PHY VIP is fully compliant with Standard MIPI M-PHY Version 2.0 specifications from MIPI Alliance. This VIP is a light weight VIP with easy plug-and-play interface so that there is no hit on the design time and the simulation time
M-PHY VIP的BLOCK如下:
M-PHY VIP 详细文档如下:
WWAGO_MIPI_M-PHY__VIP_Datasheet.pdf (327.68 KB , 下载次数: 106 )
MIPI Unipro VIP
WWAGO MIPI  UniPro  VIP is fully compliant with standard MIPI  UniPro  rev. 1.41.00 specifications from MIPI Alliance. This VIP is a light weight VIP with easy plug-and-play interface so that there is no hit on the design time and the simulation time.
the MIPI  UniPro  Verification IP provides an effective & efficient way to verify the components interfacing with MIPI UniPro  interface of an IP or SoC
MIPI Unipro VIP的BLOCK如下:
MIPI Unipro VIP 详细文档如下:
WWAGO_MIPI_UniPro_VIP_Datasheet.pdf (351.78 KB , 下载次数: 67 )
如有感兴趣的,可以联系WWAGO-inc公司的销售sales@wwago-inc.com,申请免费试用。
发表于 2014-7-28 17:38:51 | 显示全部楼层
就知道你是做广告的
 楼主| 发表于 2014-9-22 13:37:04 | 显示全部楼层
这是一个新的工具,可以有效的帮助工程师们进行验证工作。节省大量的人力和时间。
让大家知道,这也是好事情啊。
发表于 2015-2-2 22:35:46 | 显示全部楼层
good job
发表于 2015-2-3 17:50:57 | 显示全部楼层
有了這些資料會更了解MIPI
发表于 2015-2-4 17:50:44 | 显示全部楼层
经鉴定,广告。
发表于 2015-12-29 14:25:35 | 显示全部楼层
lz这是推销产品啊
发表于 2020-6-8 08:12:50 | 显示全部楼层
赤果果的广告
GMT+8, 2025-12-19 18:21 , Processed in 0.023676 second(s), 7 queries , Gzip On, Redis On.
