查看: 1491|回复: 0
[招聘] Cadence SH 招聘Principal Product Engineer
发表于 2014-5-7 12:04:41 | 显示全部楼层 |阅读模式
更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you have interest, PLS send your updateCV to zhangyl@cadence.com
1. Principal ProductEngineer (数字后端产品工程)
PositionDescription:
1.Work in shanghai Engagement PE team, mainlyfocus on TSMC-related project.
20nm and 16nm FinFET flow establishment, from synthesis to final SI timingclosure
2.Work closely with other team members for technique communication andprojects.
3.Can take lead role in project plan and action.
4.Co-work closely with R&D team to find thedebug the software problem in a IC backend way as early as possible.
PositionRequirements:
1. Master with 7-8 years working experience orBachelor with about 10years experience.
IC design background, especially in the back-endflow. Low Power related working experience will be a strong plus.
2. Syntheis, Backend experience, LVS, DRC, CLPknowledge and tape-out experience.
Unix System knowledge, vi/TCL/TK/CSH will beplus.
3. Strong scripting capability, includingshell/tcl/perl.
4. Good communication in English and Chinese,good confidence and good self-motivation.
5. Good team spirit, well-aligned with the"One Cadence, One Team."
2. Principal ProductEngineer
Position Description:
1. Work in shanghai Silicon Signoff andVerification (SSV) electrical PE team, mainly focus on Virtuoso Power System(VPS) and Voltus Power System (Voltus).
2. Support key customer engagements and localAEs to help on the business increasement.
3. Working as a domain expert to wellcommunicate with customers for their valuable feedbacks
4. Co-work closely with R&D team to enhacethe tool based on customers' real demandings
Position Requirements:
1.Master with 7-8 years working experience or Bachelor with about 10 yearsexperience.
    ICdesign background, especially in Cadence Virtuoso platform. Cadence Encounterplatform experience will be a plus
2. One or both of electrical analysis experienceon power and is necessary
3. Working experience with foundry and processtech files, spice models are desired
4. Product Engineering and customer supportingexperience is desired.
5. Good communication in English and Chinese,good confidence and good self-motivation.
6. Good team spirit, well-aligned with the"One Cadence, One Team."
GMT+8, 2025-12-25 23:13 , Processed in 0.018111 second(s), 4 queries , Gzip On, Redis On.
