查看: 5525|回复: 1
[讨论] calbre lvs option
发表于 2014-5-30 11:23:54 | 显示全部楼层 |阅读模式
大家好, 我使用 calbre2008 lvs pass, calibre2011 lvs  net error ,感觉 lvs 开关选项的问题(版图,网标,lvs rule 都是相同的,好像这两个版本的默认选项不同),还请大侠多多指点,谢谢。
比较了下, calibre 2011 LVS  rule  比 calibre 2008  LVS  rule 多了 一个 error, 四个不同选项:
ERROR  Connectivity     error
LVS   FLATTEN INSIDE                       NO
LVS   SPICE SCALE X PARAMETERS     NO
LVS   SHORT EQUIVALENT  NODES      NO
LVS   FILTER  UNUSED  OPTION  AB AC AD AE RB RC RD RE ZC RG (CAL2011 没有 RG )
LVS  CAL2008 与 CAL2011  REPORT
如下:
                  ##         C A L I B R E    S Y S T E M         ##
                  ##             L V S   R E P O R T              ##
CALIBRE VERSION:          v2008.3_34.24    Fri Oct 3 15:32:40 PDT 2008
                               OVERALL COMPARISON RESULTS
                    #           #     INCORRECT     #
  Error:    Different numbers of instances.
  Error:    Property errors.
  Warning:  Unbalanced smashed mosfets were matched.
  Warning:  Ambiguity points were found and resolved arbitrarily.
                                      CELL  SUMMARY
  Result         Layout                        Source
  INCORRECT      XRC9607_OTG20_PHY             XRC9607_OTG20_PHY
                                      LVS PARAMETERS
o LVS Setup:
   // LVS COMPONENT TYPE PROPERTY
   // LVS COMPONENT SUBTYPE PROPERTY
   // LVS PIN NAME PROPERTY
   LVS POWER NAME                         "VDD" "SAVDD?" "?VDD?" "?VCC?" "?vcc?" "?vdd?" "AVD?" "VD*" "VRP" "VCCA?" "AVD_REF"
                                          "AVD*" "VREFP_SAR"
   LVS GROUND NAME                        "VSS" "SAVSS?" "?gnd?" "?GND?" "?VSS?" "?vss?" "AVS" "AGND?" "VRN" "VREFN_SAR"
   LVS CELL SUPPLY                        NO
   LVS RECOGNIZE GATES                    ALL
   LVS IGNORE PORTS                       NO
   LVS CHECK PORT NAMES                   YES
   LVS IGNORE TRIVIAL NAMED PORTS         NO
   LVS BUILTIN DEVICE PIN SWAP            YES
   LVS ALL CAPACITOR PINS SWAPPABLE       YES
   LVS DISCARD PINS BY DEVICE             NO
   LVS SOFT SUBSTRATE PINS                NO
   LVS INJECT LOGIC                       NO
   LVS EXPAND UNBALANCED CELLS            YES
   LVS EXPAND SEED PROMOTIONS             NO
   LVS PRESERVE PARAMETERIZED CELLS       NO
   LVS GLOBALS ARE PORTS                  YES
   LVS REVERSE WL                         NO
   LVS SPICE PREFER PINS                  YES
   LVS SPICE SLASH IS SPACE               YES
   LVS SPICE ALLOW FLOATING PINS          YES
   // LVS SPICE ALLOW INLINE PARAMETERS
   LVS SPICE ALLOW UNQUOTED STRINGS       NO
   LVS SPICE CONDITIONAL LDD              NO
   LVS SPICE CULL PRIMITIVE SUBCIRCUITS   NO
   LVS SPICE IMPLIED MOS AREA             NO
   LVS SPICE MULTIPLIER NAME              "M" "MR"
   LVS SPICE OVERRIDE GLOBALS             NO
   LVS SPICE REDEFINE PARAM               NO
   LVS SPICE REPLICATE DEVICES            NO
   LVS SPICE STRICT WL                    NO
   // LVS SPICE OPTION
   LVS STRICT SUBTYPES                    NO
   LVS EXACT SUBTYPES                     NO
   LAYOUT CASE                            NO
   SOURCE CASE                            NO
   LVS COMPARE CASE                       NO
   LVS DOWNCASE DEVICE                    NO
   LVS REPORT MAXIMUM                     ALL
   LVS PROPERTY RESOLUTION MAXIMUM        65536
   // LVS SIGNATURE MAXIMUM
   LVS FILTER UNUSED OPTION               AB AC AD AE RB RC RD RE RG ZC
   // LVS REPORT OPTION
   LVS REPORT UNITS                       YES
   // LVS NON USER NAME PORT
   // LVS NON USER NAME NET
   // LVS NON USER NAME INSTANCE
   // Device Type Map
   // Reduction
   LVS REDUCE SERIES MOS                  YES
   LVS REDUCE PARALLEL MOS                YES
   LVS REDUCE SEMI SERIES MOS             NO
   LVS REDUCE SPLIT GATES                 YES
   LVS REDUCE PARALLEL BIPOLAR            YES
   LVS REDUCE SERIES CAPACITORS           NO
   LVS REDUCE PARALLEL CAPACITORS         NO
   LVS REDUCE SERIES RESISTORS            YES
   LVS REDUCE PARALLEL RESISTORS          YES
   LVS REDUCE PARALLEL DIODES             YES
LVS REDUCTION PRIORITY                 PARALLEL
   // Trace Property
                   CELL COMPARISON RESULTS ( TOP LEVEL )
                    #           #     INCORRECT     #
  Error:    Different numbers of instances (see below).
