查看: 2647|回复: 1
[讨论] snoop operation of 60x bus
发表于 2014-3-18 12:16:51 | 显示全部楼层 |阅读模式
anyone can tell the details of this operation, what's the purpose of this operation.
thanks a lot.
 楼主| 发表于 2014-5-8 13:27:11 | 显示全部楼层
The 60x bus can transfer 8 bytes of data in 1 clock cycle. However, with the dead cycle between data tenures,
each transaction, a 32-byte burst, takes 5 clock cycles. Therefore, the theoretical maximum throughput of
the 60x bus with a 100-MHz memory bus speed is 640 MBytes/sec.
Transfer rate = (32 bytes/5 clock cycles) x 100 MHz = 640 MBytes/sec
GMT+8, 2025-9-15 21:37 , Processed in 0.014880 second(s), 6 queries , Gzip On, Redis On.
