查看: 2217|回复: 0
[招聘] Marvell近期热招职位
发表于 2014-5-16 10:57:02 | 显示全部楼层 |阅读模式
Job Title: Sr.Software Engineer in Test
Description:
In the position, the candidate will beresponsible for creating and executing the test suite/cases, test tools, andautomation system to assure the quality of software platforms, which covercomponents from low level boot-loader, device driver, OS, middleware(multimedia and graphics), and up to high level application framework (likeAndroid), and Marvell proprietary compiler/debugger/performance tools.
His/her responsibilities will include butnot be limited to
- Identify the functionality, stability,performance and power quality criteria for the whole system or individualcomponents;
- Execute test suites to reach definedtest coverage and debugging requirement.
The candidate should possess a Bachelor of Science degree in ElectronicEngineering, Computer Science with relevant experiences, or Master of Sciencedegree in Electronic Engineering, Computer Science with relevant experience, orequivalent.
The candidate is expected to have belowextra qualifications:
- Programming skill in C, C++ andscripting language, i.e. Perl, python, is a must.
- Knowledge or working experience inprojects similar to above projects is preferred.
-Experience in general embedded softwaredevelopment/debugging/validation and its automation is a plus.
-Leadership experience in either softwarevalidation or development is a plus.
-Technical influence and interpersonalinfluence experience in multi-national company is a must. (English andMandarin)
2.
Job Title: Software Test Engineer
Job Description:
System software testengineer to work on WLAN, Bluetooth, NFC and Wi-Fi Display on smartphone/tablet platform.
1) Develop WLAN,Bluetooth and NFC Auto and manual test cases on smart phone/tablet platform.
2) WLAN, Bluetooth andNFC User experience, Function, Stability, Power and performance test andanalysis on smart phone/tablet platform.
3) QUALITYAssessment  and assurance for WLAN,Bluetooth NFC and Wi-Fi Display features on each APSE release.
Qualifications:
1) Bachelor in EE, CSor equivalent is required
2) 2+ year relevantAndroid/Linux/smart phone/tablet platform test experience is required
3) Fluent in English(read and write) is required
4) Experience with C,JAVA programming and debugging is required
5) Knowledge ofWlan/Bluetooth/NFC is required
6) Knowledge of Linuxkernel/driver development is preferred
7) Knowledge of mobilehardware architecture is preferred
3.
Job Title: Wifi/BT/NFC Software Engineer
JobDescription:
Seniorsoftware engineer to work on WLAN, Bluetooth and NFC software development andplatform integration for APSE
1) Develop WiFi (IEEE 802.11 a/b/g/n), Bluetooth and NFC middleware/applicationon Android platform.
2) Optimize power consumption and performance of WiFi, Bluetooth and NFCsubsystems on Android platform.
3) Develop Android GUI, framework and applications to enable new use cases ofWiFi, Bluetooth and NFC connectivity features.
4) Support customer porting/debugging remotely or onsite as needed.
5) Creative innovation based on WLAN, Bluetooth and NFC
Qualifications:
1)MS in EE, CS or equivalent is required
2) 5+ year relevant Android/Linux development and debugging experience isrequired
3) Fluent in English (oral/listen/read/write) is required
4) Experience with C, JAVA programming and debugging is required
5) Knowledge of TCP/IP and socket programming is required
6) Knowledge of WiFi/Bluetooth/NFC is required
7) Experience of Linux kernel and driver development is preferred
8) Knowledge of mobile hardware architecture is preferred
4.
Job Title: CPU Software Engineer - Android VM, Browserand System
Business Unit Introduction::
CPUR&D group in Shanghai is chartered to develop and deliver world-class high
frequencyand low power CPUs which are compatible to ARM v7/8 ISA, joint-designwithOperating System and Virtual Machine for mobile and server.
Thegroup alsodelivers high quality and complete development tools, modeling andoptimizationsolutions for Marvell CPUs in Marvell application processors,communicationprocessor, video processors, storage processors, printerprocessors and etc.
Withcompany's business and R&D expansion in China, we are looking fortalentedengineers who would like to join us to experience the opportunitiesfrom
Marvell'srapid growth.