LAYOUT CELL NAME:         XRC9607_OTG20_PHY
SOURCE CELL NAME:         XRC9607_OTG20_PHY
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:            114       115    *
Nets:           30859     30311    *
Instances:      32781     28828    *    MN (4 pins)
                 32110     28044    *    MP (4 pins)
                     9         2    *    Q (3 pins)
                     0         2    *    C (2 pins)
                     8         4    *    rppo_ckt (2 pins)
                   448       135    *    rpposab_ckt (2 pins)
                    32        13    *    D (2 pins)
Total Inst:     65388     57028
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:            114       114
Nets:           16804     16804
Instances:       1779      1779         MN (4 pins)
                  2730      2729    *    MP (4 pins)
                     2         2         Q (3 pins)
                     0         2    *    C (2 pins)
                     4         4         rppo_ckt (2 pins)
                   127       127         rpposab_ckt (2 pins)
                    12        12         D (2 pins)
                 10849     10849         INV (2 pins)
                  1528      1528         NAND2 (3 pins)
                    63        63         NAND3 (4 pins)
                    29        29         NAND4 (5 pins)
                   384       384         NOR2 (3 pins)
                    59        59         NOR3 (4 pins)
                    29        29         NOR4 (5 pins)
                    91        91         AOI_2_1 (4 pins)
                    80        80         AOI_2_1_1 (5 pins)
                   136       136         AOI_2_2 (5 pins)
                     5         5         AOI_2_2_1 (6 pins)
                    19        19         AOI_2_2_2 (7 pins)
                    14        14         AOI_3_1 (5 pins)
                    10        10         AOI_3_2 (6 pins)
                   155       155         OAI_2_1 (4 pins)
                    76        76         OAI_2_1_1 (5 pins)
                    79        79         OAI_2_2 (5 pins)
                    15        15         OAI_2_2_1 (6 pins)
                     2         2         OAI_2_2_2 (7 pins)
                    14        14         OAI_3_1 (5 pins)
                    12        12         OAI_3_2 (6 pins)
                     4         4         OAI_3_3 (7 pins)
                  1258      1258         SDW2 (3 pins)
                  2002      2002         SDW3 (4 pins)
                  3362      3362         SUP2 (3 pins)
                    52        52         SUP3 (4 pins)
                    74        74         SPDW_2_1 (4 pins)
                     1         1         SPDW_2_2_2 (7 pins)
                    35        35         SPUP_2_1 (4 pins)
                     1         1         SPUP_2_2_2 (7 pins)
                    62        62         SMN2 (4 pins)
                     1         1         SMN3 (5 pins)
                     4         4         SMP2 (4 pins)
                     2         2         SMP3 (5 pins)
                    33        33         SPMN((2+1)*1) (6 pins)
                    22        22         SPMP((2+1)*1) (6 pins)
Total Inst:     25216     25217
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                 INCORRECT INSTANCES
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    X0/X13/X35/M3(232.930,130.085)  MP(P12LL)                 ** missing instance **
  2    ** missing instance **                                    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/CC0  C(CP)
  3    ** missing instance **                                    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/CC0  C(CP)
                                      PROPERTY ERRORS
DISC#  LAYOUT                                                    SOURCE                      ERROR
  4    X0/X15/X12/X7/M39(239.712,241.822)  MP(POD33LL)           XI_ANA/XI_Transceiver/XI_HSRCV/XI_Amp/MPM5  MP(POD33LL)
       l: 5 u                                                    l: 5.816 u                    14%
       w: 47.2 u                                                 w: 40.231 u                 17.3%
  5    X0/X13/X15/X78/M6(121.219,188.585)  MN(NOD33LL)           XI_ANA/XI_CLKGEN/XI_PLL/XI_LPF/MM4  MN(NOD33LL)
       l: 11.9881 u                                              l: 10.987 u                 9.11%
       w: 571.468 u                                              w: 649.7 u                    12%
  6    X0/X14/X13/M25(186.376,547.270)  MN(NOD33LL)              XI_ANA/XI_VREF_OTG_HOST/XI_VREF/MM48  MN(NOD33LL)
       l: 5.56485 u                                              l: 7.019 u                  20.7%
