楼主: fingili
[原创] CST Studio Suite 2014
发表于 2014-10-12 13:08:40 | 显示全部楼层
谢谢LZ分享!!!!!!!
发表于 2014-10-12 13:22:57 | 显示全部楼层
我按照readme文件里面去做的,如下:
1) run CST License Manager and Stop Service, close CST License Manager
2) edit license.dat: change <pc-name> (with lower case) in 1-st line with your real HostName
3) put license.dat to \Program Files\CST STUDIO SUITE 2013\ folder
4) put CSTpatcher.exe to \Program Files\CST STUDIO SUITE 2013\ folder and run it there
5) run CST License Manager and Start Service, close CST License Manager
6)After that , when you run CST  choose : ''point to an existing CST license server system''
7)Then, type your pc-name on it(You should type with lower case ) , then OK  & Enjoy it
www.p30download.com
the joy of Downloading!
但是,当我load license进去后,出现这个错误:
“ License server machine is down or not responding. See the system adminstrator about starting the license server system, or make sure you're refering to the right host (see LM_LICENSE_FILE).
Feature: start
Hostname: xxxx
License path: @xxxx;
FLEXnet Licensing error:-96,7. System Error: 11001 "Comm. error"
请高人指点!!!
感激不尽!!!
发表于 2014-10-12 13:24:17 | 显示全部楼层
?? 刚才发的没有了。。。。
发表于 2014-10-12 13:27:11 | 显示全部楼层
我按照readme去做了,可是遇到如下错误:
License server machine is donw or not responding. See the system administrator about starting the license server system, or make sure you're referrring to the right host (see LM_LICENSE_FILE).
Feature:    start
Hostname:   dryy
License path:   @dryy;
FLEXnet Licensing error: -96,7. System Error: 11001 " Comm. error"
发表于 2014-10-12 13:28:01 | 显示全部楼层
Feature:    start
Hostname:   dryy
求大神,高人们指点,
感激不尽!!!!!!!!!!!!!
发表于 2014-10-12 13:35:36 | 显示全部楼层
搞定了。。。。原来readme文件漏了一点,在第4步和第5步之间要加一步:修改环境变量,变量名:LM_LICENSE_FILE 变量值:C:\Program Files\CST STUDIO SUITE 2014\license.dat
记住,最后的license后缀是dat,而不是lic,之前的旧版本都是lic,2014适用的是dat。。。
all good now.. happy weekend!!!!!!!!!!!!!
希望洒家的经验对后来人有帮助!!!
发表于 2014-10-12 15:35:49 | 显示全部楼层
多谢老大
发表于 2014-10-13 09:12:17 | 显示全部楼层
回复 1# fingili
    按照read.txt的文件安装好之后,一打开主界面就程序就中止。出现提示:CST DESIGN ENVIRONMENT 未响应。
请问是什么原因所致。
发表于 2014-10-13 09:13:25 | 显示全部楼层
回复 62# yyan71
    你可以试试改变环境变量
发表于 2014-10-13 09:15:48 | 显示全部楼层
回复 66# yyan71
    那请问CST2013版本设置为dat还是lic?
GMT+8, 2025-11-7 09:06 , Processed in 0.020760 second(s), 4 queries , Gzip On, Redis On.
