查看: 1772|回复: 0
[招聘] 招聘:资深系统/模拟/数字IC工程师(成都)
发表于 2014-5-19 10:43:53 | 显示全部楼层 |阅读模式
工作地:成都
联系人:Nancy
QQ:11018497
E-MAIL:11018497@qq.com
1、Senior System Design Engineer
Responsibility
- To perform IC system design and compile system specification
- To prepare FPGA prototype setup
- To conduct system validation
- To conduct silicon evaluation
- To invent and develop cutting-edge touch technology
- To debug and investigate during product development cycle
- To prepare and generate system architecture reports
Requirement
- Experiences and knowledge in LCD display technology development is important
- Ph.D/ M.Ph/ M.Sc/ B.Sc in Electronics Engineering equivalent
- 3 years of experience in IC design
- 3 years of experience in one or more of the following areas: touch controller IC, LCD display systems, mobile phone systems
- Familiar with SoC design, Verilog HDL, C / C++, Assembly, FPGA prototyping, DSP, RTL, DAC and ADC
- Candidates with substantial working experiences, including university research experiences, will be considered as Senior Engineer.
2、Senior Analog Design Engineer
Responsibility
- Perform accuracy analog circuit design, schematic entry, and circuit simulation, including high speed drivers, high speed interface IP, low jitter PLL, PHY, etc.
- Perform mixed-signals integration, silicon evaluation, device and process developmental support,
- Layout supervision and design documentation.
Requirement
- M.Ph/M.Sc/B.Sc in Electronic Engineering or Computer Engineering or equivalent,
- At least 3 years of IC design experience. People with familiarities / knowledge in display driver development is high priority,
- Experience in designing any of the following Analog blocks: Bandgap, Linear Regulator/LDO, PWM/DC-DC converter, Op Amp, Error-Amplifiers, Buffer, Gate/Source Drivers, Comparators, Bias Circuits, UVLO, Thermal Shutdown, ADC/DAC, LED Driver and etc…
- Candidates with substantial relevant working experience will be considered as Senior Engineer in leadership roles.
3、Senior Digital Design Engineer
Responsibility
-Perform logic design, RTL coding, design verification, logic synthesis, DFT and static timing analysis
-Develop verification environment and coverage closure
-Support wafer level testing and silicon evaluation
Requirement
- B.Sc or above in Electronic Engineering or equivalent. Applicants with postgraduate degree would be considered as an advantage
- 5 Years or above of solid experience in one or more of the following areas: Verilog-based logic design and synthesis, constrained random testbench with System Verilog & UVM, assertion based design verification or circuit-level SPICE simulations
- Knowledge of SoC and embedded system.
- Knowledge of scripting languages such as Perl, TCL and Make
- Candidate with less experience will be considered as Digital Design Engineer
GMT+8, 2025-12-26 09:01 , Processed in 0.018400 second(s), 7 queries , Gzip On, Redis On.