       w: 58.7706 u                                              w: 40.438 u                 45.3%
  7    X0/X14/X13/M37(214.906,534.875)  MN(NOD33LL)              XI_ANA/XI_VREF_OTG_HOST/MNcap  MN(NOD33LL)
       l: 5.38391 u                                              l: 10 u                     46.2%
       w: 49.6665 u                                              w: 10 u                      397%
  8    X0/X19/M9(256.609,96.864)  MN(NOD33LL)                    XI_ANA/XI_CLKGEN/XI_PLL/XI_VtoI/MNM2  MN(NOD33LL)
       l: 7.68706 u                                              l: 6.668 u                  15.3%
       w: 118.381 u                                              w: 141.58 u                 16.4%
  9    X0/X8/X29/M3(86.901,334.980)  MN(NOD33LL)                 XI_ANA/XI_DPM/MM18  MN(NOD33LL)
       l: 3.79285 u                                              l: 4 u                      5.18%
       w: 26.55 u                                                w: 25 u                      6.2%
10    X0/X14/X20/M1(233.701,562.439)  MN(NOD33LL)               XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/MM13  MN(NOD33LL)
       l: 5.05211 u                                              l: 5 u                      1.04%
       w: 63.6566 u                                              w: 60 u                     6.09%
11    X0/X14/X20/X53/M34(237.186,536.596)  MN(NOD33LL)          XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/XI_PD_ALL/MM17  MN(NOD33LL)
       l: 2.81824 u                                              l: 5 u                      43.6%
       w: 71.8887 u                                              w: 40 u                     79.7%
12    X0/X15/X12/X7/M31(239.907,233.072)  MN(NOD33LL)           XI_ANA/XI_Transceiver/XI_HSRCV/XI_Amp/MNM7  MN(NOD33LL)
       l: 5 u                                                    l: 6 u                      16.7%
       w: 27.2 u                                                 w: 20 u                       36%
13    X0/X15/X16/M3(235.605,245.190)  MN(NOD33LL)               XI_ANA/MM0  MN(NOD33LL)
       l: 7.68377 u                                              l: 10 u                     23.2%
       w: 280.103 u                                              w: 10 u                  2.7e+03%
14    X0/X6/X18/X1/M1(36.390,72.650)  MN(NOD33LL)               XI_ANA/XI_ID/MM0  MN(NOD33LL)
       w: 720 u                                                  w: 420 u                    71.4%
15    X0/X6/X24/X1/M1(46.058,72.700)  MP(POD33LL)               XI_ANA/XI_ID/MM4  MP(POD33LL)
       w: 672 u                                                  w: 392 u                    71.4%
16    X0/X8/X29/X30/X0/M0(93.288,330.600)  MP(POD33LL)          XI_ANA/XI_DPM/MM13  MP(POD33LL)
       l: 20 u                                                   l: 21 u                     4.76%
17    X0/X9/X7/X6/D0(6.790,573.730)  D(NDIO25LL)                XI_ANA/XI_VBUS/DD5  D(NDIO25LL)
       a: 954.245 sq u                                           a: 905.384 sq u              5.4%
18    X0/X11/X7/D0(37.249,489.110)  D(NDIO25LL)                 XI_ANA/XI_AGND1_AGND2/DD5  D(NDIO25LL)
       a: 2052.97 sq u                                           a: 1722.09 sq u             19.2%
19    X1/X8/X50/X1/M0(250.130,328.325)  MP(P25LL)               MPM0  MP(P25LL)
       l: 5 u                                                    l: 0.28 u               1.69e+03%
       w: 82.36 u                                                w: 0.21 u               3.91e+04%
20    X0/X9/X6/X7/X1/X1/X1/M3(62.940,570.720)  MN(NOD33LL)      XI_ANA/XI_VBUS/MM10  MN(NOD33LL)
       w: 960 u                                                  w: 480 u                     100%
21    X0/X9/X6/X7/X1/X1/X1/M2(62.940,569.920)  MN(NOD33LL)      XI_ANA/XI_VBUS/MM11  MN(NOD33LL)
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:             114        114            0            0
   Nets:            16804      16804            0            0
   Instances:        1468       1468            0            0    MN(N12LL)
                      311        311            0            0    MN(NOD33LL)
                     2522       2522            1            0    MP(P12LL)
                        1          1            0            0    MP(P25LL)
                      206        206            0            0    MP(POD33LL)
                        2          2            0            0    Q(PNP25A25LL_SH)
                        0          0            0            2    C(CP)
                        4          4            0            0    rppo_ckt
