楼主: scsi
安装SYNOPSYS LICENSE 报错,请专家帮忙!
发表于 2015-6-26 18:30:14 | 显示全部楼层
Setting Up the User Environment
To set up your users, you must create a Synopsys source file, or modify
each user's $HOME setup files (typically .cshrc, .profile, .kshrc, or .bashrc),
as follows. For tool-specific information, see "Setting Up <product_name>
for Each User" in the appropriate tool chapter in the Installation Guide.
    1. Set SNPSLMD_LICENSE_FILE, LM_LICENSE_FILE or a tool-specific licensing variable.
       This variable specifies the path to the Synopsys FLEXlm license server.
       Note:
         SNPSLMD_LICENSE_FILE is supported only for tools using the snpslmd Synopsys
         Common Licensing (SCL) daemon. LM_LICENSE_FILE is supported for all Synopsys
         tools (all daemons).
       In the following example, it is assumed that the Synopsys license server
       is using TCP port 27000, the default port. (However, you can specify another
       port by modifying the SERVER line of your site's keyfile--for example,
       "SERVER myserver 8308a297 26585.")
       Example:
         * Add to .cshrc
            setenv SNPSLMD_LICENSE_FILE 27000@myserver
            or
            setenv LM_LICENSE_FILE 27000@myserver
          * Add to .profile, .kshrc, or .bashrc
            SNPSLMD_LICENSE_FILE=27000@myserver; export SNPSLMD_LICENSE_FILE
            or
            LM_LICENSE_FILE=27000@myserver; export LM_LICENSE_FILE
    2. Add the tool executable files to the user path.
       Example:
         * Add to .cshrc:
           set path=(synopsys_root/<platform>/<product>/bin $path)
         * Add to .profile, .kshrc, or .bashrc:
           PATH=synopsys_root/<platform>/<product>/binPATH
           export PATH
       Note:
         For some tools, the appropriate directory of executable files
         is synopsys_root/bin.
    3. Set any tool-specific variables.
       In many cases, tool-specific environment variables must be set.
       Typically, you need to set an environment variable that points
       to the root directory for the Synopsys tool.
       Example:
         setenv SYNOPSYS /path/to/synopsys_root
       Note:
         Not all tools use the $SYNOPSYS environment variable. In some
         cases, other tool-specific variables must be set.  See the
         Installation Guide for details.
发表于 2015-8-22 19:15:39 | 显示全部楼层
Hi guys, i'm not able to start lmgrd on Fedora 17.I have SCL 11.5 i86_lsb, DC 2013.03 and installer v3 downloaded at http://bbs.eetop.cn/thread-418738-1-1.html
I generated license on Windows 7/8, and verificated with sssverify on linux.
The 3 first lines of my license are:
SERVER localhost 000000000000 27000
VENDOR snpslmd /usr/synopsys/11.5/linux/bin/snpslmd
USE_SERVER
I used MAC of zeros because lmhosid returned it, but i tried also with the real MAC of PC.When i write lmgrd -c /usr/syonpsys/synopsys.dat -l , it returns "lmgrd exited with status 0, signal 17". Why?
While, the lines of bashrc are:
export SNPSLMD_LICENSE_FILE="27000@localhost"
export LM_LICENSE_FILE="27000@localhost"
exportPATH=$PATH:/usr/synopsys/H-2013.03/bin
exportSYNOPSYS=/usr/synopsys/H-2013.03
Anyone can help me please?
There are other post about this problem, but i don't find the correct solution
发表于 2015-9-23 16:26:37 | 显示全部楼层
不大清楚
发表于 2015-10-5 16:20:00 | 显示全部楼层
i get the same problem
发表于 2015-10-5 23:00:57 | 显示全部楼层
I got the same problem in RHEL5.8
发表于 2016-3-19 14:41:53 | 显示全部楼层
8楼的就是正解。我之前一直不觉得是网卡名字的问题。可是结果啪啪打脸啊。改完名字,verdi正常启动!
发表于 2016-4-21 19:43:42 | 显示全部楼层
回复 8# snk88
   同意这位看法
发表于 2017-4-19 15:59:20 | 显示全部楼层
回复 1# scsi
发表于 2018-8-22 12:47:34 | 显示全部楼层
回复 10# michealja
8楼正解!修改请参考https://zhuanlan.zhihu.com/p/29150773
已经成功!!谢谢
发表于 2018-8-22 12:48:24 | 显示全部楼层
感谢8楼正解!
修改可以参考 https://zhuanlan.zhihu.com/p/29150773
GMT+8, 2025-12-30 16:03 , Processed in 0.018853 second(s), 5 queries , Gzip On, Redis On.
