楼主: beixia
Earthing and bonding handbook
发表于 2016-2-20 02:23:28 | 显示全部楼层
good data
发表于 2016-7-27 14:34:22 | 显示全部楼层
谢谢。
发表于 2017-3-31 15:57:44 | 显示全部楼层
回复 1# beixia
非常感谢您无私分析,同时再问一下您,您有其它ITU-T 干扰防护的手册吗?如有望您再无私分享
一、Directives concerning theprotection of telecommunication lines against harmful effects   from electric power and electrified railwaylines
1990  Volume I: Design, construction andoperational principles of telecommunication, power and electrified railwayfacilities
        1999 Volume II: Calculating induced voltages and currents in practical cases
        1990  VolumeIII: Capacitive, inductive and conductive coupling: physical theory andcalculation methods
         1990  VolumeIV: Inducing currents and voltages in electrified railway systems
2008 VolumeV: Inducing currents and voltages in power transmission and distributionsystems
1999  VolumeV: Inducing currents and voltages in power transmission and distributionsystems
1990  VolumeVI: Danger and disturbance
2008  VolumeVI: Danger, damage and disturbance
1990  VolumeVII: Protective measures and safety precautions
1990  VolumeVIII: Protective devices
1990  VolumeIX: Testing methods and measuring apparatus
二、Mitigation measures for telecommunication installations
       2004  Mitigation measures fortelecommunication installations
       2008  Mitigation measures for telecommunicationinstallations - Part 1
四、1976  Earthing of Telecommunication Installations
五、The Protection of Telecommunication Lines and EquipmentAgainst Lightning Discharges
        1974  TheProtection of Telecommunication Lines and Equipment Against LightningDischarges - Chapters 1 to 5
       1978  The Protection of Telecommunication Lines andEquipment Against Lightning Discharges - Chapters 6, 7 and 8
       1994  The Protection of Telecommunication Lines andEquipment Against Lightning Discharges - Chapters 9 and 10
发表于 2018-1-19 13:46:14 | 显示全部楼层
thanks
发表于 2019-10-29 14:26:55 | 显示全部楼层
thanks
发表于 2021-12-14 18:47:31 | 显示全部楼层
Thank you very much.
GMT+8, 2025-11-7 03:30 , Processed in 0.017340 second(s), 3 queries , Gzip On, Redis On.