                      127        127            0            0    rpposab_ckt
                        4          4            0            0    D(NDIO25LL)
                        8          8            0            0    D(PDIO25LL)
                    10849      10849            0            0    INV
                     1528       1528            0            0    NAND2
                       63         63            0            0    NAND3
                       29         29            0            0    NAND4
                      384        384            0            0    NOR2
                       59         59            0            0    NOR3
                       29         29            0            0    NOR4
                       91         91            0            0    AOI_2_1
                       80         80            0            0    AOI_2_1_1
                      136        136            0            0    AOI_2_2
                        5          5            0            0    AOI_2_2_1
                       19         19            0            0    AOI_2_2_2
                       14         14            0            0    AOI_3_1
                       10         10            0            0    AOI_3_2
                      155        155            0            0    OAI_2_1
                       76         76            0            0    OAI_2_1_1
                       79         79            0            0    OAI_2_2
                       15         15            0            0    OAI_2_2_1
                        2          2            0            0    OAI_2_2_2
                       14         14            0            0    OAI_3_1
                       12         12            0            0    OAI_3_2
                        4          4            0            0    OAI_3_3
                     1258       1258            0            0    SDW2
                     2002       2002            0            0    SDW3
                     3362       3362            0            0    SUP2
                       52         52            0            0    SUP3
                       74         74            0            0    SPDW_2_1
                        1          1            0            0    SPDW_2_2_2
                       35         35            0            0    SPUP_2_1
                        1          1            0            0    SPUP_2_2_2
                       62         62            0            0    SMN2
                        1          1            0            0    SMN3
                        4          4            0            0    SMP2
                        2          2            0            0    SMP3
                       33         33            0            0    SPMN((2+1)*1)
                       22         22            0            0    SPMP((2+1)*1)
   Total Inst:      25215      25215            1            2
CALIBRE VERSION:          v2011.2_34.26    Wed Jul 6 05:20:09 PDT 2011
                    #           #     INCORRECT     #
  Error:    Connectivity errors.
                                      CELL  SUMMARY
                                      LVS PARAMETERS
o LVS Setup:
                                          "AVD*" "VREFP_SAR"
   LVS CELL SUPPLY                        NO
   LVS IGNORE PORTS                       NO
   LVS INJECT LOGIC                       NO
   LVS FLATTEN INSIDE CELL                NO
   LVS REVERSE WL                         NO
   // LVS SPICE OPTION
   LAYOUT CASE                            NO
   SOURCE CASE                            NO
   LVS COMPARE CASE                       NO
   // Device Type Map
    // Reduction
   // Trace Property
                    #           #     INCORRECT     #
Ports:            114       115    *
Nets:           30859     30312    *
                     9         2    *    Q (3 pins)
                     0         2    *    C (2 pins)
                    32        13    *    D (2 pins)
Ports:            114       114
Nets:           16804     16804
                     2         2         Q (3 pins)
                     0         2    *    C (2 pins)
                    12        12         D (2 pins)
                    59        59         NOR3 (4 pins)
                    29        29         NOR4 (5 pins)
                    52        52         SUP3 (4 pins)
                    62        62         SMN2 (4 pins)
                     1         1         SMN3 (5 pins)
                     4         4         SMP2 (4 pins)
                     2         2         SMP3 (5 pins)
                                 INCORRECT OBJECTS
LEGEND:
                                   INCORRECT NETS