Job Description:
Thework includes software design/development of following projects for MarvellCPUs:
-Solution of optimized Java VM in Android (Dalvik and ART);
-Solution of optimized Android system including Linux for best UI and stystemperformance;
-Solution of optimized browsers for Android;
-Solution of profiling and tracing tools for VM/system performance analysis
Qualifications and Responsibilities:
-BS/MS/PhD in electronic engineering/computer science (or equivalent).
-Strong advanced low power CPU, memory controller and system bus
  architecture/micro-architecture knowledge.
-Strong C/C++ programming skills, and/or Java programming skills.
-Research or working experience in any relevant projects described above.
-Knowledge of ARM architecture, profiling and optimization is a great advantage.
-Cooperative team player with good communication and teamwork skill.
-Fluent communication in both Chinese and English is an advantage.
5.
JobTitle: Telephony QA/Performance Engineer
Responsibilities:
Marvell is looking for a software engineer for telephony QA andperformance optimization.
It will be responsible for Marvell telephony stack quality assurance, includingdesign/patch review, test case/tool development, performanceanalysis/optimization, customer issue analysis and others.
This position needs a good technical/programming and quick learning capabilityto handle the task in design/code review, issue analysis etc.
Qualifications:
1) Typically requires a BS (CS or EE) degree and 5 years of experienceor an MS (CS or EE) degree and 3 years experience
2) Experience with telephony service, 3GPP protocol, AP/CP communicationdevelopment/validation is preferred.
3) Experience in C/C++/JAVA programming is required.
4) Experience in Linux/Android shell/tools development is desirable
5) Telephony related Performance analysis experience is desirable.
6) Good in communication and team work.
6.
Job Title: System Design Engineer – Hardware Oriented
JobDescription:
Responsible for hardware related tasks,including but not limited to components selection, hardware schematic design, layoutreview, board build, debug and system validation. Work closely with customerand third parties. Evaluate solution from third parties and support customer tocomplete design. Complete system level validation and develop automation testtools.
JobResponsibilities:
- Complete schematic for reference design.
- Responsible for EVK build, bring up anddebug.
- Developing automation testing tools forsystem level validation.
- Complete the system level validation, writedocuments and test reports.
- Customer schematic and layout review.
- Customer board bring up, debugsupporting.
JobQualification:
- MSEE required.
- Experience in hardware board designincluding schematics design, layout review, new design bring up and systemdebug.
- Experience of ASM, C, C++ programming andC-coding skills.
- Experience of Python programming is aplus.
- Experience of Java programming experienceis a plus
- Experience of Windows programming is abig plus.
- Ability to work in a multi-tasking, fastpace and team oriented working environment.
- Good English reading/writing/speaking skill.
7.
Job Title: Firmware Engineer
Job Description:
This is an entry level, firmware engineeringoriented system engineer position. The engineer will be part of the vertical systemengineering team composed with hardware engineering, software engineering,firmware engineering, FPGA design engineering, signal integrity engineering,and others. The IC products to work with include Ethernet PHY/NIC/Switch/SoC,high speed SerDes based PHYs, DTV front end components, PLC PHYs, and so on.System engineering team is responsible for many post silicon engineeringefforts like product validation, platform development, collateral development,technical support and so on.
Job Responsibilities:
- Boot Code Development.
- BSP Development.
- API Driver Suite Development.
- Protocol Stack Firmware Development.
- Application Level Firmware Development.
- Technical Support to Customers.
JobQualification:
- BS/MS in EE/CE/CS.
- Must have good program skill.
- Must be familiar with embedded system.
- Must have good knowledge with computer system and data network system.
- Must be willing to work in a multi-tasking, fast pace, team oriented workingenvironment.
- Must be able to quickly absorb different kinds of knowledge and apply them inthe works.
- Working experience on firmware/software development are preferred.
- Familiarity with Ethernet and network protocols are some pluses.
If you are interested in exploring a job opportunity with Marvell,please send me a copy of your bilingual resume to: al-china-hr@marvell.com
Email Subject: 姓名_学历_学校_工作年限_应聘岗位_意向城市; 比如: 张三_硕士_交通大学_3yrs_Platform_上海
GMT+8, 2025-12-26 05:13 , Processed in 0.012559 second(s), 3 queries , Gzip On, Redis On.