  1    Net X0/X8/X26/X28/19                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0189
       (SDW2)utput                                             ** missing connection **
         X0/X8/X26/X28/X10/X0/X1/M2(24.280,306.175):s
       X0/X8/X26/X28/X10/X0/X1/X8(51.820,308.325):MINUS          ** missing connection **
       ** missing connection **                                  (SDW2)utput
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM9:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR2:MINUS
  2    Net X0/X8/X26/X28/X10/16                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net016
         X0/X8/X26/X28/X10/X1/X1/M2(24.280,297.355):s
       X0/X8/X26/X28/X10/X1/X1/X8(51.820,299.505):MINUS          ** missing connection **
       ** missing connection **                                  (SDW2):output
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM1:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR0:MINUS
  3    Net X0/X8/X26/X28/X10/X1/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0201
       (SDW2):output                                             ** missing connection **
         X0/X8/X26/X28/X10/X1/X0/M2(24.280,303.365):s
       X0/X8/X26/X28/X10/X1/X0/X8(51.820,301.215):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM4:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR1:MINUS
  4    Net X0/X8/X26/X28/X11/X0/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0442
         X0/X8/X26/X28/X11/X0/X0/M2(24.280,294.545):s
       X0/X8/X26/X28/X11/X0/X0/X8(51.820,292.395):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM21:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR6:MINUS
  5    Net X0/X8/X26/X28/X11/X1/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/net0153
         X0/X8/X26/X28/X11/X1/X0/M2(24.280,285.725):s
       X0/X8/X26/X28/X11/X1/X0/X8(51.820,283.575):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/MM22:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/XR7:MINUS
  6    Net X0/X8/X27/X28/X10/16                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net016
         X0/X8/X27/X28/X10/X1/X1/M2(24.280,366.645):s
       X0/X8/X27/X28/X10/X1/X1/X8(51.820,364.495):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM1:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR0:MINUS
  7    Net X0/X8/X27/X28/X10/X1/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0189
       X0/X8/X27/X28/X10/X1/X0/X8(51.820,362.785):MINUS          ** missing connection **
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR2:MINUS
  8    Net X0/X8/X27/X28/X11/X0/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0442
         X0/X8/X27/X28/X11/X0/X0/M2(24.280,369.455):s
       X0/X8/X27/X28/X11/X0/X0/X8(51.820,371.605):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM21:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR6:MINUS
  9    Net X0/X8/X27/X28/X11/X1/15                               XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/net0153
         X0/X8/X27/X28/X11/X1/X0/M2(24.280,378.275):s
       X0/X8/X27/X28/X11/X1/X0/X8(51.820,380.425):MINUS          ** missing connection **
        XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/MM22:d
       ** missing connection **                                  XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/XR7:MINUS
10    Net X0/X8/X26/X28/X10/X0/15                               ** no similar net **
11    Net X0/X8/X27/X28/X10/X0/15                               ** no similar net **
12    ** no similar net **                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/OUT_T
13    ** no similar net **                                      XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/OUT_T
                                 INCORRECT INSTANCES
14    X0/X13/X37/M3(232.930,130.085)  MP(P12LL)                 ** missing instance **
15    ** missing instance **                                    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DM_driver/CC0  C(CP)
16    ** missing instance **                                    XI_ANA/XI_DPM/XI_FLSDRV_TOP/XI_DP_driver/CC0  C(CP)
                                      PROPERTY ERRORS
17    X0/X15/X16/X11/M39(239.712,241.822)  MP(POD33LL)          XI_ANA/XI_Transceiver/XI_HSRCV/XI_Amp/MPM5  MP(POD33LL)
18    X0/X13/X15/X78/M6(121.219,188.585)  MN(NOD33LL)           XI_ANA/XI_CLKGEN/XI_PLL/XI_LPF/MM4  MN(NOD33LL)
19    X0/X14/X13/M25(186.376,547.270)  MN(NOD33LL)              XI_ANA/XI_VREF_OTG_HOST/XI_VREF/MM48  MN(NOD33LL)
20    X0/X14/X13/M37(214.906,534.875)  MN(NOD33LL)              XI_ANA/XI_VREF_OTG_HOST/MNcap  MN(NOD33LL)
21    X0/X19/M9(256.609,96.864)  MN(NOD33LL)                    XI_ANA/XI_CLKGEN/XI_PLL/XI_VtoI/MNM2  MN(NOD33LL)
22    X0/X8/X29/M3(86.901,334.980)  MN(NOD33LL)                 XI_ANA/XI_DPM/MM18  MN(NOD33LL)
23    X0/X14/X20/M1(233.701,562.439)  MN(NOD33LL)               XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/MM13  MN(NOD33LL)
24    X0/X14/X20/X53/M34(237.186,536.596)  MN(NOD33LL)          XI_ANA/XI_VREF_OTG_HOST/XI_OTGCON/XI_PD_ALL/MM17  MN(NOD33LL)
25    X0/X15/X16/X11/M31(239.907,233.072)  MN(NOD33LL)          XI_ANA/XI_Transceiver/XI_HSRCV/XI_Amp/MNM7  MN(NOD33LL)
       l: 5 u                                                    l: 6 u                      16.7%
26    X0/X15/X20/M3(235.605,245.190)  MN(NOD33LL)               XI_ANA/MM0  MN(NOD33LL)
27    X0/X6/X18/X1/M1(36.390,72.650)  MN(NOD33LL)               XI_ANA/XI_ID/MM0  MN(NOD33LL)
28    X0/X6/X24/X1/M1(46.058,72.700)  MP(POD33LL)               XI_ANA/XI_ID/MM4  MP(POD33LL)
29    X0/X8/X29/X30/M0(94.018,330.600)  MP(POD33LL)             XI_ANA/XI_DPM/MM13  MP(POD33LL)
30    X0/X9/X7/X6/D0(6.790,573.730)  D(NDIO25LL)                XI_ANA/XI_VBUS/DD5  D(NDIO25LL)
31    X0/X11/X7/D0(37.249,489.110)  D(NDIO25LL)                 XI_ANA/XI_AGND1_AGND2/DD5  D(NDIO25LL)
32    X1/X8/X50/X1/M0(250.130,328.325)  MP(P25LL)               MPM0  MP(P25LL)
33    X0/X9/X6/X9/X1/X1/M3(62.940,570.720)  MN(NOD33LL)         XI_ANA/XI_VBUS/MM10  MN(NOD33LL)
34    X0/X9/X6/X9/X1/X1/M2(62.940,569.920)  MN(NOD33LL)         XI_ANA/XI_VBUS/MM11  MN(NOD33LL)
   Ports:             114        114            0            0
   Nets:            16802      16802            2            2
                        1          1            0            0    MP(P25LL)
                        0          0            0            2    C(CP)
                        4          4            0            0    rppo_ckt
                        4          4            0            0    D(NDIO25LL)
                        8          8            0            0    D(PDIO25LL)
                    10849      10849            0            0    INV
                     1528       1528            0            0    NAND2
                       63         63            0            0    NAND3
                       29         29            0            0    NAND4
                      384        384            0            0    NOR2
                       59         59            0            0    NOR3
                       29         29            0            0    NOR4
                       91         91            0            0    AOI_2_1
                       80         80            0            0    AOI_2_1_1
                      136        136            0            0    AOI_2_2
                        5          5            0            0    AOI_2_2_1
                       19         19            0            0    AOI_2_2_2
                       14         14            0            0    AOI_3_1
                       10         10            0            0    AOI_3_2
                      155        155            0            0    OAI_2_1
                       76         76            0            0    OAI_2_1_1
                       79         79            0            0    OAI_2_2
                       15         15            0            0    OAI_2_2_1
                        2          2            0            0    OAI_2_2_2
                       14         14            0            0    OAI_3_1
                       12         12            0            0    OAI_3_2
                        4          4            0            0    OAI_3_3
                     1258       1258            0            0    SDW2
                     2002       2002            0            0    SDW3
                     3362       3362            0            0    SUP2
                       52         52            0            0    SUP3
                       74         74            0            0    SPDW_2_1
                        1          1            0            0    SPDW_2_2_2
                       35         35            0            0    SPUP_2_1
                        1          1            0            0    SPUP_2_2_2
                       62         62            0            0    SMN2
                        1          1            0            0    SMN3
                        4          4            0            0    SMP2
                        2          2            0            0    SMP3
发表于 2015-9-18 08:43:04 | 显示全部楼层
请问一下你的那两个warning的问题解决了没有?知道是什么引起来的吗?
GMT+8, 2025-9-17 20:59 , Processed in 0.019768 second(s), 5 queries , Gzip On, Redis On.
